Question about Mitsubishi WD-73827 73" HDTV DLP TV
Turns on then shuts off - Mitsubishi WD-73827 73" HDTV DLP TV
Which parts should be changed to solve the problem not to automatically shuts down
It depends on why it is shutting down. Is it overheating? Is it full of dust or pet hair? Does it shut down normally showing you a shut down screen or does it merely turn off. If it turns off, then I would check fans and heat pipes. IF it shuts down with a shut down screen you would want to check your windows install.
Oct 16, 2016 | Computers & Internet
Keep shutting off and it has good charge
Amazon.com: Customer Discussions: New Kindle Fire HD keeps ...
www.amazon.com/forum/kindle?_encoding...
Amazon.com, Inc.Nov 8, 2012 - My 1 month old Kindle Fire HD keeps spontaneously shutting off. I have made sure I am not accidentally hitting the power button. It gives no warning, just shuts ... Kindle Fire HD 7" won't turn on ...
Jan 16, 2014
my kindle keeps shutting off ...
Sep 21, 2013
My kindle won't turn on
Sep 10, 2012
New Kindle Fire keeps shutting down
Dec 11, 2011
More results from www.amazon.com
keeps shutting off Tablets & eReaders Questions & Answers ...
www.fixya.com > Forum > Tags > keeps shutting off
Jan 18, 2016 | Tablets & eReaders
Cruse control keep shutting off.
Probably the cruise servo to sensitive to load will need to replace,when you shut off it resets til the next time.
Mar 16, 2015 | 2006 Dodge Ram
Valve to toilet does not shut off water
IF the water wont shut off with the valve that is under the tank then you have to shut off the water to whole plumbing system.
Feb 08, 2014 | Home
Tv shuts off after 10 seconds
one of the energy cables is damaged, so tv 'safety protcol' turns on, not to burn shuts off.
go to service
Apr 18, 2013 | Sylvania 6427TE 27" TV
Reciever shuts off after turning the volume up
You will have to change the volume controller and its circuit board.
F150 Accessories
Aug 12, 2012 | Audio Players & Recorders
2000 corolla shuts it self off when tunr signal is turned on if you shut signal off car runs fine
You rstatment is odd but i think you said if you turn on the turn signal and have it turn it'self off by turning the steering wheel the engine shut's off but if you turn the signal off with the handle and everything is Okay? Or if you turn the wheel after making a turn the signal stays on till you turn it off with the handle. Or the car shuts off if you turn the whell with the turn signal on and as it shuts off the signal it stalls the car too.?
May 14, 2011 | 2000 Toyota Corolla
I cant turn off my shut off valve that goes to my
Hi!
Are you talking about the gas shut off valve or a water shut off valve(if you have a boiler)? Either way if you can't shut it off you need to get it replaced. Good luck!!
Dec 31, 2009 | Heating & Cooling
Receiver shuts off as soon as I turn it on
having the same problem. it doesn'T Shut off immediately. but after 30 seconds or if I turn the volume up, then it shuts off
Dec 05, 2009 | Denon Audio Players & Recorders
Is simply shutting the notebook a safe way to
The proper way to shut down a computer is to click on START - Turn off Computer - then click Turn Off.
Sep 28, 2009 | Toshiba Satellite A105 Notebook
Mitsubishi WD-73827 73" HDTV DLP TV Logo
263 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
