Question about LG 50PC1DRA 50 in. Plasma Television
L troubleshooting a lg 50pc1dra
My tv will act like it turns on and then shuts right back off no time for a picture to show up or sound. it did this a few months ago and somone told me to unplug it and press somthing but basicly reset it and it turned right back on
  • 19 Answers
SOURCE: LG 42LG5 TURN ON TV PICTURE GOES BLACK
This could be 1 of a few things here. Without opening up your set and trying to look at voltages or indiciator lights I couldn't tell you exactly without some more info.
Without looking at it myself here are my thoughts and where I would first look at.
It may be a main board because:
1) Main board processes all your audio/video signals. Bad main board means bad video processing. Could do that. Especially if the main board is not sending the right signal or a bad signal to the rest of the boards so they don't do their jobs.
It may be a power supply because:
1) Power supply is well, the power supply. If it's sending inadaquete voltage to the main board you may not be recieving enough juice to keep that main board doing your video processing or further up the line keeping enough juice flowing to your TCon board to keep it telling things where to go and what to do. The power supply sends voltages to your Ballast board(controls your lights) and to your main board through which power is supplied to your TCon board via a LVDS line and a +12/+16V signals. If the power supply isn't pumping out enough juice to keep the TCon or Main Board running, it could be a problem. By the same token it could be that your P/S isn't sending power out to your ballast board.
It could be a TCon because:
1) If the TCon is bad, you won't get your pictures. This could be the TCon board itself or the LVDS cable from your TCon to your Main. However, with few exceptions, if it's a bad TCon you're looking at a total panel replacement.
It could be a ballast board because:
1) The Ballast Board controls the lighting behind the LCD screen. If this isn't working right you won't be seeing much of anything without that back lighting. If this is bad, it's a panel replacement. These are not field replaceable items by LG.
Based on the symptoms, without more data or a eyes-on view of it, I would say you're most likely looking at a Main Brd or PSU problem.
Posted on Feb 21, 2009
SOURCE: no picture but has sound
hey i think i know your solution on how to fix that you should get another tv lol jp go to my web site and I'll tell you a couple of methods to try.its meatspin.com
Posted on Feb 28, 2009
  • 6 Answers
SOURCE: LG 42 LCD no sound or picture
This is probably bad capacitors on the power supply board. My LG 42LB1DR has a known problem with this and I replaced the four bac capacitors myself and saved 5-6 hundered dollars that I was also told that it would cost to fix. I fixed for under 10 dollars and about 20 minutes. LG knows about it but they dont really want to admit it. My TV was only 26 months old when this happened. The four capacitors are made by Samxon and are 2200uf @ 10v. They are junk so even if you have the entire board replaced for say $200 its just going to happen again. They need to be replaced with a different brand.
Posted on Apr 29, 2009
rulds2008
  • 3866 Answers
SOURCE: LG 50PC1DRA POPS AND SHUTS OFF
Your right its a power supply issue and what your hearing is capcitor pop or maybe even a fuse, Well if you know about eletronics sure the new psu is going to be $150 bucks
hope this helps
Posted on Jul 18, 2009
  • 5 Answers
SOURCE: LG 47LC7DF Green Light Blinks 16 Times - No Picture or Sound
The lights indicate what the issue is. Kind of like your check engine light in your car tells you something is wrong with the engine.
Posted on Aug 31, 2009
My LG tv will go on then after a few seconds the screen goes from black back to picture of and on a few times then shuts off. Help!
LG LED TV has no picture (black screen) but still sound ...
www.tomsguide.com/answers/.../led-picture-black-screen-sound-fixed.ht...
7 days ago - My 32' LG LED TV has suddenly lost picture! The sound is all right but theScreen is pitch black. After switching it on the picture flashes for a second and thenthe ... LG LED TV has no picture (black screen) but still sound - can it be fixed? Tags: ... a touch on the screen reveals nothing so it's not the back light.
Monitor going black after 2 seconds [Solved] - CCM.net
ccm.net > Forum > Hardware
Oct 9, 2012 - Brightness goes down, display draws less juice, and you can at least use .... it's the LCD's Inverter ... you have to replace it for it to go back to ... If the screen is turning off every two seconds or so and then it comes ... i turn my tv on it comes right on, but then after a few minutes turns off, .... Digital Trends for LG. No display in monitor
Jan 11, 2013
Ps3 and hdmi cable
Oct 8, 2012
More results from ccm.net
TV with Black Blank Screen Repair How to Troubleshoot ...
? 3:16
https://www.youtube.com/watch?v=kFdVi2ejfzA
Dec 20, 2015 | LG Televison & Video
Please help diagnose problem with Panasonic TH-50PC77U Plasma HDTV
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Oct 31, 2015 | Panasonic TH-50PC77U 50 in. Plasma TV
Tv turns on w/pic then pic dissapears light blinks 4 times
I have the same issue, we've had to change our bulb three times in less than two years. now we have 61" expensive paper weight. Our current bulb is less than 6 months old. The TV is only 2 years old and like i said this is our third bulb.
the blue light blinks 4 times. you get sound. then a few minutes the the picture returns... then it goes out, and the cycle goes on.
A solution to this would be greatly appreciated.
Oct 08, 2009 | RCA HD61LPW165 61" Projection HDTV
3 lights blink and a loud buzzing sound.
Color wheel you can get one at the following link with instructions on how to replace it
Jun 01, 2009 | Samsung HLP4663W 46" Rear Projection HDTV
Won't turn on
those tvs will try 3 times before completely shutting down. you can try and take the back off and check CP150 it is a large capactior located near the middle of the board on the left hand side(looking from back) if it looks and feels like the top is vented or puffed out then that could be the problem. if not i suggest having a qualified service tech take a look because there are too many things that could be the root cause.
Apr 07, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
PLEASE HELP QUICK! 36" Sony blinking 4 red times
probably this is the small mailfunction,probably some contacts,but you probably not a qualified to do this repair ,so please call a service man
Feb 07, 2008 | Sony FD Trinitron WEGA KV-36HS20 36" TV
Tv powers on, but turns off after a few min
somone with some sort of tv knowledge told me that sometimes people dont realize t but moisture builds up inside and it needs to be dried back out
Jan 28, 2008 | Televison & Video
Loose Sound and Picture very now and then, but TV stays ON
Check out www.manualsparadise.com There are service manuals available for download. They start at $7.95. That might point you in the right direction.
Oct 12, 2007 | Pioneer PRO-510HD 53" Rear Projection...
LG 50PC1DRA 50 in. Plasma Television Logo
35 people viewed this question
Computer Repairing
Computer Repairing
