Question about Acer V193w LCD Monitor
Black screen when starting a game
My ACER V193w lcd monitor turns black when i start a game. otherwise it works ok.
  • otokooya May 20, 2009
    the thing is...it worked on my older monitor when i plugged it in...
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Acer Master
  • 848 Answers
Black screen when starting a game? This trouble maybe power supply or inverter boards is defective.
first you can test the voltage of the multr,and then check which part is defective.From Wisiny.com can find those parts
if you have any question,please let us know email:service@wisiny.com.thanks,we sincerely hope we can help you!
you can also check this boards whether suit you:
8921EQIX 715G3350 1 2 Acer ADTV8921EQIX Power Supply Backlight Inverter
Posted on Dec 12, 2014
  • 749 Answers
Check for the video card speed requirement of your game. it might be too high for your video cards, a 256MB video card could not display a game with 512MB video card speed requirement.
Posted on May 20, 2009
My acer monitor displays the acer background, makes a noise like a buzzing sound and goes black, and then after all my settings and background picture and information are complete and up, the monitar...
It sounds like a backlight or inverter problem. You can verify this by using a bright light to shine on the screen surface. If you can see the picture (but it will be very dark) that means that the backlight which illuminates the screen from behind. You would have to replace the inverter to test it, but there is good news: These are pretty difficult to find parts for, and not an easy repair for an amateur; acer products usually have a 3 year warranty on the backlight/inverter system, so I would start there.
May 25, 2011 | Acer V193W 19 inch LCD Monitor
V193W 19" acer monitor is connected to computer
Hi, Try turning off your system, activate your monitor and then activate your computer. Check the troubleshooting section of the manual received with the monitor and if that still does not help, let me know.
Regards, Icom1
Apr 01, 2011 | Acer V193w LCD Monitor
I have v193w acer desktop lcd screen suddenly it went black the blue light (( which mean that it's on and every thing works fine )) is on all the time but nothing appeared like the the screen is completly...
Ive had that problem recent, same monitor. Same months to be exact, though started around October 2010 then got worse. Do not send it back to Acer, I did and the cost was 20 bucks to ship to them and all I got was a note and monitor back saying they tested and then did Extended testing and found nothing. Not even had it for 1 year or 2 years to say, 3 year warranty. Just going to buy a new one and perhaps a LED from ASUS, the V stands for Value on Acer website, guess I got what I payed for. Think it was $166 I payed for this thing. It is shame, as its nice monitor but I cannot have it not trusty like this, cannot even play some games without it going off like this. Worst if I put the monitor in Graphics or Movie mode makes it worse it seems.
Nov 04, 2010 | Acer V193w LCD Monitor
I have a Acer V193W Computer Monitor. When I turn it on I get a white screen then it goes black for like two seconds then comes back on with a white screen and stays on that way. What could the problem be?
The LCD panel is not getting the 5/12vdc from the logic board or the fuse on T-CON board is blown or bad T-CON board, it can also be due to bad 5VDC power supply caps in the power supply and in the logic board.
Please read my guide and look at the pictures at my photobucket.
Basic LCD monitor troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
Failed TV, Monitors, Caps : http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Capacitor kits: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Please post back what you find.
Nov 03, 2010 | Acer V193w LCD Monitor
The screen has go black. Every once in a while the screen goes from black to saying Acer. Everything seems to plugged in just fine. The problem even starts right as you turn the computer on. Does this mean...
It could also be your computer.
Connect the monitor to another computer and see if the problem disappears. If there is not a problem, then probably the VGA card of the computer is defect.
Another thing to try before sending anything for repair, is changing the resolution and/or refresh rate of the computer. Could be lower or higher.
Sep 17, 2010 | Acer V193w LCD Monitor
My acer V193w is putting itself on black after about 1 hour of computing.when I set it off for about 15 minutes it is working fine for another 15 minuten and then goes black again. i think it is...
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, blown fuses, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed ACER monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://www.badcaps.net
May 21, 2010 | Acer V193w LCD Monitor
Acer v193w monitor screen is black, and an amber light is flashing. How do is fix it?
The blinking Amber light can mean two things, one is that the monitor is not getting the video signal from your PC, or it can be problem in the monitor power supply due to bad caps. Please try it on another PC first before opening up the monitor. If is it the monitor then read below so you can make up your mind if you want to DIY or not.
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Apr 14, 2010 | Acer V193w LCD Monitor
Won't come on
Try starting it after unplugging the devices Viz. Printer, Modem, ADSL, then during bootup Press F8 key to start it in Safe Mode..
Once you get in.. Run a checkdisk and diskcleanup.. and run Virus Scan etc. to get back in Normal mode.
Thanks
Scott
Apr 28, 2009 | Acer V193w LCD Monitor
Acer V193w LCD Monitor Logo
179 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
