Question about RCA E13309 13-Inch Diagonal XL-100 Color Television Television
Change my rca xl 100 to it video input without a remote
I have RCA XL-100 I need to change the input to rear video input inorder to connect my DVD and Playstation. Is there any one who knows how to do that?
    Sergeant:
    Champion:
  • 255 Answers
Ye a tech can do that.he'll make a extension of the video input at rear.or you can buy a switchbox for that.
Posted on May 20, 2009
Why can't i pick up channels using a RCA converter box, amplified HDTV antenna on my rca XL 100 analogue TV
If you live a good distance from the TV station you may need a better antenna. Did you do a channel search on the converter box? You'll need the remote for the converter box to change channels, not the TV's remote.
Jul 16, 2014 | RCA Televison & Video
RCA XL 100 Commercial Skip TV
Only thing I can think of here is to get a Universal remote, then try these pins to Sync your TV with URM:
RCA - 000,003,004,005,007,009,011,015,048,082,092,094,
096,098,101,102,103,107,113,125,129,067,179,187,188,191,194
May not work 100%, depending on remote functions.
Instead of just buying any, you could maybe borrow one from a friend first of all.
Oct 11, 2017 | Televison & Video
RCA XL 100 f19207bc menu button wont work
The front panel control buttons should be checked. Contact any service technician.
Oct 15, 2013 | Televison & Video
Connectding audio/video cables when you have a cable box and sound bar with dvd player
How To Connect a DVD Recorder to a Television:
1.If you want to use higher quality cables, then you may want to connect the TV Source (Cable and Satellite only, not Antenna) to the DVD Recorder using Composite, S-Video or Component video and audio cables.
2.To use composite cables (also known as RCA, the yellow plug is video, the red and white plugs, audio): Plug in the composite cables to the RCA outputs on the back of your TV source and then plug in the composite cables to the RCA inputs of the DVD Recorder. Then connect the RCA outputs from the DVD Recorder to RCA inputs on the TV.
3.To use S-Video and RCA audio cables: Plug in the S-Video cable to the S-Video output of the TV source. Plug in the S-Video cable to the S-Video input on the DVD Recorder. Next, connect the RCA audio cable to the output on the TV source and the input on the DVD Recorder. Finally, connect the S-Video cable and the RCA audio cable to the output on the DVD Recorder and the input on the TV.
5. To use Component Video cables and RCA audio cables: Connect the Component Video cable and the red and white RCA audio cables to the outputs on the TV source and the inputs on the DVD Recorder. Next, connect the Component Video cable and RCA audio cable to the outputs on the DVD Recorder and the inputs on the TV.
6. Now that the TV source (either Cable, Satellite or Antenna), the DVD Recorder and the TV are all connected, you need to configure everything to make sure that TV is coming through the DVD Recorder, for recording and viewing.
7. Turn on the Cable Box or Satellite Receiver, TV and DVD Recorder.
8. If you connected everything using the RF connections then the TV should be passing through the DVD Recorder and displaying Television on the TV screen. To record in this mode, you would need to tune to either channel 3 or 4 on the TV and then use the DVD Recorder TV Tuner to change channels and record.
9. If you made connections using either Composite, S-Video or Component cables, then to view or record TV, two adjustments need to be made. First, the DVD Recorder needs to be tuned to the appropriate input, typically L1 or L3 for rear inputs and L2 for front inputs. Second, the TV also must be tuned to the proper input, on a TV usually Video 1 or Video 2.
10. If you have a Dolby Digital 5.1 Surround Sound A/V Receiver you can connect either a Digital Optical Audio cable or Coaxial Digital Audio cable from the DVD Recorder to the receiver to listen to audio through the receiver.
Oct 17, 2011 | Televison & Video
The player does play the dvd's and everything but the picture wont show up in my television. I already connected the RCA connectors into the television and the player but still no picture. Please Help.
Assuming you used the standard YELLOW-WHITE-RED RCA cable, between the unit and the TV, the colours of each of the plugs should match both the outputs on the rear of the unit and the respective inputs at the rear of the TV. The TV must also be on an AV input 'channel' to receive the connected unit. (for example, AV1 or VIDEO 1)
Try changing the RCA cables - just in case the ones you currently have are defective in some way.
Being a combo unit, there should be a DVD-VCR common output on the rear - using RCA cable, the YELLOW is video, the WHITE is left channel, the RED is right - these MUST match the input on the TV, and the TV AV input must be selected in order to view the pictures and audio from the unit. To enjoy both VCR and DVD, using the RCA connection, the common output on the rear of the combo unit is recommended.
Better quality video is possible using S-Video cable (available from electronics stores such as Radio Shack etc. but this does not provide audio; you would still require RCA RED-WHITE cable for that, and your TV may not have S-Video input). Your TV may have a TV/AV button on the front - select the correct AV 'channel' with that if necessary.
It makes sense to check everything twice before assuming anything is broken.
Jun 28, 2011 | RCA DRC8300N DVD Recorder/VCR
My rca xl 100 remote will not work. I have changed the batteries multiple times. I was just wonder if i could buy a new rca remote and be able to have it work on my tv?
Yes,, you can easily purchase a new remote and have it work on that TV. In the packaging for the new remote you will find a piece of paper that contains the necessary remote codes for your TV. Follow the instructions provided with the remote and you are all set!
May 19, 2011 | RCA E13309 13-Inch Diagonal XL-100¿...
Dont have manual how do i change to watch a dvd
It will depend on the model but, you note which input you have the DVD hooked up to on the rear of the set---Component 1? 2? Then you use the input (some Mitsubishi's label it Device) and move until you are on the same input the DVD player is connected to.
If your DVD is HD you will if not using it for HD reception connect to the DTV input which is input on back---again not knowing the model number of your set--it is this simple---watch on whatever input the DVD player is connected to---most need a component input but some will use RCA which is yellow (video) red and white which are audio.
Component inputs require Green to green, Blue to Blue, and Red to red AND SEPERATE red and white for audio. 5 connections for typical component and three for RCA or composite.
Let me know if this helps you by rating this solution as I do this here for free.
REGARDS, SD TECH
Aug 14, 2010 | Mitsubishi Televison & Video
Need remote code for an RCA XL100 tv
I just programmed my RCA XL-100 today! The code is 11447
Jun 11, 2010 | RCA E13309 13-Inch Diagonal XL-100¿...
What channel does the TV need to be on to watch a
If your tv has input [rca connections] jacks, look at the original remote and use the input button.In some cases....pressing 00 on the remote will access an input. If you must a converter box...set your tv and the DVD player to channel 3.
Dec 25, 2009 | RCA F27442 27" TV
How to connect dvp 3356 t0 samsung 29 inch tv with crt tube.
Please check the connection. If you are connecting the 3 RCA cables to DVD component input/output, you need another pair of RCA cables to connect to audio out (FL&FR rear of DVD player) and Audio in (L&R) in your TV set. Else connect 3 RCA cable in 1-Video out & 2 Audio out of DVD player and 1-Video in & 2 Audio-in of TV.
Dec 15, 2009 | Philips Televison & Video
RCA E13309 13-Inch Diagonal XL-100 Color Television Television Logo
1,464 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
