Question about Kodak EASYSHARE 5500 All-In-One InkJet Printer
Colour from printer does not match colour shown on screen
I am currently wasting photo paper and printer ink attempting to get the same result on printer as being displayed on screen.
Please help.. Is there a way to make sure I get the colour and tone shown on screen on the printer
    Problem Solver:
  • 10 Answers
The manual WILL have instructions on which ink to use, it will be by the same company and have a special number. If you cant find out what it is just ask PC-WORLD or google search it. Simple :D
Posted on May 20, 2009
Why can't I print in colour although cartridge is quarter full. Cleaning the heads has no result.
It should be an installation or alignment problem. I would suggest you to go through an alignment test, and if problem still continues, uninstall and reinstall your printer
May 10, 2016 | HP Deskjet 3050A J611G Inkjet...
Colour lighter than previouse copies
Replace the ink-cartridges, to see if that fixes the problem.
Check the printer setup to see if it is in "draft" mode or "normal" mode.
Feb 24, 2015 | Canon SELPHY CP740 InkJet Photo Printer
Colour don't match the screen light blue on the screen will be light pink when printed
If you have used non canon ink tanks that will be the problem.'
If you have used genuine canon ink then you may have placed the tanks in the wrong place.
Also try using genuine canon paper as that could also be the problem.
Apr 10, 2010 | Canon PIXMA Pro 9500 InkJet Photo Printer
Printed colours doesn't match with monitor colours
Here is a list of reasons why colours on electronic designs might differ from printed designs:
  • Monitors work in the RGB (Red,Green,Blue) colour space while printers use the CMYK (Cyan, Magenta, Yellow and Black) colour space.
    Designs look fine on a monitor if they are designed in RGB to begin with. Converting them to CMYK might make them look odd on screen, but they will print correctly, to a certain measure. It is difficult to sign of an image file that is currently in CMYK mode while viewing with an RGB monitor.
  • Monitor settings differ.
    The designer was sitting in a darkish room when choosing the blue and his blue looks vibrant. The client was viewing the same design in a well-lit room, making the blue seem lighter. The designer uses an LCD display and the client uses a CRT monitor and the vibrancy differs. The contrast and saturation settings on each monitor might differ as well, rendering the blue with different values.
  • Each printer in the world prints colour slightly different.
    Sometimes it is really obvious and sometimes it is almost impossible to see the difference. Normal desktop printers are definitely not something to do colour proofing with. If you print the design out on your desktop printer then a slight shortage on any of the colours will make the colour come out wrong. There are a lot of factors that can influence even the most expensive printing equipment. These include altitude, humidity, the current heat of the printer, age of the printer, quality of ink, the paper that is being used, special coatings on the paper etc. Even viewing the same printed material in different lighting conditions may make the colour seem different.
Tips on getting the most accurate colour
Go to your nearest printer company and ask to see their Pantone colour matching system. Each colour in the Pantone chart has a matching number. Most design applications have the same Pantone charts built in so that colour matching is easy. Read up on Pantone at Wikipedia. Make sure that the file is converted to CMYK (If not designed in it originally) before sending it to print. Some printer companies might ask for colour separation prints which the leading design packages can produce. It is also important for the designer to choose the correct colour management profile in the design package.
Dec 05, 2009 | HP OfficeJet 6110 All-In-One InkJet...
Can't print photos with correct colours. Photos in .jpg format and I know colours on screen match colours when printed commercially. Printing from Zoom Browser or Canon Easy Photo gives much worse results...
First clean the print head and run the test print and then the alignment setup to make sure that the printer is clean and registers correctly. In the Printer Properties (Right click on the printer name via Control Panel - Printers) there is an option tab for Colour Management. Click this and select the source that you need to match the print output to. Also go through all the other tabs in Pinter - Properties as there are many setup options there to setup and tweak the colour balance and adding effects etc. This can be quite a lengthy process but well worth the effort. There is no shortcut to doing this but you will end up with a precisely calibrated custom printer setup that you can save and reuse at any time. I have these profiles defined for my printers for each media type and each ink supplier although I have minimised the number of profiles by now using 1 bulk ink supplier to get consistency between cartridge changes and CISS refills. Note that this may vary when you change print carts or change the media type and manufacturers.
Oct 07, 2009 | Canon PIXMA iX4000 InkJet Photo Printer
Printing too dark
Defective ink cartridge..most likely black
Mar 29, 2017 | HP Photosmart 3310 Printer
Black colour ?
Thats because it's using the other colours to mix what it thinks to be shades of grey. Due to the black ink being pigment based and the colours inks dye base, when printing onto glossy paper the machine will use the colour dye based inks to make up black.
If you were to print on plain paper, set to greyscale, then the machine will just use the black as the pigment ink sits onto of the plain paper and will not run should the paper get wet.  With glossy paper the ink has to be absorbed into the paper ad the Black pigment ink will not do this so the machine will use the coloured inks.
Sucks but true.
Aug 06, 2008 | Lexmark X3480 All-In-One Printer
Printing photos
its ok I solved it! I didn't realise that all the photo cartridge does is gloss over the colour picture produced by the colour cartridge. I simply had to replace the colour cartridge which had run out, so now its all working perfectly!!
Apr 08, 2008 | HP DeskJet F380 All-In-One Printer
Ink won't dry
Unless the problem coincides with a change in ink cartridge, my guess is an incompatibility between the ink and the paper. Could you have changed the paper you're printing on. If so, is the new paper of a different quality? If you're using coated (eg photo) paper, are you printing on the right side? Check the "paper quality" setting on the printer (or the software you're using to drive it) - it needs to match the specification of the stuff you're printing onto. Photo quality papers are capable of absorbing much more ink than plain paper (which is how you get the colour intensity). If the printer thinks it's using photo paper, it will throw out enough ink to get that colour build - leaving a sticky mess if what is really loaded is just plain paper. A.
Apr 28, 2007 | Canon i860 InkJet Photo Printer
Kodak EASYSHARE 5500 All-In-One InkJet Printer Logo
129 people viewed this question
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
