Question about Eclipse 4 Person Hot Tub Spa - Dream Maker Spa
There is a leak and we can not find it. Any solutions
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
    Scholar:
  • 64 Answers
Leaks can be hard to find in a fully insulated hot tub or spa. The best way to find a leak is to first look and inspect the area around the hot tub. Around the hot tub there will be an area of moisture that may identify your leak or at least bring you closer to the source.
You may want to make certain that your hot tub cover is making a good seal and that you are not just losing water due to evaporation. This usually shows with moisture at the middle seam area or the corners.
Next tighten all unions and connections and make sure you are not losing water through your pumps and equipment.
Once you are certain it is not the hot tub cover seal, or connections, turn off your hot tub and let it leak until it does not leak anymore, this will show you the possible area or height of the leak. Inspect the area on the outside of the hot tub for saturated insulation.
  1. Inspect for pools of water around your hot tub
  2. Inspect seal of your hot tub cover or spa cover
  3. Tighten all clamps and connections
  4. Do a leak test
When all else fails call a hot tub professional in to locate and repair your leak.
How To Fix Leaking Hot Tub
Posted on Sep 18, 2015
  • 1,631 Answers
This may help?
Fill spa to highest level possible.
Heat to 100 degrees or higher.
Then, with your bare hand feel throughout the bottom rim and anywhere else you are able to: see if you can feel "Warm/Hot" water. Any "Cold" water is not the area of the leak, that water has "Travelled" there. The warmer the water, the closer you are to the origin.
Posted on Jan 27, 2014
Testimonial: "I don't understand. If I heat to 100 degrees won't most of the water be warm/hot? So the leak could be anywhere?!"
I have a Hoover V Steam Vac model F7412. The tank for the clean water and cleaner fluid leaked out the bottom. I purchased a new tank but something in that area is still leaking. I know it is not the...
My clean solution tank is leaking from the bottom, too. It is not a hose or a valve. The clean solution tank is leaking in-between the clear plastic walls of the solution tank & the grey plastic bottom that are connected, together. I was thinking of caulking it all around the bottom where the clear plastic sides join the grey bottom plastic. I can't get into ordering a new one (spending $) unless Hoover will send me a new one for free. Purchased at Kohl's in Massapequa, NY in June 2008. There's a one year warrantee AND the directions say to EMPTY the solution tank after each use. Which I normally do because the tank runs dry.
Aug 08, 2014 | Hoover Steam Vac Dual V w/ SpinScrub...
Water tank leaks water out
Hello! Storing the solution in the water tank can cause the tank to leak. The solution tank is replaceable. Follow the link below to place an order for a replacement solution tank. Hope this helps!
Search Results
Jul 29, 2014 | Hoover SteamVac F5914-900 SpinScrub...
Frig freezer got puctured and the gas leaked out.-solution?
u will have to call someone to repair the leak and recharge with gas
Apr 08, 2014 | Samsung Refrigerators
Cleaning solution runs out
Most of these units have a control switch as to how much solution you want as you are spraying. Use the lowest setting. When the unit is empty, then refill it of course. Make sure the unit is not leaking (check the solution container for leaks).
Oct 16, 2013 | Hoover Vacuums
How to find an ac leak in a 2005 pacifica
Go too any auto store and get a leak detecting solution usually UV which willcome in a charging canister, then install following directions, when you shine a UV light on the areas your leaks will be shown thru the dye in the solution. That will locate the leak for you.
May 24, 2012 | 2001 Chrysler Town & Country
Power steering presure leak hose
temporary solution is to fine the leaking spot (if it's a very small leaking hole in the hose ) and screw in a right size screw and wrap it up tightly with tape. this way you'll loose less power steering fluid. and off course you know the better solution is to change the pipe.
Feb 10, 2010 | 1995 Pontiac Grand Prix
Cleaning solution leaks
It could be the lid on the container. If it isnt lined up absolutely perfect it tends to leak. You could make it tighter with a bit of ptfe tape. As these containers go into the machine lid down this is here mine leaks if Im not very careful.
Jun 13, 2009 | Hoover F6212-900 / F6215-900 SteamVac...
Clean solution leaking out the bottom
open it up again and check the pump there is probably a hose leaking ,did you put the clamps back on the hoses
Apr 14, 2009 | Bissell 1400 Little Green Pro Canister...
Hoover steam vac spin scrub leaking cleaning solution
The hose leading from the tank to the sprayer head on the bottom of the unit, or the tank is not seated properly or the tank has a hole or crack
Feb 14, 2009 | Hoover SteamVac F5914-900 SpinScrub...
Cleaning Solution leaks out around bottom
Most likely the opening under the seal has cracked or is starting to break away. You will have to replace the water bucket, the soap dispenser come with it, not separately.
Oct 20, 2007 | Hoover F7220900 SteamVac V2 Upright Vacuum
Eclipse 4 Person Hot Tub Spa - Dream Maker Spa Logo
430 people viewed this question
Top Eclipse Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
David Spradling
David Spradling
Are you an Eclipse Pool and Spa Expert? Answer questions, earn points and help others
