Question about KitchenAid KP2671 Professional 6 Series Stand Mixer
Problem in speed mixing.i want to change the motor,where can i order to buy this thing. thank you..
My 6 quart stand mixer has a problem in speed mixing.i want to change the motor,where can i order to this thing. thank you..
  • KitchenAid Master
  • 2,005 Answers
Www.easyapplianceparts.com/KitchenAid-Parts.htm
Posted on May 20, 2009
Runs for 5 seconds and then stops
Hey Greg, the first thing that comes to mind is that the machine is not tuned correctly. If it runs in slow speed and stops when you move to a fster speed then the speed control switch needs to be adjusted, here is a site that will give you the basics on tuning.
www.youtube.com/watch?v=pUo_ZU5xh3o
I hope this helps you, please let us know if we can help further that way we can help FixYa
Aug 08, 2014 | KitchenAid KP26M1XNP Professional 600...
Why is mixing speed switch not working correctly?
How old is your appliance?
If you are just getting one speed at any speed control. Its likely that the speed control mechanism ( probably an electric one has been damaged due to ailing parts). Likely component which may fail over time are electrolyte capacitors. Take a look at the circuitry inside the food mixer.
You may need to change some parts to get back the control.
Jun 24, 2014 | Gourmet Grade GM800 7-Quart 10 Speed...
Kitchenaid stand mixer 5SSWH 325 watts. How do I adjust the bowl height? Beater is too far from bottom of bowl. Thanks! Cas
There is a screw at the bottom of the motor head (flat head) you usually can't see it because of the top rim of the mixing bowl. hard to see and hard to reach, it may also be hard to turn due to "gunk" from mixing stuff (egg butter flour sugar) turn the screw counter clockwise to lower the motor head clockwise to raise it, you may also have the wrong size beater, it is not an uncommon problem, if you are the original owner and you have the original beater it should fix your problem with the adjusting screw, however I am not clear as to your model a 5SSWH would actually be a K5SSWH, which stands for kitchenaid 5 quart solid state white mixer, if this is your model number and you have the correct beater size then the adjusting screw will work to lower the head down, adjust it down using the stir or slowest speed just untill you can hear the beater "Ding" against the bottom of the bowl, then back it off a quarter turn to adjust properly. Hope this helps, let us know
Apr 17, 2013 | KitchenAid K5SS Heavy Duty Commercial...
Kitchenaid kp26m1xer won't turn on
If the mixer died completely and no noise at all comes from the machine you need one of three things.
1. New brushes2. new speed control switch3. a new motor.
The KP26 is a 6 quart mixer of the new design, post 2002, it is easy to work on and relatively inexpensive for parts if it turns out to be the motor that will be about $100.00, the speed control about 30.00, the brushes on this mixer cannot be replaced you have to install a new motor, sry about that. Hope this helps let us know. But first check that the electric outlet you are working from has not tripped the breaker on the circuit too. I know I know it's silly to say but check the outlet first before you spend a dime on anything.
Mar 11, 2013 | KitchenAid 32685 Mixer
325 k5ss mixer stir speed not working, but works in all other gears
First congrats on the great mixer that you have. next the pro 6 or professional 600 series mixers are of an entirely different design than the one that you have even though they are both bowl lift. Do you really need 6 quarts capacity? The pro series is a 575 watt mixer BTW, and it will have more power available to you IF you are doing bread or a lot of food grinding, if that is a requirement that you have then the 6 / 600 series is the better suited mixer but if all you are doing is general medium to light mixing duties then fix and keep the K5SS it a great machine,
Mar 02, 2013 | KitchenAid K5SS Heavy Duty Commercial...
Kitchenaid mixer 600 won't turn on
bread is very tuff on mixers. always buy the strongest mixer that you can afford. im guessing the field in the motor fried.
Feb 07, 2013 | KitchenAid Kitchen Aid KP26M1X 6 Quart...
KitchenAid stops working when anything other than liquid is in the bowl..
There is a non metal gear inside the motor head that is stripped and no longer engaging the worm drive. What happens when you try to assist the turning process (try it only on stir speed, sloooowwwww) if it starts to turn and then stops again then it is the gear I spoke of. It will require tearing down the machine, cleaning all old grease, to insure that you have no ground up parts in the grease, then replace the grease gasket and gear. Hope this helps
Jan 11, 2013 | KitchenAid Professional 600 Series 6-Quart...
My KitchenAid mixer will not turn it makes a loud noise.
thebsjunk - I don't know if you've canned the old mixer. If you've bought a new KA, congratulations to Kitchenaid. If you haven't, there's still a possiblilty that you might be able to fix it yourself. (For the price of KA mixers you'd think they's last a 'lifetime', but alas, KA quality is sorely lacking from their current products...but I editorialize.)
It's quite possilbe that you've had a gear tooth break in the transmission, which would lock up and prevent the planetary gear (agitator) from rotating in mixing bowl. This is what happend to my wife's 6 Quart Pro KA mixer. Since it was out of warranty, I decided to troubleshoot myself. First I downloaded the Parts List manual from the KA website so I knew what to expect. Then I easily disassemble the mixer to find that a bevel gear tooth had broken. After ordering the correct parts, and reassembling, it works better than when we first upacked it. The loud whining is absent...
If the motors gone bad, you can still replace that, too. Fixing your mixer yourself is much easier than shipping it off to a repair center, and you have the gratification of doing it yourself.
I hope this helps! Howard, Burke, VA
Oct 14, 2009 | KitchenAid KSM90 Ultra Power Series Stand...
Today mixer stopped while mixing.
OK, you mentioned everything except the brand. I found on some models of Sunbeam mixers that the speed governor would fail due to the control knob screw being loose.
On that particular model, the screw is behind a stick-on label in the center of the knob. Peel off the label and make sure the screw is tight.
If your mixer isn't a Sunbeam, please advise.
Mar 23, 2008 | KitchenAid KP26M1X Stand Mixer
KitchenAid KP2671 Professional 6 Series Stand Mixer Logo
120 people viewed this question
Top KitchenAid Food Mixers Experts
jack arons
Colin Stickland
Colin Stickland
Are you a KitchenAid Food Mixer Expert? Answer questions, earn points and help others
