Question about ASUS Computers & Internet
P5n-e sli bad capacitors
2 bad caps at top of board
map9966
  • 2351 Answers
SOURCE: Asus P5N-E SLI Mobo will not boot or post.
Hi bart, please re-check you're memory. See page 1-17 in you're user manual. (Read everything)!
You're Asus board can not use 184-pin DDR DIMM's.
Also check the QVL list for supported memory page's 1-18 & 1-19.
I did not see Corsair on either page.
You're board can only use 240-pin DDR2 memory. Please read the "Notes" at the top of page 1-18.
If everything (Regarding memory) is within the Asus specifications than clear the cmos/bios & re-boot again. If you're system still does not boot than remove one DIMM & try again.
Asus warrants their boards for three years. Call Asus tech at
1-812-282-2787 EST, IL 8:00AM to 5:00PM. The call is on you but the service is free. It's worth every dime.
Good Luck & Kind Regards.
Would you be kind enough to let me know what Asus suggested? (If it comes to that).
Mike
Posted on May 15, 2008
SOURCE: ASUS P5N-E SLI
Try RAM with a different speed. My 800 mhz RAM didn't work until I installed 533 mhz RAM and adjusted to 800 mhz in BIOS. Newly built PC, default must be set as 533 mhz because I reset the CMOS and still couldn't POST to BIOS. Only taking out all RAM gave me any sort of audible error code. Luckily I found some 533 RAM before I RMA'd the board.
Posted on Aug 06, 2008
bootz84
  • 197 Answers
SOURCE: P5N-E SLI MotherBoard core2 Quad Q6600 2, 2gigs
If all power cables are connected properly to the board, and also all devices, I would assume it's a faulty board.
Posted on May 04, 2009
map9966
  • 2351 Answers
SOURCE: i have a p5n sli motherboard which refuses to boot
Go to page 2-30 section 2.4.5 in your manual.
If you are using the onboard graphics for your display set this to [PCI]. If you are using the PCI-E video card, set the bios to [PCI-E]. Save & exit the bios. You should have display after the system re-boots. If you still have no display & you are 100% sure your monitor functions than the video controller on the board is bad. This can not be repaired.
Mike
Posted on Aug 13, 2009
SOURCE: Can a p5n-e sli handle a single 9800gtx? I
Yes as long as the 9800gtx is PCI Express x16. I am assuming the p5n-e is the Asus MB. Since I couldn't find any other Manufacturer using that MB#
Posted on Sep 20, 2009
Testimonial: "Thanks for the info. All pcie 2.0 are *supposed* to be backwards compatible with x16. We shall see."
Hi. My computer with an ASUS P5N-E SLI motherboard won't bootup and responds with one continuous "beep". Help?
you can check your video card or memory card if it is placed correctly. or else, try to remove the cards and clean the pins with an eraser so that corrosion will be removed. then gently place the cards into the slots and try to press them quite hard for them to establish good contact with the boards slot. start your pc and see what happens.
Nov 15, 2010 | ASUS P5N-E SLI Motherboard
Drivers for p5n-e sli motherboard
You can download the drivers here:
http://support.asus.com/download/download.aspx?SLanguage=en-us
In the upper left hand corner of the screen, type in the model number of the board (P5N-E SLI) and use the drop down to select a category (probably "All"). Good luck.
Oct 17, 2010 | ASUS P5N-E SLI Motherboard
I need a installation manual
Hi there Samurai2,
Please click here to go to the official download site of Asus for the P5N-E SLI model.
http://usa.asus.com/product.aspx?P_ID=KyHOsOKWujC2QguJ&content=download
From the site, select your OS and it will show you the list of download resources for the board. Click to expand the MANUAL and look for the English version.
Hope this helps.
Mar 05, 2010 | ASUS P5N-E SLI Motherboard
I lose my mother board driver cd
Access the manufacturer's web-site:
In the top-left corner, put 'P5N-E' into the search-box, and do the search.
In the next window, click on 'P5N-E SLI'.
Select "Windows XP".
Select the driver(s) that you want to download.
Nov 09, 2009 | ASUS P5N-E SLI Motherboard
Sep 19, 2009 | ASUS P5N-E SLI Motherboard
I have a p5n sli motherboard which refuses to boot
Mike
Jul 31, 2009 | ASUS P5N-E SLI BULK PACK of 10, Quad,775...
P5N-SLI
HI stukove2000,
What is the 5200 stand for?
Here is Asus approved CPU list link for the P5N-E SLI MB:
http://support.asus.com/cpusupport/cpusupport.aspx?SLanguage=en-us&model=P5N-E%20SLI
The Corsair TWIN2X2048-6400 5-5-5-15, should work just fine on the Asus MB.
Here is an expanded approved Qualified Venders List from Asus.
http://www.asus.com/999/download/products/1474/1474_10.pdf
You can also see a smaller QVL list in the manual on page 1-18 & 1-19.
The QVL insures total compatibility with the motherboard.
The NVIDIA GeForce 9600 GT will run just fine on the Asus MB. Just make sure your power supply is no less than 500W. A 600W or 650W is preferred.
http://www.google.com/products/catalog?hl=en&q=600W+power+supply&um=1&ie=UTF-8&cid=1841721063482288764&sa=X&oi=product_catalog_result&resnum=1&ct=result#ps-tech-specs
Here is a write up of the Asus mother board: http://www.techspot.com/review/43-asus-p5n-e-sli/
Asus FAQ's of the P5N-E SLI. Good place to check questions about the board.
http://support.asus.com/faq/faq.aspx?model=P5N-E%20SLI&SLanguage=en-us
Good luck stukove2000!
Any more questions?
Mike
Oct 08, 2008 | ASUS P5N-E SLI Motherboard
ASUS P5N-E SLI
Jul 06, 2008 | ASUS P5N-E SLI Motherboard
Computers & Internet Logo
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
