Installed new transciever in 2002 f 150. do the keys program the transciever?
CORRECT LICENSE KEY NUMBERS WILL NOT OPEN EITHER PREMIUM PROGRAM.
When you have problems with registration keys always contact the program owner ( Microsoft, Adobe etc) and explain the problem
they normally will send a e mail with a link to a new number
Apr 12, 2015 | Computers & Internet
How do I program new key switch to car after installing a new one
1999 you had to put ignition on and wait 10 minutes until security light stop flashing and came solid now it is program .Switch must be brand new ,from scrap wont work, 2004 ?
Dec 06, 2014 | 2004 Chevrolet Impala
My car will not start due to theft do i need to replace transciever ring or no
The car will need to be towed to the dealer and they can reprogram it. Be sure to bring ALL of you keys so they can program them all or the others will not work. This has to be done through their PATS system on their laptop. No other way around it.
May 21, 2010 | 2001 Ford Expedition
I want to know what the transciever is for when you buy a wireless ps3 controller
are you buying a offical controler?
what do you mean by transciever
if your buying this controler from a dodgy shop i think they are trying to trick you
Dec 27, 2009 | Sony Playstation 3 (PS3) Console
I have 2 of these installed on individual lights.
You can use the PHR03 wireless RF remote control or the PHR04 (key chain) both of which also _require_ the X10 pro transciever (PAT 01):
http://www.thehomeautomationstore.com/x10prowirelessremotes.html
You can also use the PMC01 Mini controller:
http://www.thehomeautomationstore.com/pmc01.html
You can also use the PHC02 Pro maxi controller:
http://www.thehomeautomationstore.com/phc02.html
Warning! This stuff is addicting :-)
Dec 10, 2009 | X-10 X10 Pro PLW01 Standard Toggle Single...
I have a '99 Ford Ranger 3.0L that won't start reliably(3 times in 2 weeks).When I turn the ignition to "on",the theft light flashes rapidly,and will eventually give me a 1:6 code(faulty link between PATS...
When the anti-theft light is flashing rapidly then either it is not seeing the key,or the transciever module is not communicating with the PCM. It could be the transciever or it could be the PCM is not powering up for some reason. I would first try replacing the PCM relay in the underhood fuse panel.
Jun 24, 2009 | 1999 Mercury Cougar
Please how do i get to activate a toshiba wireless mouse
just connect the transiever(the usb part) to the USB port.normally it will be recognized automatically. If not you shoul install the drivers. Dont forget to put batteries in the mouse. After that you should set up the connection between the transciever and the mouse. in most wireless mice there is a deep button under the mouse or hidden in the battery compartment you should push it and then push the button on the transciever( in some cases in the opposite order; first the transcievers button then the mouses button). usually an LED indicates that the connection have succeeded( either on the mouse or the transiever )
LEDs condition:
flashing on/off not connected.
continuous ON means connected.
Hope it helps
BR
/BS
Feb 18, 2009 | Toshiba Satellite A135-S4527 Notebook
2000 ford windstar anti theft light flashing vehicle won't start
This means that your key is not being recogonized.Ethier the chip in the key is bad or the patts transciever at the lock cylinder. Do you have a spare key? If not you will have to get 2 new keyss cut and programmed.
Feb 15, 2009 | 2000 Ford Windstar
Computers & Internet Logo
174 people viewed this question
David Payne
David Payne
