Question about Bower Cameras
Droped my camera
It hit the floor and broke where the mount is..I have this unit Bower SFD14N Flash for a Sony
5 Suggested Answers
  • 25 Answers
SOURCE: I have 2 Nikon D80's and a Bower 724AF speedflash
Set the flash unit to full manual.
Posted on Aug 13, 2009
  • 65 Answers
SOURCE: Sunpak 383 problem
Try to trigger it by shorting Center of shoe mount and the side terminal with a small wire.If it is firing the flash is ok.
If not there is open connection in the sync jack ,due to repeated inserting of sync chord.The springy part inside is not going back to its normal position.
You can fix it your self by opening it(adapter only)
.If you are new to this take a photo of the wiring immediately after opening the shoe adapter to see the position if any wire breaks later on.
Do not give up .383 is great flash
Posted on Mar 05, 2010
  • 17 Answers
SOURCE: Dropped Flash
call olympus spares dept. You need the exact part number, which can sometimes be hard to get, sometimes they will fax the diagram so you can id the part. The spares dept tel # is hard to find. The links on olympus website will not get you there and the consumer hotline will not give the spares dept #. They now try to keep consumers from fixing stuff themselves and a lot of spares they no longer will sell to you. They used to be one of the best and very helpful. I managed to get a spare battery cover after a lot of hassle a while back, but they said they would not supply most parts for these newer flashes.
Posted on Jul 23, 2010
SOURCE: Hot shoe plastic section broke on flash unit
I managed it by buying a broken (non-working) F32X from an auction service for something like 5 bucks. I just made sure (by looking at the photos) that the hotshoe was intact.
Here's how to disassemble and replace foot (I got to this by trial and luckily no error ^^).
  1. Unscrew 2 small screws located under the battery flip cover.
  2. Put the lamp (moving part) in the upright position.
  3. Unscrew 1 small screw above the infared sensor (below the main lamp part which you moved to the upright position).
  4. Remove the cover of the infared sensor by gently pulling forward.
  5. On two sides of the infared sensor there are two small clips which hold the 2 casing pieces together. Pull them away from the casing just a tiny bit and use something to keep them in this position (I used 2 small nails). Then pull the pieces apart gently.
  6. Just behind the hotshoe casing you can see a small plastic inset -- place a screwdriver sideways between this inset and the hotshoe to help you separate the two casing parts. Be careful when doing that, don't use too much force, wiggle the casing instead to make this easier (this is the most tricky part).
  7. When the electronics is exposed, there is a single screw in the middle of the motherboard. Remove the screw and gently pull the motherboard away from the casing. You do not have to pull it all the way or disconnect any cables, you just need to make sure the bottom battery connectors are pulled out of the casing just a little, because then under the two middle battery connectors (looking from the top, as if you were putting the batteries in) you can see two screws!
  8. Unscrew those two screws, and the hotshoe will come apart. Pull it out gently and remove a single electrical connector that connects it to the flash.
Do this in case of your working lamp (with a broken hotshoe) and your replacement lamp (with a good hotshoe), and just move the good hotshoe to your working lamp.
Took me about an hour to do this (most time was spent on trying to figure out how to disassemble the lamp), and the lamp works perfectly.
Warning: better test disassembly on the replacement lamp, since even if you break it, all you need it for is the hotshoe, so you can practice on it. Only after you learn how to disassemble the F32X do this on your working lamp.
Hope this helps!
-- Tomasz Andrzej Nidecki (tonid)
Posted on Feb 15, 2011
Bower digital flash sfd290 cord won't connect to my canon rebel eos t3i
You need a PC sync socket on the camera. PC stands for Proctor Compur and this meaning of PC goes way back to the days of cameras with bellows and the photographer under a black blanket.
You can buy an adapter:
http://www.bhphotovideo.com/c/search?Ns=p_PRICE_2%7c0&c...
But from reading reviews, you may not be happy with this flash unless you use your camera in manual mode. I hate when people answer questions by suggesting the poster buy something else, so notice I did answer the question first by mentioning the adapter.
For a less expensive flash option that will work right on your camera and be truly automatic, consider a used Canon 420EX from Ebay for about $100.
If you intend to go into photography in a creative way, (more than point and shoot) sell the Rebel and get a used Canon 40D or 50D ($200 to $300) so you don't come up short on features like the missing PC sync port and other things you won't know about until you need them. With the Rebel you'll keep finding other limitations. With the used cameras I mentioned, they'll work great, have lots of features and control, and won't depreciate much (because they already have) so you can upgrade every year or two by adding just $100 to the sell value. That's how I went from a 10D camera up to a 1D pro camera over a five year period.
