Question about Polaroid i1236 Digital Camera
How do I delete pictures from a polaroid is426?
I need to delete some pictures off my phone and I don't know how
2 Suggested Answers
lpfaff1
  • 11573 Answers
SOURCE: Hi.user manual for Polaroid is426
Anon, Not a lot to be found for this camera, Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Polaroid iS426 Camera Intro Review
Polaroid Digital Camera Manuals
Posted on Jun 27, 2016
Jun 27, 2016 | Polaroid Cameras
How do I import photos onto my computer
Many cameras were sold with a cable just for the purpose of transferring photos to a computer .other than that you have to put the pictures on an SD card and move them that way .
Mar 11, 2016 | Polaroid Is426 16 Megapixel Compact Camera...
How to delete pictures off camera ?
Two methods, one if this function is installed on your camera you can choose to format the card which will delete everything on the card.
Two if the above is not available you can put your card in your computer if there is a slot for it or connect your camera via USB to your computer. Locate the memory card and format it to remove everything, this is faster than choosing the delete option.
Jun 14, 2015 | Polaroid Is426 16 Megapixel Compact Camera...
How to take videos in wide angles on polaroid is426
go in to menu scroll to panarama mode press set go back to picture mode you should have wide mode
Feb 13, 2015 | Polaroid Is426 16 Megapixel Compact Camera...
Do i need a memory card for a polaroid is426
At some stage all digital cameras need a memory card as the internal memory will not be sufficient. Refer the instruction manual for how to select and install a memory card in the camera. You also will need instructions to make sure the camera can always save images and videos onto the memory card. Polaroid cameras use the SD card.
Aug 21, 2014 | Cameras
Polaroid IS426 wont turn on even after charging.
try to measure the battery if is okay, or display unit else check power supply
Aug 19, 2014 | Polaroid Cameras
Why has my Polaroid iS426 a permanent red light on the rear and will not power up!
Probably the battery is not charging. If it is older than 5 years, the battery could be bad. See if you can have it checked or replaced.
Aug 11, 2014 | Polaroid I Cameras
How do you zoom in on a Polaroid is426
I do not know your specific conditions when this happens to you. Generally, though, this will happen when your autofocus determines that what you are pointing at is too close to the camera for the level of zoom you have choosen. Try backing away from the subject and zooming in again.
Jun 14, 2014 | Polaroid Vintage 100 Black Instant Film...
My sound will not play on my polaroid iS426 camera how do i fix it?
There is no built in speaker in Polaroid iS426 camera. You can play your videos when imports on your PC. So don't worry about that.
Thanks
Fazal Zahoor Bangash from Pakistan
Dec 30, 2013 | Canon PowerShot SD1100 IS Digital Camera
Transfering photos from iS426 polaroid camera into computer
The best way to transfer pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo management program such as Picasa.
Organize edit and share your photos
Nov 14, 2013 | Polaroid Cameras
Polaroid i1236 Digital Camera Logo
290 people viewed this question
Top Polaroid Cameras Experts
Steven Wander
Steven Wander
Are you a Polaroid Camera Expert? Answer questions, earn points and help others
