Question about Samsung HL-R5656W 56" DLP HDTV
Tv makes buzzing sound when you first turn on and keeps buzzing even when picture comes on after a few min. it stops and will not do again until next day turning on will buzz again but turn it off a
Seems to be when first turn on
  • 1694 Answers
SOURCE: No picture or sound after replacing lamp
Possible bad color wheel...
Pull the lamp out & look inside where the lamp sends the light-
does the color wheel look defective? If so,replace it.
Or, the lamp ballast may be bad.After that,usually replace
complete engine.
Posted on Oct 19, 2007
  • 49 Answers
SOURCE: Samsung DLP HL-R4266W..no sound or picture. TV is completely dead
Assuming the noise is a high-pitched whine, then yes, it is the color wheel.  If the color wheel goes out, the TV will turn on for a while, then turn off when it can't establish color wheel sync.  The color wheel has to be in sync with the mirrors on the DLP, so if sync can't be established, the TV turns off.
You can order a new color wheel from Sears or partstore.com (among other places) and replace it yourself, if you are so inclined.
Posted on Jan 24, 2009
  • 98 Answers
SOURCE: Repetitive Buzz
Need to check the cooling fan.
-- open the back cover & unplugg two of cooling fan socket(black & red wires or yellow & red wires)
If the noise still remaining, need to exchange the color wheel.
Posted on Feb 11, 2009
  • 336 Answers
SOURCE: Constant buzzing even when muted
Hi,It sounds like you might be experimenting a color wheel problem.The color wheel is a rotating disc that has a gamma of colors it spins at high rpms.The light of the lamp goes through it to create the colors on your tv.When it starts to go bad you will get color distortion ,black and white picture and sometimes you will hear humming noises.Your part # is BP96-00674A you can find it here: http://www.discount-merchant.com/product-p/samsung-bp96-00674a-cw-enc.htm?1=1&CartID=0?Click=48173 and here's how to replace it: http://www.fixyourdlp.com/guides/samsung/bp96-01579a.php Have a blessed one and go girl power!
Posted on Apr 27, 2010
  • 25 Answers
SOURCE: My 56
Its your colorwheel,don't get one from a guy on Ebay for $118.00 his are defected ,try partstore.com.
PS(Please rate my service ,Thanx!)
Posted on May 28, 2010
Testimonial: "Thank you!"
Vizio has sound but no picture, 50 inch
I have the P50HDTV20A. When I turn mine on I get sound but no picture but if I leave it on for about 15-20 mins and then turn off then back on it will have picture and sound. It seems as though as something has to warm up so the picture will come on.
Mar 27, 2012 | Vizio P50HDTV10A 50 in. Plasma HDTV
The tv made poping sound & it lost the picture but the sound was ok, their is buzzing sound coming from inside the tv, after about a min. the set turn off & red light stays on. reset tv, same...
This model is prone to a lot of problems to the point where a year or so ago they offered a chassis replacement on an exchange basis.
I would with rear cover removed try to localize first where the sound or buzz is coming from: The ballast? the Light engine? The power supply?
I can help but as I said this model has a LOT of chronic problems.
Steve
Nov 01, 2011 | Mitsubishi WD-52525 52" Rear Projection...
I'm experiencing a loud buzzing (fan?) sound that just started recently while watching my HLP5674W. The picture is fine, but the sound of what may be a fan or something like that is very loud and will...
Loud sound would be coming from defective color wheel that is mounted i light engine, next to lamp housing. Replacement of color wheel is required expertise/ experience and professional will do that for you in correct and in safe manner.
Contact local tv repair shop to get color wheel replaced in tv.
Thanks.
Oct 19, 2010 | Samsung HLP5674W 56" Rear Projection...
My tv screen keeps flickering on and off
  1. Need Model # of set and the brand so I know if its a plasma, LCD, or CRT set keep me posted
Aug 23, 2009 | Televison & Video
NO PICTURE, NO SOUND On My Plasma TV.
Should have been 3300 UF 10V caps that were bad? Shouls have been replaced with 3300UF 18V. 50V is huge. If it was replaced with a 50 the polarity may be wrong or the cap it too big to be seated property. Sometimes the caps just dry out and even a normal looking one will be the culprit of no OSD. Are you getting an LED fault code blinking? That should be a red led. Do you hear the relay clicking.? When you replaced the caps did you charge them? Just plugging in the set without trying to power it on for about 20-30 mins. I may be able to help you
gysgt2u1@yahoo
Mar 05, 2009 | Philips 50MF231D 50 in. Plasma Television
Starview 4 not working
reset to factory default then do a rescan that will fix it
Dec 21, 2008 | StarTech.com StarView SV211K 2-port KVM...
After few minutes I have disturbance in picture on SM T200
i have almost the same problem and can't find a solution... hopefully the guy who made my computer know whats wrong with it...
my samsung syncmaster is also connected to the DVi port(digital)
and it's sometimes working for a day and other times for a minute of 5.
and now i get it always in games what i get is:
-screen go black and in the top left corner yuo see analog(VGA port)and then digital(DVI) again.
and this will continue for at least 5 min sometime it stops after that sometimes never and i need to reboot(1of 5 times that work sadly)
-i get a buzz sound while he is doing that.
-sometime i get a green flash in the shape of what i was doing and then he change again.
can anyone help me/us?
Dec 20, 2008 | Samsung SyncMaster T200 LCD Monitor
Sony Bravia KDL 52 keeps turning itself OFF
i had prob where my sony would switch off for a few secs thenh come back on . The solution was in menu / tv settings / sleep timer . Go into that and make sure its set to off. there are opions for off , 5 min 20 min 30 min etc... mine was set to nothing just blank.
Apr 06, 2008 | Sony BRAVIA KDL-52W3000 52 in. LCD...
Buzzing after 1 hour
Is the buzzing coming from the back of the TV, staying loud even when the volume is turned all the way down, or is it coming from the speakers?
Sep 04, 2007 | Mitsubishi CK-35306* TV
Samsung HL-R5656W 56" DLP HDTV Logo
24 people viewed this question
Jerry Greenberg
Jerry Greenberg