Finally here is a "positive" review I found of the Bower flash, notice the caveats:
"Had this flash for a Sony and now for my Nikon D300. I also have a SB-600 flash unit which is of course way better, but also way expensive - I guess nobody here should expect the same quality for 1/4 of the price.
The build is overall cheap but okay for the price, it will last a while when you take care of it. The major downside is that it's not really a TTL flash. The title says something about "automatic", I'm really unsure what they mean with that. Fact is, it produces a strong flash, you can swivel the head (even at the wall behind you) but it doesn't communicate with the camera. You can still use it on-camera though, but it's more like a manual flash gun, so operating the camera in auto-mode will most likely produce an overexposed photo. If you're unsure if you should buy it... it's an okay budget flash which will give you more options than the popup-flash, but if you're more like the I-use-my-SLR-only-in-auto-mode guy than better invest $100+ in a TTL flash which will get more information from and to the camera than: Fire flash now!
But here's the deal: Buy a remote FM-trigger (I use the "CowboyStudio NPT-04 4 Channel Wireless Hot Shoe Flash Trigger Receiver for Canon EOS, Nikon, Olympus & Pentax Flashes Other products by cowboystudio") and use this flash as an off-camera remote unit. Again, manual mode operation of your camera is recommended, but you can achieve great results with this off-camera set for $70 (flash + trigger). Combine it with a lighting stand, camera bracket and umbrella, and you have a portable studio lighting set for about $100-$130. This flash does even fit better on the remote trigger than my SB-600 because it has a screw-ring (not shown in the product picture) to tighten it to the flash-shoe-mount."
Mar 27, 2014 | Bower Digital Autofocus Zoom External...
The ringflash won't fire on this camera.
If the menu item is gray it means that you are in a mode that does not allow you control of your flash. You are likely in an auto mode. Change the mode to Manual, Shutter priority, Aperture priority, or Program.
Diane
NYC Photo Safari
Mar 12, 2014 | Bower SFD14S Sony Ringlight Flash
I have a sony a200, i want to fit an external flash for that.
The camera already has a hot shoe that will accommodate a Sony flash unit or a third-party flash unit designed for Sony cameras. You don't need anything else (other than the camera and the flash unit, of course).
Mar 01, 2012 | Sony Alpha DSLR-A200 Digital Camera
Aug 12, 2009 | Nikon Cameras
Washed out pictures using a Bower 724 AFPX flash
This is probably not the camera settings. Pentax k200D wilt only give auto-flash with just three of their own units. Sounds like you have the Bower set on Auto. Set the flash to Manual, and adjust exposure on the aperture setting with the body set to manual as well.
Note that several people have reported problems with Bower units on digital cameras (and not just on Pentax)
Mar 22, 2009 | Pentax K200D 10 Megapixel Digital SLR...
Nikon D80 using Bower AF 724AFN
I also purchased a Bower 724AFN to use with my D80, and experience the same problems. Received confirmation from Nikon that this flash unit is not compatible with the camera. I then purchased an SB-600 flash, and haven't looked back. It's worth the extra money for this high quality unit; fully compatible, and compliments the TTL features of the D80. I'll never deviate from original Nikon accessories again.
May 22, 2008 | Bower (724AFN) for Nikon Flash
Added flash mount
LOLEE, I'M NOT FAMILIAR WITH THAT FLASH, BUT I HAVE SOME GENERAL INFO THAT MIGHT HELP. FIRST, IS THIS FLASH USING THE CAMERA " HOT SHOE " MOUNT? IF IT IS, ARE YOU SURE THAT THE FLASH IS FULLY INSERTED IN THE HOT SHOE? NEXT, IS THIS FLASH COMPATIBLE WITH YOUR CAMERA? YOU SEE, SOMEHOW THE CAMERA IS NOT GETTING THE INFO THAT THE FLASH IS CONNECTED. I WOULD CHECK ALL CONNECTIONS TO BE SURE THEY ARE TIGHT. HOPE THIS GIVES YOU SOME IDEAS TO WORK ON. IF YOU NEED MORE HELP, JUST REPLY.
ARCLIGHT1217
May 11, 2008 | Minolta Maxxum 50 QD 35mm SLR Camera
Flash wont flash!
first you check the inside flash circuit, any copanent may be burntout or drysolder, check properly, one mor inside the flasah capacitor very high voltage becarefully..
Oct 04, 2007 | Bower (724AFM) for Minolta Maxxum, Dimage...
Cameras Logo
37 people viewed this question
Top Bower Cameras Experts
Doberman
Jerry Greenberg
Jerry Greenberg
Are you a Bower Camera Expert? Answer questions, earn points and help others
