Question about Intel Desktop Board D865PERL (MBIND865PERL) Motherboard
Windows xp installing failed
Iam trying to install a fresh copy of windows xp and the following error message appears; installing failed F:\i386\asms. error message: a component's file doesn't match the verification information present in the component manifest.
I had try to copy all the file in cd:\ I386 into my HD when the windows on completing install, and then rebooting my computer, but the same problem still appear. can anyone fix this problem?
Posted on Aug 26, 2012
  • premono_andi
    premono_andi Aug 26, 2012
    I had try to copy all the file in cd:\ I386 into my HD while the windows was completing install, and then rebooting my computer, but the same problem still appear. can anyone fix this problem?
    President:
  • 623 Answers
I assume you are trying to install XP from a self-burned CD.
Did you slipstream SP2 or SP3 in it?
If so, try to burn a DVD instead of a CD. I had that problem once too and followed some advice I found here.
If you have any more questions, just come back here and leave a comment - I'm happy to help.
Posted on May 20, 2009
It is not starting up
Good day. I suggest for you to reinstall windows and use the repair options. Usually software encounter errors or some files might get corrupted causing your computer not to boot up properly. The repair option in Windows XP will help you to fix those issue. here are the steps to follow:
1. Rule out hardware issues. Windows Repair will only fix software problems. Hardware issues can also cause boot problems (i.e. bad hard drive, memory, CPU, or power supply).
2. Backup. It's always a good idea to backup your important data before making changes to Windows XP. Relax, if you follow these instructions your data will be perfectly safe.
3. Boot from your Windows XP CD. Insert the Windows XP CD into your computer's CD-ROM or DVD-ROM drive, and then restart your computer. When the "Press any key to boot from CD" message appears on the screen, press a key to start your computer from the Windows XP CD.
4. A blue screen will appear and begin loading Windows XP Setup from the CD.
5. When completed loading files, you will be presented with the following "Windows Setup" screen, and your first option. Select "To set up Windows XP now, press ENTER". DO NOT select Recovery Console.
6. Then press F8 to continue
7. Next, Windows Setup will find existing Windows XP installations. You will be asked to repair an existing XP installation, or install a fresh copy of Windows XP.
8. Then just choose repair option to repair your Windows Xp
9 Then it should work. If iin any case that will not solve the issue, you might try to install fresh copy on Windows Xp
Hope this information will help you resolve your issue. Have a great day.
May 24, 2011 | Microsoft Windows XP Home Edition
Tip
HOW TO REINSTALL WINDOWS XP OR INSTALLING CLEAN COPY
How to reinstall Windows XP operating system or installing fresh copy of Windows XP on your computer.
If your Windows XP operating system had problem due to corrupted files, viruses problem or you want to upgrade your system. This procedure will guide you in reinstalling your current Windows XP or installing fresh copy.
After this installing process, you need all your hardware drivers like Chipset Intel driver, LAN driver, Sound driver, WAN driver, Webcam driver and others for the computer to be fully operational. Otherwise, do not proceed on reinstalling you operating system if your do not have those hardware drivers.
CDROM drive is required for installing Windows XP. If you don't have in your notebook computer, use external CDROM drive to connect in your computer using a USB cable.
1. To start with, you need to back up your in blank CD all your important files before you begin installation produre because all the data will be wipe out.
2. When ready, start your computer and when booting press F2 to
BIOS setting.
3. On BIOS menu, choose the BOOT setting and change the priority boot to CDROM, exit and save.
In some laptops, you can skip this BIOS setting process by repeatedly pressing F9 key or F10key when booting your computer and it will run boot priority on CD.
4. Once you exit from BIOS, you computer will reboot and a message will appear " Press any key to boot from CD", press any key to enter into WINDOWS XP SET UP.
5. Belows instruction messages will appear:
* To set up Windows XP now, press ENTER
* To repair Windows XP installation using recovery console, press R
* To quit set up without installing Windows XP, press F3
Press ENTER to initiate the installation.
6. You will go to Windows XP license agreement and press F8 to agree.
7. You will ask you if you want to REPAIR or REINSTALL the operating system. It will appear like this. Just press ESC to proceed.
A. To repair the selected Windows XP installation, press R.
B. To continue installing fresh copy of Windows XP without repairing, press ESC.
From repairing your operating system, it will not removed all your files and other software installed in your computer including your hardware drivers installed. Just fixing the operating system.
For reinstalling the operating system, you need to back up all you files because it will wipe out all you datas in your computer.
