Question about Philips 190B6CB/27 19" LCD
Menu screen tv settings menu stays on the screen. It will not let youext the menu screen.
    Champion:
  • 200 Answers
Did you press the menu button again?
Posted on Jan 01, 2014
I have an RCA projection TV, model D52W19B. The TV powers on ok, stays on, and audio is normal. I don't get a picture. If I press the menu button, the menu will appear on the screen normally.
my guess is you either have a satellite or cable box try unplugging the system cable or satellite and set for 5 minutes and then plug them back and and restart the unit up and see if it comes back the gemstar module would some times lock up causing this problem . and please let me know if that get's you working or if there is more trouble shooting to be done
Nov 03, 2014 | RCA Televison & Video
Problem with setting up PC mode on my LE40S7 LCD TV
hi it shouldnt matter to much its just a guide line just might mean you get a less clearer picture if you was watching say a dvd but your telly should still let you acess this menu have you tried acessing the menu without the laptop plugged into it let me know ok
Feb 11, 2008 | LG 42LC2D 42 in. LCD HDTV
I HAVE 60 ' INCH FATBACK WHILE THE TV TURNS ON THE SCREEN THAT TELLS YOU , SETTINGS , STAYS ON UNTIL IT WARMS UP ....YOU GO TO YOUR REMOTE AND HIT MENU , IT DISAPEARS....BUT ONLY WHILE ITS WARM .
Got a heat related issue likely on main signal board---might be able to localize it (suspect a flat pack chip) with a hair dryer to heat the board just a bit.
Nov 05, 2012 | Televison & Video
Main setup menu froze on screen unable to remove,also TV just stays on have to unplug from outlet. Press Rest button, and home button on remote nothing happens. Do have background channel TV from cox cable...
If the model number posted here is correct (vs-70707) this is a VZ8 Chassis made around 2000 and should NOT have a reset button on the front.
Please confirm actual model number.
Note: almost all Mitsubishi sets have a hidden menu (two or more) and one allows with the Mitsubishi remote to enter for example the OPTION menu and there you will be able to do a HARD RESET on the set which sets ALL settings back to default.
sj
Oct 20, 2011 | Mitsubishi VS-70707 70" Rear Projection...
Lcd screen is on, but screen stays black? what can that be?
Make sure the tv is on the correct input (Input 1 may be dvd player, but if you have it set to a blank input nothing will show up)
Does the TV's menu work?
Feb 28, 2011 | Philips 32PFL3403D/27 32 in. LCD TV
TV stays at the "Please Wait" screen
There is something in the system control not being satified. Probably needs a main PCB.
Oct 13, 2009 | Sharp LC-26D40U 26 in. LCD HDTV
Blue menu screen stays on
Hi! the blue menu screen can be turned off by pressing the same button that caused it to appear. In most cases pressing the "Menu" button on the remote or TV-control will make the blue menu screen disappear..
I hope this helps!
Mar 10, 2009 | Zenith C27A24T 27" TV
Set up menu
Check to see if something was spilled on the screen of this set
or using too much cleaning solution.
As it will run down on to the tac switches and create problems with the cpu.
Thanks guy
May 24, 2008 | Sony FD Trinitron WEGA KV-27FS100 27" TV
Main Menu
power supply regulator and horizontal output transistor.
Jan 17, 2008 | JVC AV-27230 27" TV
RCA 52" projection Model no. D52W19 produced 9/04
make sure you do not have the automatic screen mode set to wide screen on tv menu .Also if you have cable box set to wide mode only then the tv will only display wide mode.
Dec 05, 2007 | RCA P52937 52" Rear Projection Television
Philips 190B6CB/27 19" LCD Logo
35 people viewed this question
Top Philips Computers & Internet Experts
micky dee
Are you a Philips Computer and Internet Expert? Answer questions, earn points and help others
