Question about Panasonic KX-FM181 Fax
Lan Card burnt
I have a Panasonic thermal fax machine. It is not working after an electric short circuit. A local technician says its Lan Card has burnt. Where I can get my machine reaired in Faridabad / Delhi and what will be approx. cost of repair.mkbhargav1@yahoo.com
Not worth repairing
Posted on May 28, 2009
Frigidaire electric dryer model gleq2152es1 lights wont turn on and wont do anything
Hi ana piedranayari05, this is AP! Thank you for your post
I understand you are having trouble with your Frigidaire electric dryer not turning on. Make sure the dryer is still plugged into the outlet, and plugged in correctly. Also check to see if the house fuse is blown or circuit breaker tripped? If so, Replace fuse or re-set circuit breaker. Check to make sure that electrical circuit is not overloaded and correct. The dryer must be on a circuit by itself. Overloaded circuits can damage the dryer and possibly cause damage to home. Have a licensed electrician check to make sure it is on a circuit by itself. Additionally, the thermal limiter could have tripped or possibly an internal problem with the dryer. A thermal limiter automatically turns off the motor in the unlikely event of an overheated situation. A service technician must replace the thermal limiter after correcting the fault. If you have check the plug, fuses, and circuit breaker and still no power I would recommend contacting a local technician to diagnose and service your electric dryer.
Jan 18, 2012 | Frigidaire GLEQ2152ES Electric Dryer
My Panasonic Fax machine KX FHD331 is not receiving faxes ( it is on automatic) however, it is saying "memory full" and I cannot print what is in memory.
Make sure there is no additional error messages on the screen - they usually show in a sequence one after another - maybe paper not loaded correctly,or machine is jammed or out of thermal film.
Oct 03, 2009 | Panasonic KX-FHD331 Plain Paper Thermal...
Paper rolling up with the thermal film
The best thing you can do, short of launching the thing into inter-galactic travel, is to clean all of the plastic parts of the machine with an anti-static cleaner. Particularly, the roller that feeds the paper and the carbon roll. Remove all paper and carbon film and unplug the machine. Clean inside the paper housing and the feed rollers before turning it back on. It sounds like a build up of static electricity, a common problem on such thermal based fax machines. Remember, the paper has the propensity to curl because it is on a roll, so any extra help it gets will send it curling like mad. Good Luck.
Jul 20, 2009 | Panasonic KX-FP141E Plain Paper Thermal...
Panasonic kx-fp155 not printing
problem is not clear.u change fax roll when it was finished.if fax was printing before ending roll .i think u have installed roll with wrong side .thermal roll only prints with one side which is coated .just see inside machine there will bi a paper for installing roll direction.if not just check thermal head .clean it check its supply.or just replace.it mian jee
Jan 13, 2009 | Panasonic KX-FP155 Plain Paper Thermal...
Panasonic KX-FM220 fax machine does not have a dial tone
is your line provider ok.connect your line to ordinary phone to check if there is really a dial tone from the line provider.if there is a dial tone please let the analog board be cheked by a technician near you
May 01, 2008 | Panasonic KX-FM220 Plain Paper Thermal Fax
Communication error # 43on panasonic kx-fhd331
problem with your machines ncu or mb unit.check with proper technician.
Mar 26, 2008 | Panasonic KX-FHD331 Plain Paper Thermal...
Panasonic KX-FPG376 Plain... Problem:
Thermal paper roll upside down. You can only print on 1 side of thermal paper. also could be the thermal head in which case not worth repairing. Lawrence
Mar 22, 2008 | Panasonic KX-FPG376 Plain Paper Thermal...
Panasonic KX-FHD331 Plain Paper Thermal transfer Fax
for printing of this machine ttr roll is use you check with another quality of that like canofax roll and cheak out for machine printing.
Mar 11, 2008 | Panasonic KX-FHD331 Plain Paper Thermal...
Indicating an error
EITHER THE NEW DRUM IS FAULTY, OR THERE IS SOME OTHER HARDWARE PROBLEM. CONTACT hemant1968@gmail.com for further solution HAPPY FAXING OMNIPRESENT
May 10, 2007 | Panasonic KX-FL511 Plain Paper Laser Fax
Panasonic KX-FM181 Fax Logo
49 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
CheckitRight
CheckitRight
Norman  J Weimar Jr
Norman J Weimar Jr
Mitch S
Mitch S
Level 1 Expert
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
