Question about CDN DTP482 Programmable Probe Thermometer/Timer
Why is my unit flashing HH?
Flashing HH will not show temperature
Tip
Show AM / PM Symbols in System Tray Clock in Windows 7
1. Type intl.cpl in RUN or start menu search box and press Enter. It'll open Regional and Language Options window.
2. Now click on "Addition Settings" button.
3. Go to "Time" tab and you'll see the value of "Long time" will be set to HH:mm:ss. Just add tt at last of the value, i.e. change the value to HH:mm:ss tt
4. If you want to show the time in 12 hour format (06:30 instead of 18:30), then change the value to hh:mm:ss tt
5. That's it. Click on Apply button and you'll get the AM / PM symbols back in system tray clock.
on Aug 10, 2011 | Computers & Internet
We want to just make dough
According to the manual, page 23, "H:HH" means "Temperature in breadmaker is too high". The solution is to "Press the Stop button. Remove the baking pan, leave lid open and allow to cool. When cool, put the baking pan back in, set program and start the program again."
If you need a manual, you can download one here:
http://www.morphyrichards.co.uk/Pdf/IB48286.pdf
Apr 19, 2014 | Morphy Richards 48268 Bread Machine
Display panel shows 6522 Rev HH
check wiring to controller either wires touching at plugs or wires cut
Sep 11, 2012 | Jandy Aqualink Rs4 One Touch Control...
Flashing HH
HH is over heat.
If you have a manual Hi Limit Sensor try reset the sensor with the push button on the heater.
If you have an electric system unplug then reattach the hi limit sensor on the board.
If neither works it's likely the hi limit sensor has failed or another overheat event has damaged the spa.
Jul 18, 2012 | Balboa Instruments Pool & Spa
HH error code? on magic chef mcbc580dbt
I, too, have just seen (late June 2013) the "HH" code on my Magic Chef wine cooler (and it is running too cold and I can't reset the temperature). Have you found a solution since your posting of about 1 year ago?
Jun 27, 2012 | Magic Chef MCWC30MCG Compact Wine Cooler
I have an Acurite 822-RX thermometer that shows HH as the outdoor temp, even after replacing the batteries in both the base and remote units. How can it be fixed or reset?
HH means it is showing the high temperature you (most likely accidentally) set with the MAX MIN / + button, which is easy to do when setting the clock. Just press that button again until the reading appears.
Jan 15, 2011 | Acu-Rite Acurite Wireless Weather...
What does hh.h mean on display
I'm assuming it just stands for "High Humidity". It wasn't raining at the time, but it sure had been earlier, so perhaps if it's over some number (like 90%), it just says "HH".
Nov 01, 2010 | Acu-Rite AcuRite 00592A2 Wireless Humidity...
I plug in reddy heater and flip the switch on and nothing happens
The HH indicates that the control believes that the temperature is over 99. This happens when a) it is over 99 degrees (not likely or you would not be using the heater), or b) the thermistor is not plugged in or bad.
a) unplug your heater
b) remove the control cover (two screws where the display and knob are)
c) find the thin black wires with a green connector on the end. The other end of the wire are attached to the thermistor which looks like a balistic missile.
d) plug the green connector onto the white two pin connector on the circuit board. This is the only place that it will fit.
That should solve the problem.
Dec 20, 2008 | Reddy Heater-170,000 BTU Kerosene Deluxe
Hh TTY support
You should let the phone ring 10 or more times to allow the Deaf or HH person enough time to see the flashing light and respond to it.
Aug 27, 2008 | Williams Sound PKT D1 H21 Pocketalker...
CDN DTP482 Programmable Probe Thermometer/Timer Logo
187 people viewed this question
Top CDN Home Experts
Donni Steen
Tom Chichester
Are you a CDN Home Expert? Answer questions, earn points and help others
