Question about Frigidaire PLEFMZ99EC Electric Kitchen Range
Cooktop Locked Up!!
I have a Frigidaire Convection Oven Model # PLEFMZ99ECK I noticed as I walked by one day that there was a red padlock on the display and on the displays above each burner knob has a (--) when it is usually blank. When I press and hold the lock button all it does is lock the oven door. And when I press it again it unlocks the oven and door. I have unplugged it and I have flipped the breaker and nothing works. Also, on the cooktop I have a warming element that does not have a digital display and it works. PLEASE HELP!
  • 5 Answers
Got the same problem.
Here's a work around: Turn breaker off, second person needs to hold the CANCLE/LOCK button (keep holding it!)
Turn breaker back on and keep holding the button, lock feature may turn on, red lock light stays on, KEEP HOLDING THE BUTTON. At the end you will get a F11 (shorted keypad) warning. It may take up to 20 seconds or more but in my case the red lock light goes off, the dashes disappear and everything is back to normal.
Now here are the bad news. This does not fix the problem (I think it's the EOC). Every time the power goes off the red lock light and dashes will come back. It also may require to people to fix this/work around... but, hey, it doesn't cost anything either...
Posted on Dec 10, 2009
Just press and hold the Clock button. Voila! Btw, that's how you got in that predicatment to start with - by overholding the Clock button. :)
Posted on Nov 04, 2014
  • 39 Answers
Your EOC is dead...It needs to be replaced
Posted on May 22, 2009
Error Code E0 39 after replacing induction Control module. Our Range is Frigidaire CPCS3085LF, apparently the module is not talking to the panel. is there a fix?
Execute following sequence to force cooktop reconfiguration (Be sure the good ESEC20 UIB is installed into the cooktop)
1-Put all rotary control to the first detent position clockwise (1 o'clock).
2-Put all rotary control to the first detent position counterclockwise (11 o'clock). The system should then reconfigure, showing walking dashes on the cooking zones displays.
3-Put all rotary controls to "Off" position. There should be no more error code and the cooktop is ready for operation.
Frigidaire Range Stove Oven Surface Element Board 318329620 Frigidaire Range Stove Oven Oven Control Board 318347100
Jun 12, 2016 | Frigidaire Kitchen Ranges
Frigidaire electric cooktop locked
I appreciate your post, friend!
I noticed your question is labeled under Frigidaire cooktop model, FEC30S7E. I have located the Use and Care Guide for your cooktop and I was unable to locate a lock feature. You could perform a reset on your appliance and you can do that by unplugging the power cord or flipping the circuit breaker off for ten minutes.
If that does not correct your issue could you please provide me with your model number? Usually you can locate the serial tag (which lists your model number) inside your burner box or on the outside of the appliance base. With that information I can look further into your model. I look forward to assisting you. -Matt
Oct 09, 2014 | Frigidaire 31 in. FEC30S7E Electric...
The door is locked and will not open display says door locked been that way 3 days
Press and hold the oven lock button for approximately three seconds to turn off the oven lock. The oven lock button has a symbol of a padlock on it. You will hear a beep when the oven lock is turned off. You can now open the oven door and operate the oven as normal
Mar 18, 2011 | Frigidaire 30" Self-Cleaning Drop-In...
My stovetop is locked out - there's a padlock icon on the display. I've fooled with it for an hour but can not get the lock out to turn off. Help!
Jan 26, 2010 - by frankegd - Well, after further investigation I found out that simply holding the "Oven light" button for some time will unlock (red padlock) the cooktop...
Apr 22, 2010 | Frigidaire FEF376 Electric Kitchen Range
Cooktop is locked out on digital kenmore unit, already tried cutting circuit breaker and waiting 5 minutes, that unlocked the oven but not the cooktop
Hi and welcome to FixYa. I am Kelly
I could be of much better help with a complete model number I.e. (example 110.XXXXX)
The wait is supposed to be 10 minutes. go back and turn off your breaker by "Physically" pushing it with conviction to the OFF position and wait 10 minutes.
If after 10 minutes the cooktop is STILL locked:
Push the touch pad that looks like a padlock for at least 5 seconds. The lock light should go out.
If it does not go out I will need your model number to go any further.
Thanks for using FixYa and I will be watching for your response.
Kelly
Feb 18, 2010 | Cooktops
MODEL NUMBER FEFL89CCB. THE OVEN WILL NOT HEAT I have tried it in all modes
Hello hriley2214,
I just want to clarify the problem before moving forward. The oven will not heat either in bake, broil, or convection, correct ?
How about the cooktop, does it function normally ? As does the clock/timer ?
Let me know and I can try and assist you further with that info.
Thank you,
macmarkus :)
Jan 05, 2010 | Frigidaire Kitchen Ranges
Frigidaire plef398ccc displayed 'er' now won't heat cooktop/oven
You could have a problem with the user interface board, which is #97A in the attaced breakdown, part #316225039500. Hope this helps.
Nov 16, 2009 | Frigidaire PLEF398C Kitchen Range
Padlock sybol when try to turn on hob
Press the 'Oven light' for about seven seconds...
Jan 12, 2009 | Bosch 32 in. PIE875T01E Electric Cooktop
My Electric Frigidaire Convection Oven just locked it's own door! I heard a continual beep..then "Err" "F9" flashed, then beeping stopped and the illuminated "padlock" symbol lit up and the door locked...
I have a similar problem with my electric Frigidaire convection oven, which flashes ERR F9 and beeps after finishing a cleaning cycle; if you haven't had to have it repaired professionally by now you might try cutting the circuit breaker to the oven for a few seconds and then turning it back on. My oven takes a few minutes to reset, after the circuit is turned back on, but then will unlock the door and let me reset the clock and continue cooking as normal. . . until the next time I set the clean cycle.
FW
Seattle WA
Dec 15, 2008 | Frigidaire 30" Self-Cleaning Slide-In...
Our cooktop will not turn on!!
Aug 22, 2008 | Kitchen Ranges
Frigidaire PLEFMZ99EC Electric Kitchen Range Logo
643 people viewed this question
Top Frigidaire Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Mike Carew
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
