Question about Apple iPhone Cell Phones
I have an iphone5 it is showing in the top left corner SOS i have tried for 2 hours to find the off button or similar but to no avail. I can not ring out or receive calls & my texts are not going thru either
    New Friend:
    Problem Solver:
  • 5 Answers
The power button is located on the top of the iPhone. To turn it off hold the button down until "slide to power off" appears. Then slide the slider and the iPhone will turn off.
it sounds like you SIM card is not installed correctly or has not been activated by the network provider.
Posted on Apr 24, 2014
bdouglas
  • 290 Answers
SOURCE: phone won't ring in sleep mode
I had the same problem with my iPhone the only way I was able to fix it was to re-flashed the latest 2.2 firmware. Power phone off, power on by holding power and home at same time, hold power for ten seconds and then release still holding home key for another 30 seconds to put phone in DFU mode. Then plug into iTunes it will detect phone in recovery mode and allow you to re-image
Posted on Jan 08, 2009
bdouglas
  • 290 Answers
SOURCE: Display shows "SOS calls only"
Yes unfortunately it means the seller was dishonest when they said unlocked, but the other probability is that this phone for made for Europe only and is only a Tri-band GSM so it will only use one US frequency which means the phone isn't very useful here in the US. You can google for sites that offer unlock codes for a small fee.
Posted on Jan 09, 2009
  • 4 Answers
SOURCE: number 2 in the top left hand corner
this is due the fact that your mobile's line is set to line 2
in the ideal screen press # for a few seconds it may solve the problem
Posted on Jun 07, 2009
SOURCE: my w890i will not ring
press and hold the # key. or you may have your phone set on "light only" to fix this you will need to go into settings on the main menu(: hope it helps!
Posted on Jun 17, 2009
  • 87 Answers
SOURCE: MY PHONE SAYS PUK BLOCKED,SAYS CALL SOS.PHONE
see....note down your sim card number which is on the back of your sim.then from other phone call your customer care..and tell your sim number they will tell you the puck code now enter the puk code and your sim will start working...
Posted on Feb 18, 2010
My iphone5 has quit ringing when incoming calls come in & it also has quit alerting me when a text comes in
Check the small movable button on the left side edge of phone. Make sure "orange color" is not showing. If it is then it has been pushed to the silent mode. Simply push button back towards the front. Happened to husband twice.
Feb 28, 2014 | Cell Phones
I am trying to change to the new time and am pushing mode but can not get the hours to change.
Hi mca2529,
You can easily change the time of your Timex watch by following the steps below.
1. With the time and date showing, press the top left button.
2. Press the right top button (this sets seconds).
3. Press the bottom left button. This flashes the hour; press the top right button until you have the correct hour (there is no symbol for am, pm will show if pm).
4. Press the bottom left button, minutes flash. Press the top right button until correct minutes.
5. Press the bottom left button, month flashes. Press the top right button until correct.
6. Press bottom left button, date flashes. Press the top right button until correct.
7. Press bottom left button, day flashes. Press right top button until correct.
8. Press bottom left button, time format flashes (can be set to 24 hour clock). If correct, you're done. Press top left button if you're done (can be pressed at any step if you're finished).
To turn off the chime and alarm: Press bottom left until in the alarm screen. Then press the top right button repeatedly until the CHIME or CH symbol is gone and/or ALARM or ALM to disappear, then press the bottom left button to go back to main time.
Hope it helps.
Thank you for using FixYa.
Mar 13, 2011 | Timex 1440 Nylon watch
How do I set the current time on the Woods Digital Timer Model#59203?
78a8604.jpgWoods 59301
Manual for 59301
http://waterheatertimer.org/pdf/Woods-59203.pdf
Plug timer in wall for 1-2 hours so rechargeable battery charges
If display does not show after 1-2 hours, the battery is dead and timer is no good
After 1-2 hours, you can remove timer from wall to program
Press reset (R) with paper clip to clear memory
Select format: Press and hold Clock button until 12 hour or 24 hour shows on display, then release
Press hour button to change display to 12H
press Clock button and display returns to normal
AM shows in upper left corner
Set current time:
Press and HOLD clock button
While holding clock button, press hour button and minute button until display shows current time
Release clock button
Press and HOLD days button until current day shows in display
Release days button
Further instructions to set ON-OFF times are in manual (click link shown above for manual)
If you have problems, re-post additional question.
Oct 17, 2010 | Woods Indoor 24 Hour Digital Timer (59203)
How to set to 24hr mode for timex 1440 sports
Setting My Timex 1440 Sports Watch (4-button)
8. Press bottom left button, time format flashes ( now it can be set to 24 hour clock). If correct, you're done. Press top left button if you're done (can be pressed at any step if you're finished).
Feb 04, 2010 | Timex 1440 Nylon watch
Timex 1440 sports watch. How do you turn off the chime on the hour every hour?
Hi aburns983,
You can easily change the time and turn off the chime of your Timex watch by following the steps below.
Hope it helps.
Nov 05, 2009 | Timex 1440 Nylon watch
Pioneer super tuner3d
  1. Turn the radio off by pressing and holding the SRC button (under the label OFF).
  2. Press and hold the Audio button in the upper right corner of the radio. After holding the button for about 3 seconds, the clock will begin to blink (the hours).
  3. Use the up and down arrows to increase or decrease the time hours or minutes. Use the left and right buttons to toggle between setting the hours and/or minutes.
  4. When done, push and hold the Audio button again fir about 3 seconds until the clock stops blinking (hours or minutes).
Nov 16, 2008 | Pioneer DEH-1600 CD Player
Only First Phone in the system will ring on incoming calls
These manuals are available on the norstar web site.
Jul 08, 2008 | NorStar M7310 Corded Phone
SET THE TIME
: 1. With the time and date showing, press the top left button. 2.Press the right top button (this sets seconds) 3.Press the bottom left button. This flashes the hour; press the top right button until you have the correct hour (there is no symbol for am, pm will show if pm). 4.Press the bottom left button, minutes flash. Press the top right button until correct minutes. 5.Press the bottom left button, month flashes. Press the top right button til correct. 6. Press bottom left button, date flashes. Press the top right button til correct. 7. Press bottom left button, day flashes. Press right top button til correct. 8. Press bottom left button, time format flashes (can be set to 24 hour clock). If correct, you're done. Press top left button if you're done (can be pressed at any step if you're finished). To turn off the chime and alarm, press the top right button repeatedly until the CHIME or CH symbol is gone, then press the left top button. Repeat for alarm but watch for the bell icon or ALARM or ALM to disappear, then press the top left button.
Feb 16, 2008 | Columbia All Sport watch
Cell Phones Logo
41 people viewed this question
Top Apple Cell Phones Experts
David
Martin Murray
Are you an Apple Cell Phone Expert? Answer questions, earn points and help others
