Question about Home
I need to replace or paint whirlpool jets on an aqua glass tub...20 years old
I have a 20 year old aqua glass whirlpool tub that needs the jets replaced or painted...
PartsCenter
  • 125 Answers
SOURCE: power switch for whirlpool tub
the easiest thing (maybe) is to install an air switch kit on the side of your tub. Here is a link to the part. Basically you install an air button on the side of the tub, install the air tubing from the nipple on the underside of the air button to the nipple on the box that plugs into an outlet under the tub. The pump plugs into that same box and the air tubing from the air button pushing onto the nipple on the box. When you push the button on the tub it will turn the pump on/off. Air Switch Kit
Posted on Feb 24, 2009
  • 74 Answers
SOURCE: How to Change White Water Whirlpool Tub Jet Hardware
First step is to remove the old hardware so you have something to compare it to. THere are two types/sizes of tub faucets on the market for deck mounted applications. If yours is mounted on the tub deck then it is a deck mounted application.
The faucet spread (distance between the threaded nipples on the bottom of the faucet) is going to be something close to 8" or it will be of variable distance. If the two handles and the spout are connected via hose then they are of variable length.
Bring the old faucet into the hardware store and compare it so you know you are getting the correct one. It is not hard but also not fun to have to adjust the holes in the tub deck to accommodate a different size.
AS for the suction.....I am assuming that you are referring to the inlet part o the pumping system and all of the equipment behind the tub. I always recommend that you use parts from the same manufacturer. It is extremely helpful to call them with all of the numbers you have to get a list of acceptable replacement parts.
Hope this helps.
Posted on Apr 27, 2009
  • 123 Answers
SOURCE: aqua glass whirlpool tub leaks. looking for
To my knowledge there are no closure caps for your tub; you can however purchase new jets with new seals if the tub is leaking through the jets.
Posted on Sep 01, 2009
slick fixer
  • 7 Answers
SOURCE: I have an aqualux whirlpool tub w/ cracked jet housing
yes i can do it call me 301 659 9968 rick
Posted on Oct 31, 2009
  • 10865 Answers
SOURCE: aqua glass jetted tub quit working
Hello. There are two reset buttons in the mechanical space or your tub. You should be able to access that area from the front by removing a few screws. it is not uncommon to have to push those reset buttons after a power outage. If you do need a repair I recommend that you call a store that sells hot tubs as they will have a technician on staff or be able to guide you to one. Regards, Joe
PS kindly rate my answer as helpful.
Posted on Feb 13, 2010
Aqua glass jetted tub. How do I get the on/off switch to turn off jets?
it is a air switch, it has a tube running from the button to a box mounted on the pump motor,it could the hose has came off
Oct 08, 2015 | Home
Aqua Glass whirlpool, Indulgence collection, pump turns on and works briefly, then jets stop.
First of all, what you have is a WOW pump that has an E-switch for a control.
There is a knob on the top lip of your tub that you turn a 1/4 turn to turn this pump on/off.
There is a small circuit board inside the box on top of the motor. This is likely the source of your problem.
Here is your biggest problem. That little circuit board is not made anymore. We have the e-switch but you will be better off changing out the pump (which you have to do anyway) with a new WOW pump with an air switch and change the switch on the top lip of the tub to an air button which will turn the pump on/off.
Rod
US Parts Center
Apr 13, 2014 | Whirlpool Safety Bath Walk In Bathtub -...
I have an Aqua Glass Whirlpool Tub. The jets shut down and when I push the on/off button, it just makes a clicking sound. Do I need a new pump? If so, what kind do I order?
You could easily have the whirlpool fed by a double breaker. Try turning it off and back on and see if all is back to normal
Nov 30, 2013 | Home
I have an Aqua Glass Jaccuzzi that I haven't used in 10 years. The last time it was used it worked perfectly. Now I can't turn it on at all. I don't remember is just the round dial that
Check the circuit breaker and make sure you have power to the pump.
If you have power to the pump and it is not operational when the tub is full of water and you are in it then I would say you have a serious problem.
Most all of the older control that Aquaglass has used in the past have been discontinued.
You may want to visit this link and identify your control before you begin t trouble shoot your system.
Rod
US Parts Center
888-521-6183
Feb 27, 2013 | Whirlpool Safety Bath Walk In Bathtub -...
How to replace broken jet nozzles in whirlpool tub
Hopefully your tub is not too old because this will make replacing the nozzles very difficult as they are no longer made.
If in fact you have a Jacuzzi Brand bath you can get what is still available for bath jets here. The diagrams will give you an idea of how they come apart.
Jul 08, 2012 | Home
My Aqua Glass Whirlpool tub has stopped working. The motor comes makes a sound when I turn it on but the jets are not working
Your motor is shot. you need a new pump. If it comes on and you can hear a hum then it is bad. If you can get us a model number of the pump we can recommend a replacement model for you.
US Parts Center
Jan 05, 2011 | Whirlpool Safety Bath Walk In Bathtub -...
Aqua glass jetted tub quit working
Feb 13, 2010 | Whirlpool Safety Bath Walk In Bathtub -...
Aqua glass whirlpool tub leaks. looking for closure caps to close off the jets for good.
Aug 29, 2009 | Home
Home Logo
55 people viewed this question
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
