Question about Sharp Office Equipment & Supplies
U2 fault on Sharp AR-206
Sharp AR 206 Photocopier has U2 fault after changing toner cartridge
    Problem Solver:
  • 5 Answers
Error code U2 in Sharp copier AR 206 shows error or failure of toner crimp you can try to solve by replacing toner crimp
Or by reseting the error code by fallowing procedure
press c intrrupt 0 ( zero ) intrrupt contoneously after pressing all the light on control will go off then press 16 then press start switch
your prob will 100% solve.
if any more prob pl inform
Posted on May 27, 2009
How can i remove the error code u2 from my sharp AR 206 photocopier?
Mite need to have the firmware of the machine re-flashed get a tech out to look at your machine
Feb 23, 2016 | Sharp Office Equipment & Supplies
How to solve an U2 error on sharp 5316
http://olsonbros.com/sharp/support/sim.html
U2 04 EEPROM read/write error (serial communication
error)
11 Counter check sum error (EEPROM)
12 Adjustment value check sum error (EEPROM)
40 CRUM chip communication error
Jul 27, 2014 | Sharp AR-5316 Laser Copier Black OEM Toner...
Code erreur U2-40
U2-40, mostly appears in sharp copiers when you installing new toner cartridge.the reason of this code is faulty CRUM chip because of different type of toner manufacture .
you cane this problem by replace the chip in the new toner cartridge by the chip in old toner cartridge
- the chip is located in the rear toner cartridge -
I hope this help!
Feb 14, 2011 | Sharp AR-5316 Advanced Digital Imager...
I have a sharp ar-235 what does call service code U2-40 mean
CRUM chip communication trouble = the chip on the toner cartridge is faulty.
1, Try to clear the code press P, *, C, *, to enter the service simulation, on the key pad press 1,6, then the copy start, press execute on the screen.
2, Change the toner cartridge.
If it is a brand new one return to supplier as fault, if it is a refilled new one take back to supplier (the CRUM chip serves as a genuine supplies protection for sharp and 'blows' when the toner is empty the re-filler will have to put a new chip on it)
Nov 04, 2010 | Sharp AR-235 Copier
Sharp a163 photocopier ero u2 40 and h4
U2 40 is a CRUM comunication error with the toner (wrong toner chip on toner cartridge or wrong toner cartridge) try a new toner.
H4 is a fuser trouble code. Check to make sure all conection are right, Theres a few posible problems for H4, power board, MCU board, thermistor, or broken heat lamp.
Aug 30, 2010 | Sharp AR-160 Copier
Sharp AR 206 problem F2
change toner cartridge or the chip on the toner.
Feb 20, 2010 | Sharp Office Equipment & Supplies
Solution for SHARP AR 5127 error U2-40 call for service
This means that the cartridge's sensor is miscommunicating with the copier memory thus the code U2 -40. You should clean the inner sensor connector and the toner sensor of the spilled toner by low blower. Perform this code ;# , interrupt , C, Interrupt keys in that order and press 16 then Print key and the code will be cleared.
Feb 02, 2010 | Sharp AR-5316 Advanced Digital Imager...
How to reset u2-40 for sharp AR266 photocopier
Since this appears to be a non-US model I can only base my response on the closest US body type AR-M237.
U2-40 means the countdown (CRUM) chip in your toner cartridge either broke or went to zero. If you can put in a fresh CRUM chip in your cartridge, that's great, otherwise you'll have to replace the toner cartridge.
L4-01 means main motor lock, probably due to a brownout or otherwise missed timing. You can probably get by with a power off and on. Not sharing your copier with other devices on the same outlet will also help here.
To reset error codes, put the machine in test mode with the four-key combo: # - * - C - * ... 16-Start clears your U2 trouble, 14-Start and 17-Start clear the rest. Then hit CA and allow your copier to reboot. Good luck!
Jun 02, 2009 | Sharp AR-M237 Copier
Printer displaying an error message: 2U
There is a long list here for the U2 code so if you let me know I will tell you what it means..
Again what is the Last part of the Code?
If it is U2-40 code, it is a Crum Chip, Take the toner out clean the end of the toner cartridge, there is a chip, a small plastic connection piece with bronze/silver wire on it.
Or replace the toner cartridge.
You will also need to clear the code with simulation 16.
Turning the machine off might work but, not usually.
Oct 28, 2008 | Sharp AR-M205 Copier
What's U2 code and method for solution
U2 can have several indications.
The most likely one is that the chip that is on the back of the toner cartridge is not seated properly or has failed.
Try with the machine off, removing and inserting the toner cartridge several times to clean the contacts, next step is to try a new toner cartridge.
There is also a connector on the back frame of the machine that may be dirty or going bad.
Jan 16, 2008 | Sharp AR-5316 Advanced Digital Imager...
1,126 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
jasbo
jasbo
Adorjani Laszlo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
