Question about Husqvarna 23HP VTwin Hydrostatic 48" Cut Riding Mower
Back tyre removal
Back tyre is flat . It is tubeless. Need to remove it and get it reinflated
  • Husqvarna Master
  • 2,478 Answers
Most a e-clip holding tire on. I use a tubeless tire repair kit. Blow the tire up, find the leak and use kit repair.
Posted on Jan 02, 2014
Which tyre best for honda cb shine 80/100-18 tubeless or 3.00-18 tubetype
Hi Nagraj, it all depends on what type of wheel you are running. If your wheel has spokes you must use a tube, if your wheel is cast you can run tubeless. Good luck
Apr 06, 2015 | Honda Motorcycles
Why hero Impulse bike don't have tubeless tyres?
Can't run tubeless tyres with spoked wheels.
Mar 27, 2015 | Hero Motorcycles
What should the tyre pressure be for a Vauxhall Astra 1.6 SXI 2008
There should be a sticker on the door or door surround when you open the front doors. Pressure should be on there though likely to be in bar, ie 1.2 bar, or kpascals. they seem to have dropped psi but 30 psi / 1.2 bar is near enough for a reinflate. If it goes down you have a puncture and will need to visit a tyre shop.
Jul 01, 2014 | Vauxhall Astra Cars & Trucks
2007 Honda SCV 100 Lead repair rear wheel flat tire
Hi, Anonymous for this scenario you will need your service manual, parts fiche, and owners manual if you can't find the best tool you ever bought for your Honda, despair not, for a mere zero $0 you can download another one.
For more information about your issue and valuable "FREE" downloads that you will need for viewing or printing please click on the blue links below. Good luck and have a wonderful day.
How to replace scooter rear tyre inflate tubeless and remove exhaust
How To FIX FLAT TIRE on HONDA SPREE Scooter REMOVE the REAR Wheel on moped
http://www.family-motorsports.net/GY6-50cc-150cc.pdf
https://www.partsfish.com/page/oem-parts-for-honda
Honda SCV100 Owner Manual
Nov 30, 2012 | 2007 Honda SCV 100 Lead
There is a small nail in my real tire. Should I buy new tire and replace it myself? Should take it the tire repairs service? What is the best and cheaper thing to do. I don't even know if it a tubeless...
Hi, have you checked if it is loosing air, try removing it and see if it goes down,if it. Leaks as you try to remove it then push it back in and leav it in the tyre, some tyre fitting centres will repaire it for you if it is not damaged inside as a result of overloading, take the wheel along to a fitting centre and ask about a repaire, or contact 1by telephone and enquire if they do repaires to motorcycle tyres before you travel, there is a stigma with repairing motorcycle tyres as a liability problem may exsist if the machine lost traction due to loss of air. Even though the manufactors say it is ok to repair, probs best. Buy a new 1, what bike is it fitted to, if it has spoked wheels it poss not tubeless, if it has alloy wheels it should be tubeless
F
Mar 07, 2011 | Yamaha Ybr 125 Motorcycles
A spoke on the rear wheel has snapped off how can I repair it?
Simply buy a replacement spoke. Unscrew the dustcap on the tyre valve and deflate the tyres inner tube. Remove tyre using tyre levers(as you do to repair a puncture). Next remove the inner tube to reveal the spoke tensioners. undo the tension nut and allow the broken spoke to fall out, feed the other part of the broken spoke out of the hub. feed the replacement spoke through the hub and into the hole on the wheel rim. Now screw on the tensioning nut to the spoke.Tighten up to the same tension as the other spokes. replace inner tube and tyre, then reinflate. Viola!
Jan 30, 2011 | Cycling
I have new Accent Excutive car, i just notiec that my car tyer type is Bridgestone S322 . My Question is its a Tube less tyre ? My car has all company fited tryes one of them show 175/170 R 13-...
putting a tube inside a tubeless tyre is a cheap way of fixing a puncture,BUT DO NOT EXCEED 75MPH,as, if the tube gets punctured,you could lose total control of the car......If you get a puncture with A TUBELESS TYRE YOU SHOULD ALWAYS replace it (how much is your life worth)Tyres have written on the wall wether they are tubeless or not.DO NOT MIX THEM,lastly NO MANUFACTURER fits tyres with tubes for road use.
Oct 18, 2010 | 2009 Hyundai Accent
Yahoo.comProblem with Tubeless tyre, one time it got burst, second times bubbles came out from tyre, I want to place tube inside tubeless tyre, can I place tube inside tube less tye and make it tube...
max speed with a tube inside a tubeless tyre is 75 mph.DO NOT EXCEED THIS SPEED for highway motoring.(hyundai make KUMHO tyres) THEY ARE NOT RATED FOR MORE THAN 100 MILES PER HOUR.YOU MUST USE TYRE RATED FOR THIS TYPE OF SPEED.check out michilin.com for tyre for ratings.
Aug 24, 2010 | 2009 Hyundai Elantra
I am having trouble getting the side wall of small tire to seal against the wheel.
I take it we are talking a tubeless tyre, the way I do it is to remove the valve core use a wide luggage strap to contrict the tyre and inflate until the tyre seals against the rim, once the tyre has seated you can refit the valve core and inflate the tyre to it's correct pressure. hope this helps
Nov 28, 2009 | Sears Heavy Machinery
Help- wheel problem!
Call or email the company. I had the same problem and they sent me a new inner tube for free b/c my stroller was still under warranty (yours should be too). I took the new tube and the stroller to a bike shop where they finished the repair for me for $5.
Oct 06, 2006 | Bugaboo Cameleon Jogger
Husqvarna 23HP VTwin Hydrostatic 48" Cut Riding Mower Logo
116 people viewed this question
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
