Question about Hammond SK1 Organ
Hammond SK1 patches corrupted
I think I had just pressed the drawbar parts 'upper and lower' as required to change organs to vox, Farfisa,etc. Then most user and preset patches became screwed up with identical DB settings or no sounds other than a bell or short piano strike. Volumes also messed up. I restored an earlier gbackup and it seemd ok at the moment. What do you think?
3 Suggested Answers
  • 5603 Answers
SOURCE: i have 2 digital pianos
Ooften there is a setting for the pitch. Set it to A at 440 Hz which is usual standard. HOWEVER make sure it is really a pitch difference as the ear can be fooled by the "hammond" type sounds.
Posted on Dec 29, 2010
  • 3113 Answers
SOURCE: Hammond sk1 foot switch is set to toggle Leslie effect between fast and slow. How do I change it to act as damper sustain pedal or other function such as glide?
Thre is a sustain pedal jack next to the foot switch jack. The pedals used are different. The foot switch is a latching switch, the sustain pedal is a momentary.
Posted on Dec 29, 2016
Need owners manual for Thomas Paramount deluxe model 586
Hi, after googling I fond there were some available on ebay. That is your best bet.
Oct 27, 2017 | Hammond XK1 Pro Drawbar Organ
Dec 29, 2016 | Hammond Music
Ebay wanted
I doubt you will find something like that on eBay...try the manufacture site
Feb 08, 2018 | Televison & Video
Load to default not working
Did you follow the instructions from the manual? If yes, at what point did this process fail?
Switch off the power of the XK-1.
2. Hold the [REC/JUMP] Button, and switch on the power.
3. Continue to hold down / Keep pressing the [REC/JUMP] Button until "Loading Default..."
appears on the Display.
4. After 5 seconds if everything is in order, PLAY Mode appears on the Display. (Completed)
Dec 20, 2013 | Hammond XK1 Pro Drawbar Organ
My m3 makes no sound starts and runs perfect tubes are all lit
Sometimes people are fooled because some tubes have TWO heaters in them and you have to check that BOTH are lit. Your first thing is to get a schematic. Try the "Captain Foldback" site for Hammond schematics. You can find it with Google.
Sep 09, 2011 | Hammond XK1 Pro Drawbar Organ
When I turn on my xk1, I get no sound, no response from any buttons, keys, drawbars or knobs. I have tried the factory reset and it doesn't work either. What else can I do before I return it to the...
Take it to the store and have them test it... don't be surprised if there is a simple thing that has been overlooked. If it doesn't worked there, it needs to go in for servicing so that is the logical course to follow anyway.
Aug 06, 2011 | Hammond XK1 Pro Drawbar Organ
I have a Hammond XK1, I plug it in and everything is fine. Once I turn on the recessed ceiling lights with the three rotrary dimmer switches, I get a loud scratchy/hummming line noise through the amp,that...
It is probably so kind of interference from the rotary switches. It is in the shielding of the Hammond organ. You might try some aluminum foil around the unit certain areas at a time which will give you an idea if it will help and what areas need to be shielded. If that does the trick you install the aluminum foil shield inside the chassis. Hope that helps. Let me know..
Jul 25, 2011 | Hammond XK1 Pro Drawbar Organ
I purchased a used Hammond Organ Aurora, Model 700, 710 C125 but the previous owner did not have the manual for it. I am looking for a manual so I know how and what to do to play it. I don't know what...
Try the organforum . com. There are a lot of Hammond people there. The model 700 is the base model and probably enough to get you started.
Also just get a organ music book as a lot of the vernacular is in those. Also check your library for organ books. OFTEN the user manuals aren't much use to learn the instrument.
Most organs will either have tabs or drawbars. These select the type of "voice" and often one selects more than one as a mix. Each keyboard is refered to as a "Manual". Most organs have foot pedals. Each of the manuals and the foot pedals will have a seperate set of tabs associated with them.
To get started, turn on the organ and press the expression pedal which controls the volume... experiment setting a few tabs or drawbars an play notes on the manuals. You will soon learn what controls what.
Note that some models of Hammond organs used rotating tone wheels and those require lubrication. Those that do, usually have a power switch labelled "start" and "Run". These organs are usually higher value and one should have them serviced before using.
Nov 23, 2010 | Music
Hammond SK1 Organ Logo
32 people viewed this question
Top Hammond Office Equipment & Supplies Experts
k24674
jasbo
jasbo
Are you a Hammond Office Equipment and Supply Expert? Answer questions, earn points and help others
