Question about Garden
Husqvarna se 561 82
Fuel line arrangement
Where to find vent line on 359 husqvarna
Husqvarna chainsaw fuel line check and replace - YouTube
? 3:44
https://www.youtube.com/watch?v=8FyU_fG9qwc
Feb 6, 2012 - Uploaded by mweba1
359. ... Husqvarna chainsaw fuel line check and replace. mweba1. SubscribeSubscribed .... You will want to inspect the tank vent and fuel line.
Husqvarna common air leak - YouTube
? 1:51
https://www.youtube.com/watch?v=Z7f9zNQTJBQ
Apr 11, 2012 - Uploaded by mweba1
Husqvarna common air leak ... Husqvarna 136 ChainsawCarburetor Rebuild & Fuel Line Repair - Duration: 22:39. by donyboy73 59,377 views.
Husqvarna 359 Professional Chain Saw Review
Dec 14, 2015 | Husqvarna Garden
How to replace fuel pick up,line in Husqvarna 1414 chainsaw?
You need to remove carb and then you can access the hole for the fuel tank. you need to go to a Husqvarna dealer and get the correct line. if too big wont go in if too small will leak replace fuel filter when you do it.
Oct 14, 2014 | Husqvarna Garden
How to change fuel line on Husqvarna Trimmer 128L
They are juat a pull in fitting. Get access to the fuel tank, the broken fuel line should just pull out the tank. The new full line goes back in through the top, just pull through into the tank until the hole in the tank sits between the 2 flanges on the fuel line.
Mar 20, 2013 | Husqvarna 128L Line Trimmer
Need fuel line diagram for Husqvarna 322L trimmer
There are only 2 ways the pipes can go on. there is a fuel tank out pipe and a breather/return pipe.
Jul 04, 2012 | Husqvarna Garden
181 se chainsaw. runs for 30 sec then dies. new fuel new carb kit, completely cleaned, new plug
Check the fuel line going into the tank for holes or tears. When you get it to run for the 30 sec. it is running off the prime from the bulb. Once it is running it should be sucking gas through the fuel line to keep it running. A hole or tear in the fuel line will cause it to **** air and die out.
Jun 24, 2011 | Husqvarna ChainSaw 18 in Bar 32 HP Model...
I have a Husqvarna model 444 chain saw. The fuel pick up line disolved in the fuel tank. How do I replace?
order new fuel line and filter from www.randysenginerepair.biz
remove top cover, remove air filter, remove fuel line from carburetor, empty gas tank, pull remains of fuel line out of tank and replace with new.
Aug 25, 2010 | Husqvarna Chain Saw 20" Bar
Husqvarna 65 fuel line
This is Husqvarna.com manuals. You wlll need to find the IPL that applies to you. The exploded diagrams should help you trace the fue lines.
http://www.husqvarna.com/us/homeowner/support/download-manuals/
Lou
Aug 06, 2009 | Garden
Garden Logo
304 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