8. After that, it ask you where partition you want to install the operating system. The message will display like this :
C : Partition1 [NTFS]
D : Partition2 [NTFS]
Unpartitioned Space
Use the directional key to navigate and choose C: Partition1 if you want reinstalling Windows XP and press enter.
If you want clean copy of Windows XP, you need to delete both partition by pressing L and install clean copy at Unpartitioned space. By these procedure, you will have C: drive only. D: Drive is delete.
9. After choosing the desire partition. this will appear :
* Format the partition using NTFS files system
* Format the partition using the NFTS file
I suggest to choose the first line which is the quick format. The 2nd line take too much time to install the operating system. Press to initiate the installation and it will be finish and reboot automatically. PART OF WINDOWS INSTALLATION IS FINISHED.
If you had interrupted installation which is asking for certain driver file, your CD installer maybe damage which cause files to be unreadable. Try to replace the new Windows XP installer CD to proceed and until finished installing OS.
10. Once it reboots, this time do not boot from CD or do not press any key to go to PART2 OF WINDOWS XP INSTALLATION PROCESS.
11. On the opening, regional and laguage option will appear, jus click next.
12. The it will ask to type your name & organization. Put you name and company if any and click next
13. Then, it will ask for CD key and type the 25 character CD key and click next
14. Then it will ask for computer name. You can change or leave it and click next.
15. Then, set your date and time zone and click next.
16. Then, it will ask you for workgroup and computer domain, just leave it and click next.
17. Now wait until the installation process end and it will again restart automatically.
18. Again, do not boot from CD and display setting will appear. Just click OK.
19. welcom to Microsoft Windows screen will appear. Just click next.
20. Helps protect your PC will appear and choose Turn on Automatic Updates ( Only if you install genuine Windows XP). Otherwise, I suggest to choose "Not right not" if you are installing copy only of Windows XP.
21. Who will use this computer message will appear. Just type your name on the first box and click next.
Also for your reference, here is the video for your convenient .
A thank you message will appear, Just click next and it is finished.
I hope it helps you and thank you for using FixYa !
For repairing the operating system here is the blog as other want it.
As per others demand, here is the video for Windows 7 and Windows Vista Operating system
on Dec 23, 2010 | Computers & Internet
STOP C0000221 erro de hardware desconhecido systemroot system32 ntdll.dll
You may receive one of the following stop error messages while working on your Windows XP computer.
STOP: C0000221 unknown hard error
Path\File_nameSTOP: 0xC0000221 unknown hard error
C:\Winnt\System32\Ntdll.dll (or another specific file or driver)
STOP: 0xC0000221 STATUS_IMAGE_CHECKSUM_MISMATCH
Path\File_name
Note: The error message may be discussed in many different formats-blue screen or message box. It depends on when the corrupt file was detected.
Similarly, you may receive the following STOP messages when a critical system file fails to load on your Windows NT and Windows 2000 computer.
<path>\<file_name>STOP: 0xC0000221 unknown hard error
c:\winnt\system32\ntdll.dll
Note: Some other drive may also be given in the message.
On Windows 2000 the following error message may display:
<path>\<file_name>
You usually face this problem when an incorrect driver for one or more hardware is installed on your system. For instance, the error messages described above are displayed when you install a millions of instructions per second (MIPS) driver on a x86 system.
Cause of the Error
This error occurs if the file given in the error message is damaged.
Your Windows XP operating system checks the following files for integrity during system startup:
  • All driver files, excluding the files that loaded using the system loader to start your system .
  • All DLL (Dynamic Link Libraries) on the system. These include, Graphics Driver Interface (GDI), User, Ntdll, Crtdll, Shell, Kernel and several other DLL files on the system.
  • On Windows NT and 2000 computers, all DLLs loaded in the Window server address space are also checked.
The problem may also occur if an Iomega Zip drive is connected to the same cable as your hard disk drive.
Resolution Method
You can resolve this issue by removing the corrupt driver from your computer and then reinstalling a fresh and healthy copy of the driver. You may need to use the Device Manager utility to remove the driver. It is recommended that you clean your registry with the help of a reliable tool, such as RegGenie to ensure that all entries related to the uninstalled driver are removed from the system. After you have completely removed the corrupt driver, restart your system and install a fresh copy of the driver on the system.
If this step does not resolve the problem, you may have to reinstall Windows XP.
It is recommended that you regularly clean your registry with the help of a registry cleaner tool and perform antivirus and antispyware scan using tools, such as Antivirus Plus and StopZilla to prevent such errors from occurring on your system.
