Question about Water Heaters
Toto washlet Wand does not retract
  • 34 Answers
SOURCE: TOTO Elongated Washlet C100 Toilet stopped heating the water.
no there is not
Posted on Feb 05, 2009
  • 659 Answers
SOURCE: Toto C100 Toilet Washlet Seat
There are two types of bowls as far as toilets are concerned...elongated and round front. The seats are interchangable as long as there isn't anything different in the way the seat is mounted to the toilet. As far as I know and my experiance with both brands, I can't see any reason why it would not work.
Posted on Apr 08, 2009
gary1121
  • 332 Answers
SOURCE: TOTO WASHLET LEAKS!
from where?? If it is leaking on to the floor from the base of the toilet you need a new wax ring installed,,, if the water is comming out from where the tank bolts to the bowl you need to get the proper kit since it;s a toto they are one of a kind and don't have any universal kits that will work, call or e-mail toto tell them you need the tank to bowl kit, might as well tell them to send the flush valve also and just do the whole thing good luck
Posted on Jun 06, 2009
  • 151 Answers
SOURCE: had a new commode installed and now the washlet
check the GFCI outlet (ground fault circiut interupt) that the commode is plugged into there is two button on the outlet one is test and the other is the rest try pushing the rest button. If it kicks back off or doesnt take care of the problem call the installer.
Posted on Dec 24, 2009
jyackle5
  • 8197 Answers
SOURCE: Toto Washlet C100: main cleansing
If the front to back clean washlet is not working that means to get it to work you need to replace the seat. Call toto I heard that there was a recall on them.
Customer Service & Technical Support
Tel: 1-888-295-8134
custservice@totousa.com
techsupport@totousa.com
Good Luck
Posted on Dec 05, 2010
My seat is a few months old and stopped heating, any solutions?
If within a year of purchase it is still in warranty and Toto will repair it. Unfortunately they don't seem to offer on-site repair, you must remove and send it in.
Dec 20, 2010 | Toto Elongated Washlet C100 Toilet Seat -...
I have a toto wash let S#W 824 and would like to download the user manual. I bought it used with no manual.
Try the wizard of OZ after all he helped Dorothy and friends!!! On a serious note try the TOTO website?? Thing that make you go HUM....
Aug 20, 2010 | Toto Elongated Washlet C100 Toilet Seat -...
Shutting off water valve problems
Some shutoff valves are pretty marginal to start with, then they corrode. They can easily break if you put too much force on the handle. You are wise to be cautious. You will have to turn of the main water supply and then replace the toilet shutoff valve. You might be able to replace the shutoff valve yourself, depending on your skills and depending on how the shutoff valve is connected to pipe coming out of the wall or floor. But keep in mind that if you get in over your head you will have no water in the house until you get that new shutoff valve in place.
If you can describe what kind of pipe that shutoff valve is connected to I can help you understand if you should tackle it yourself.
Jun 29, 2010 | Toto Elongated Washlet C100 Toilet Seat -...
THE WATER KEEPS FILLING PAST THE OVERFLOW.
Replace fill valve. Fluidmaster works quite well and is very adjustable.
Jan 21, 2010 | Toto Elongated Washlet C100 Toilet Seat -...
Empty water from hot water unit?
Shut off the valves going into the top and connect a hose to the drain at the bottom. Open the drain valve and lift on the safety valve, on the side near the top. The water will drain out of the hose.
Dec 26, 2009 | Toto Water Heaters
Had a new commode installed and now the washlet toto won't work. what can I do to trouble shoot it
Dec 24, 2009 | Toto Elongated Washlet C100 Toilet Seat -...
Toto toilet: refill valve opens and closes rapidly
I believe you have a high water pressure going to the
tank. Minimize the water volume going to your tank. This is done by fully closing the inlet valve under the tank. Then open about 1/4 to 1/3 of the inlet valve. To do this, count the number of turns to get it full close from full open position. For 1/4, divide the number of turns by 4 and divide it by 3, for 1/3 open. Hope this will solve your problem.
Nov 26, 2009 | Water Heaters
Apr 05, 2009 | Toto Elongated Washlet C100 Toilet Seat -...
TOTO WASHLET LEAKS!
Feb 20, 2009 | Toto Elongated Washlet C100 Toilet Seat -...
Water Heaters Logo
51 people viewed this question
Top Water Heaters Experts
Donni Steen
Gil Shultz
Are you a Water Heater Expert? Answer questions, earn points and help others
