Question about Hardware & Accessories
Wooster adh 6124
Dont know how to set the time and date to the proper one. tried lots of things. nothing works. running out of options. please help.
E61N
  • 515 Answers
SOURCE: Tomtom Xl date and time settings
In v7.xxx software version, (you dont tell wich you have);
If all menu options are showing:
tap screen, tap Change Pref., tap right arrow to page 8/8, adjust time....
If not all menu options are showing:
tap screen, tap Change Pref., tap right arrow to page 3/3, adjust time.... While your there, tap Show all menu options.
Posted on May 21, 2008
SOURCE: WATCHES
i hope this helps....
the top right says st/stp....tells you the year
the bottom right is the light...
the top left is the reset....
and the bottom left is mode...alarm, stop watch,and time 2
Posted on Dec 01, 2008
SOURCE: i cannot change the time on my motorola KRZR
did you restart your phone?
Posted on Mar 09, 2009
  • 2501 Answers
SOURCE: I need to know how to set the correct time and
You can get instructions from their web site "(www.adidas.com/campaigns/watches_fw07/content/index.asp?)"
Click on "instruction manuals" in the menu on the left, choose your country.
You will be presented with a series of generic instructions from which you should choose the ones that suit your watch
Posted on Jun 01, 2010
nonontech
  • 4737 Answers
SOURCE: in my nokia 1650 set no is not working properly
Reset you phone to "Factory Default" by entering 12345 as the code. To do this, go to "settings" scroll down to the bottom and select "Factory Default" or "Factory Restore" and enter the code as mentioned above and press "Ok". This will restart your phone or if not will directly reset you phone to the factory default (the condition of the settings when you purchased). If this doesn't fix, you need to update the firmware, i would suggest you to get it done from the mobile repairing shop.
Good luck. Thanks for using FixYa.
Posted on Jun 03, 2010
I have st6000 digital camera. when i goto change some settings some options cannot be selected sometimes.(like touch screen not working properly). so how do i reset my camera to factory settings.?
First you have to be sure, you could select the same options in the same menu, with the same settings before.
Most of the time when you can't select a certain option, it has to do with the chosen setting. So if you are in automatic, you can't change white balance or the ISO and lots of other things. Also when you are in a scene mode, lots of things can't be changed or chosen.
Most camera's don't have any way to go back to the factory settings. You can set back some settings you made, but most of the time, things like language, date time and some other things will stay as you put them in. Don't think your "computer" in the camera does not function correct, unless the camera gives some warning on the screen, or Samsung comes with an update of the firmware.
Jan 07, 2014 | Samsung ST600 Digital Camera
Reboot system
Not sure how much you know but you seem clued up.Try switching off, turn on and press delete then scroll down and try to start up in safe mode. Have you had a power cut when trying to install up dates??? if this does not work try doing the same thing but pick restore to last known date. it took me a bit of time to work this out, use the cursers as your mouse wont work. would like a bit more info if these options dont work. Let me know please?
Jan 24, 2012 | Microsoft Computers & Internet
I just bought a watch its number is ADH4017 i believe its the peach tree watch,something like that. its neon yellow, anyway i cant find the settings to change the time. can somebody please help me i...
TIME/CALENDAR SETTING
1. In normal time display, press and hold A to enter setting mode; chime will begin
flashing.
2. Press C to increase setting value. Press D to decrease setting value.
3. Press B to set and advance to next setting value.
4. Setting sequence is chime, 12/24-hour time, hour, minute, second, year, month,
date, Auto EL.
5. Press A to save data and exit setting mode.
Dec 02, 2010 | Adidas Unisex Watch Wooster ADH1770 - WW
My pc automatically get start on plug on .and then it suggest me to press F1 to Continue. when I do this it takes incorrect date and time how to restrict it.I want to start it with start button on cabinet
There can be many reasons...
  • Your BIOS setting is not correct.
  • CMOS battery is down(Most probably).
  • both
You can open the BIOS setting page by pressing keys like DEL, F10, etc. depending on your system's manufacturer at computer startup(post screen). There are lots of wakeup options check them properly.
One of the option is "Restore last state of power Button on failure" which can turn on your computer without touching the power button. you should check these options.
And it suggest you to press F1 because your system's date/time is not configured properly. You can also set Time/date in BIOS also.
If your BIOS Battery(CMOS) is not weak or dead then after setting these values your computer should start properly.
And if your BIOS battery is dead then all the settings will be lost(date/time etc) after a restart and you will face same problem again...
Try changing the Power-button option and Date/Time in BIOS and see if problem persist....if yes then you have to change COMS battery that is on your Motherboard.
Sep 22, 2010 | Computers & Internet
Please help me set up the time for the adidas wooster watch, can't seem to find the right instruction page.
mcdevito75 Here, Go thru the manual slowly, you need the MODE and SET Buttons. Carefully read all.
Aug 26, 2010 | Adidas Wooster ADH1769 WW eBook Watch for...
I need to know how to set the correct time and date on an adidas wooster watch
Jun 01, 2010 | Adidas Unisex Watch Wooster ADH1770 - WW
How do i set the time for the adidas adh 1770
You can get instructions from "www.adidas.com/campaigns/watches". Click on "instruction manual", choose your language and the choose the watch that looks like yours and follow the instructions listed.
Mar 12, 2010 | Adidas Unisex Watch Wooster ADH1770 - WW
Changing the time on my Motorola Razr V3 phone
you must first disable Autoupdate (turn it off) - go to settings>scroll to Initial Setup, (select this)>Time & Date (select this)>Autoupdate (set to OFF)>after you do this option will appear to change time to 12/24 hour....
May 11, 2009 | Motorola Mobility RAZR V3c Cellular Phone
I need to reset the date and year
I had exact same problem with RTH7500. Did not set the date properly at the beginning and than realized that there is no menu option to change the date after it is saved once (???!). I was very confused for few hours and wandering - trying to find changing option on thermostat menu; than I was looking online what can be done... I could not find solution...
Than I took out both AA batteries, open the thermostat (be very careful while doing this - you don't want to break plastic peaces that hold the thing together) and took out the button battery thinking that this will reset the thermostat... but it did not.
I repeated the same thing, but this time, while the button battery was out, I put two AA batteries back and this reset the thermostat... the old - blinking date appeared and I was very happy to see this on thermostat screen! This time I set the time properly and it works fine.
Hope this will be helpful if you did not solve the issue yet... if you did, someone else might find this solution useful.
Mar 01, 2009 | Honeywell Electronic Programmable...
Go to settings
--> Initial Setup
--> Time and date
--> Auto update off
Then you will find the time and date.
go to date use right soft key and change the date and similarly for the time.
Jul 28, 2008 | Motorola Mobility RAZR V3
Hardware & Accessories Logo
Top Hardware & Accessories Experts
Gene Haynes
Hippy_dd
Are you a Hardware and Accessory Expert? Answer questions, earn points and help others
