Question about Exercise & Fitness
My schwinn 6300 treadmill quit working while running. Is there a reset?
3 Suggested Answers
maxtreadmill
  • 832 Answers
SOURCE: schwinn 820 treadmill quit working in the middle
Loss signal: 3 possible areas that can be causing the problem speed sensor , motor control Board ( MCB ) or the drive motor. Unplug unit remove motor shroud then plug in unit now on the MCB their should be L E D s lights should be on. One of the L E D s should speed on other P W M . Start your treadmill you see the PWM light flickering thus the upper console and cable connections are good now it will go back L S. Reset your treadmill then manually start pushing the running belt now the speed light should be flickering if it does then the peed sensor is good if not flickering then replace sensor. If we have a good speed sensor then I would check the Drive Motor this done unplugging the unit the disconnect the two leads coming from the motor to MCB then by using a fully charge 18v drill battery connecting the leads to the motor should move it at approx; 1 mph then Your MCB is defective and need to be replaced. if no belt movement you for the most part will have worn brushes or open windings in the motor , I would open the brush compartment and inspect the brushes if they are less than 3/8" in length replace them this should the motor issue. Good Luck
Posted on May 15, 2010
Testimonial: "very helpful thanks much, JW"
Robert Braun
  • 77 Answers
SOURCE: Belt slipping on Schwinn Treadmill 5620P looking for local repair zip code 97405
Look for a repair person in your area at Treadmill Repair
If you don't see one there, and find a good one somewhere else, please submit them to this directory.
Posted on Nov 18, 2011
How do I fix error 3 on schwinn treadmill
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience.
http://electro-medical.blogspot.com/
Feb 25, 2015 | Schwinn 6100/6300 Walking Belt
Schwinn 5450 treadmill power to fuse on circuit board, but no operation
HOwever test the c. breaker and reset.
If the problem persist LUBE the deck belt+rollers bearing see the video attached.
see the diagram attached in case that you need to troubleshooting.
Feb 18, 2013 | Schwinn Exercise & Fitness
SportsArt 6300 error display 04 -0015 help...
the power supply is receiving too low or higher currents.You must test this. Or you need to call the service tech. However try to RUN the s. calibration if you can. Otherwise reset the machine. and see the block diagrams attached.
God bless you
Dec 05, 2012 | Sportsart 6300 Treadmill
Schwinn belt stopped
Dear Sir:
1) You must LUBE the Deck Belt, in according with the instruction manual. The deck maybe is worn.
2) See if the deck belt is in bad condition.
3) Test the drive belt if o.k
4) Test the main motor if running, if not the motor need attention and repair.
5)Test the input voltage for motor coming from the main motor BOARD.
see my personal TIPS for HELP.
sincerely. God bless you
Apr 23, 2012 | Schwinn 820 P Treadmill Silver Service...
Schwinn 820 treadmill quit working in the middle of walk shows L-5 on screen. what is problem?
May 13, 2010 | Schwinn 820 P Treadmill Silver Service...
Error code L5 on schwinn 820p
Landice L9 tredmill, L5 display on screen,belt runs slow and nothing else works to the touch.
Exercise & Fitness Logo
Top Exercise & Fitness Experts
Howard
Howard
Sportsmith LLC
Sportsmith LLC
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
