Question about Refrigerators
Kitchen aid ksrt25c display - Refrigerators
Broken magnet of a Kitchen Aid Blender. Where can I find another one? KSB5WH4
From Kitchen Aid they only come on a new motor. I am a Kitchen Aid service agent and I remove them from burnt out motors and keep them. Look for a service agent near you and see if they can help you out. I have no idea where you are, I'm in New Zealand.
Apr 26, 2016 | KitchenAid Kitchen Aid Kitchenaid 5-speed...
KSRT25C display doesn't work after power outage
No sorry there is no reset button. If this happened during an outage there is a possibility that there was also a surge. Electronic control boards are sensitive to sudden changes that may have swelled the tops of the capacitors on the control board. HERE=> 2303843 Dispenser Control Board
Have someone unplug the power and look over the 2303843 Dispenser Control Board Sometimes you can see damage but most times you will not see a problem with the board. . I am here should you need me, Thanks John Tripp Appliance 911
Apr 03, 2014 | KitchenAid KSRT25CRSS Stainless Steel Side...
My kitchen aid stove keeps displaying F2:E2 - Why? and what does that mean?
That code means that the oven is over heating.
Replacing the temp. sensor should do the trick. The sensor
is the rod that protrudes from the inside back wall of oven.Usually in the top left corner.
Feb 05, 2013 | KitchenAid KESC307 Electric Kitchen Range
Oven temp is lower then display
kitchen aids website has the manuals available for download. page 33 has the procedure. opent eh dorr and hold "bake" pad for 5 seconds until you hear the beeb then press "bake" again for each 5 degrees you want it adjusted. If the oven is not hot enough add 5 if it is too hod make it a -5. the range is 35def farenheit either way.
Nov 20, 2011 | KitchenAid KGST307 Gas Kitchen Range
My kitchen aid gas range display F5:E3 and contact touch board has no function
Hi
Error code F5-E3 indicates that there is an issue with the door latch switch assembly; if the switch tests open then the door lock assembly should be replaced. Hope this helps...please post back for further assistance.
Daniel
Aug 08, 2011 | Kenmore 79012 / 79014 / 79019 Gas Kitchen...
Controls won't work. Displays message: E0 -F2-
Hi
Thanks for using FixYa. Error F2-E0 on your kitchen aid means that the keypad is shorted and to resolve this issue you’ll have to replace the electronic range control/clock (ERC). Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Jun 20, 2010 | KitchenAid KERC607 Electric Kitchen Range
I have a Kitchen Aid KGRC608lsso, the key pad
I have the same problem with my KGRT607H. I took off the control panel, and wiggled some wires, then it worked (the LED display). Seems to be a loose connection, with one of the wires going into the connector. I myself haven't replace the connector yet, I just take the control panel apart, and wiggle the wires. Pain in the ****, so one day I will try to replace it either that or try to secure it better. My next step is to find out which wire leading into the connector. (figuring its either a bad wire). On my control panel, its the connector that has all the 'white' wires going into it, not the coloured ones.
May 20, 2010 | KitchenAid KGRC608LSS Gas Kitchen Range
Kitchen Aid Refer: KSSC42FMS01: The freezer, doesn't go below 32
How long have you had this refrigerator and is this the first time this has happened? Your refrigerator has a control board and I believe the board is causing the refrigerator not to defrost every 8 hours. Let me know these questions and I will help you resolve this. Thanks, Sea Breeze
Mar 19, 2009 | KitchenAid Refrigerators
Can't attach beater to kitchen aid
good day,
hope this link below will solve your problem.
kitchen
Dec 13, 2007 | KitchenAid KITCHEN AID 5 Quart Artisan...
Refrigerators Logo
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