GOOD LUCK :-)
Feb 03, 2010 | Intel Computers & Internet
Blue screen error
I see ..either teh installation didnt complete the loading of the files..or you didnt format the Hdd proper...try to reformat it in the NTFS normal mode...and change the installation cd ..cause in the proces there might have been a file it couldn't copy ..and skip it ...keep trying cause sometimes it does that ...if the server went fine ..this means that the HDD its ok ..and the problem is the installation disk ...with xp on ...
Aug 04, 2009 | HP Pavilion zd8000 Notebook
Need file asms to complete installation
The problem is some files in your installation cd cannot be read anymore.
Options:
1. When the error appears try to redirect the wizzard to the directory of your CD ROM and locate the file.
2. If you have back up copy of your xp cd use it to replace the xp cd you are installing when the error appears.
3. If you have a copy of your xp installer on your hard disk re direct the wizzard to that directory.
Apr 27, 2009 | Microsoft Windows XP Professional
Error code 2352
http://service1.symantec.com/SUPPORT/nav.nsf/pfdocs/2003020714354306?Open&docid=2003020714354306&nsf=nav.nsf&view=pfdocs
To run the Microsoft Windows Installer if Norton AntiVirus was installed from the CD
  1. Insert the Norton AntiVirus CD into the CD-ROM drive.
  2. Do one of the following:
    • If the installation program appears, then click Browse the CD
    • If the installation program does not appear, then double-click the My Computer icon on the Windows desktop, and then double-click the CD-ROM drive icon.
  3. Double-click the MSI folder.
  4. Do one of the following:
    • In Windows 98/Me, double-click the WIN9x folder.
    • In Windows 2000/XP, double-click the WINNT folder.
  5. Do one of the following:
    • In Windows 98/Me, double-click the Instmsi.exe file.
    • In Windows 2000/XP, double-click Instmsiw.exe if you have Windows 2000/XP.
  6. In the next dialog box, click Yes.
  7. After the rollback has finished, then reinstall Norton AntiVirus.
    Follow the instruction in Reinstalling your Symantec program after a failed installation or after you see error messages to start the computer without any programs running on startup and then reinstall your Norton program.
If these steps do not fix the problem, then go on to the next section.
To run the Microsoft Windows Installer if Norton AntiVirus was installed from a downloaded version
  1. On the Windows taskbar, click Start > Find (or Search) > Files or Folders.
  2. Ensure that "Look in" is set to the drive where you downloaded Norton AntiVirus, and that "Include subfolders" is checked.
  3. In the "Named" or "Search for..." box, do one of the following:
    • In Windows 98/Me, type the following:
      instmsi.exe
    • In Windows 2000/XP, type the following:
      instmsiw.exe
  4. Click Find Now or Search Now.
    You might see many files with this name. Look for the file with this name that is located in either the Symantec_Norton_AntiVirus_2003 or the your Windows temporary file location depending on your version of Norton AntiVirus.
  5. In the Search Results window, do one of the following, depending on your version of Windows:
    • In Windows 98/Me, double-click Instmsi.exe.
    • In Windows 2000/XP, double-click Instmsiw.exe.
    This will undo the changes that were made to your system during the first failed installation.
  7. After the process finishes, then reinstall Norton AntiVirus.
Apr 22, 2009 | Microsoft Windows Vista Home Premium...
Application Error - svc host
its may be because any virus or trogans already in your pc. just backup your data, format ur c drive and install fresh copy of OS. Install an antivirus and update immediately. Then access your other drives. this is the best solution.
Apr 10, 2009 | Microsoft Windows XP Professional
Installation failure
I have already started to answer on the original thread!, let's keep the conversation in one place.
Oct 08, 2008 | Computers & Internet
Problem loading win XP-SP2
Don;t know if this is the cause of u're errors, but it might be do to the motherboard chipset drivers (the lack of them in u're windows version). If so, u have to make a copy of u're windows cd with all u're motherboard drivers included, and try to install with that cd. The same problem appears to all new laptops that do not offer XP support and only Vista support . In order to do the new XP cd, u\ll need a little program that u'l find on internet..... (for example: n-lite)
Jan 18, 2008 | ASUS A8N-SLI Deluxe Motherboard
Error no 0x80070003 appears when trying to install Windows update.
Click on the start button, click run
at the run window type the following:
sfc /scannow
now your windows system files will be checked for changed, if they are changed a fresh copy of the files will be copyed from the windows cd.
Note: you must have the original windows installation cd in the cd/dvd drive.
Jan 04, 2008 | Microsoft Windows XP Home Edition
Computers & Internet Logo
598 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
