Question about Samsung Refrigerators
FANS MAKING NOISE - Samsung Refrigerators
Ceiling fan making grinding noise
bearings are dry and noise is metal on metal you can try to oil/lube the bearings --and or a blade is rubbing on case either loose blade or bearings worn causing offset wobble
Jul 13, 2016 | Dryers
Fan making noise on a 2004 Izuzu Ascender
all fans make noise.
which fan ,most cars have up to. 4 or more fans, some in rear seat.
try to point to and exact spot on car say in 1 square foot and say
xxx fan ,makes too much noise
Jul 01, 2014 | 2003 Isuzu Ascender
Zeith lg dlp 3110v00139b how to clean tv fans making noise wont turn on
It may not be the fans if this model uses a color wheel--fans can be cleaned with air to remove all dirt or dust(rest of set as well for that matter)
If possible I would remove cover and try to locate where the sound you are hearing is actually coming from.
Apr 29, 2012 | LG Televison & Video
Cooling fans inoperable
Be sure to check the fuses and relays first! If the fans were making noise before they failed, like you said; then it seems like they are the problem. Run power and ground to the fan to make sure.
Feb 01, 2012 | 2003 Chrysler Town & Country
Honeywell compact refrigerator model # 88031not cooling.
Honeywell compact refrigerator model # 88031 making a clicking noise, not cooling, interior light blinks, and the fans in back are not working properly....seems as if it's not getting full power. worked fine for about a year and justed stopped.
Mar 18, 2010 | Refrigerators
Just bought new fridge samsung rf 197abwp ,do the fans always make so much noise when running
none of the fans should be making very much noise at all.
if they are making noise they maybe loose and need to be checked.
Mar 12, 2010 | Refrigerators
My CPU is making lot of noise especially when I'm using programs like Adobe reader
The CPU wont make noise unless its frying. So its either your hard drives, cd drives, or your fans.
If its your fans i sugest buying newer "Cool Master" fans that are powerful but less noisy
Oct 20, 2008 | Mesh 80mm Aluminum Fan Filter Fan Kit
Cooling fan
Yes. It can be replaced. Try to check which fan is making that sound. Do you have a laptop or a PC? On a PC, there are 3 standard fans inside it. one for the CPU, one for the power supply and one for the computer casing fan as well. It depends on which of those fans it's coming from. On a laptop, some laptops' fans actually makes a loud noise which is common but there is a way that it could be lessened but it might slow down your pc and it might overheat it as well. The loud noise on the fans of a laptop actually indicates that it's trying to cool down the system. If it doesn't stop the loud noise, it could indicate a problem switching the fans back to normal and would just continue to spin fast. Try to contact your PC tech for further diagnostics on the laptops fan to indicate if the problem is with the fan or the mainboard as well.
Jan 02, 2008 | Iomega 33089 250 GB Hard Drive
Refrigerators Logo
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
