Question about RCA E13309 13-Inch Diagonal XL-100 Color Television Television
Change video input witho remote
No there are no seperate in url or any thing just the three yello, white,red video inputs onlyl is there way to change the tv to that video input manually without the remote?
  • 864 Answers
There might be an input button or menu button on the front of the TV (or behind a door or panel) that will let you set it for video input.
Posted on May 20, 2009
Rgb internal wires which ones can u use to convert it into red, white and yello at other end for tv
RGB is a term that means the guns in the crt or other display are only driven by amplifiers for that color. So you have to have seperate signals and inputs for red,green and blue. Those come from the source in that method. They are then fed into the monitor for which each of those colors has its own channel and amplifier. If you dont have something that is supplying the RGB singals then it is of no use. The colors that you listed as red white and yellow are for COMPOSITE video with AUDIO. The yellow is the whole video signal and the red and white are stereo sound signals. No attempts at making that work will correct this unless you buy a converter.
May 14, 2014 | Philips 107E66 17" CRT Monitor
I have a video game don't know where to put the whight and yello cords colors don't match up
if you have a tv that has a red, yellow, and white inputs then you put in the corresponding jacks into them. if your tv only has a yellow and a white inputs, you can ignore the red wire. most important note though is that the yellow wire must match the yellow input as that is the video cable.
Jan 21, 2014 | Video Game Consoles & Games
I plug the white, yellow and red cables from the dvd player into the back of the tv but it says "no signal". I changed the input to Component 1 then I tried the other plugs too but still get the...
Hello
If you have connected the red, white, and yello video cable connection right correct to the respective pins; both at DVD and TV end, by selecting the input to Video-1 or Video-2, you must get the logo of the DVD player on the TV screen. Please not that whether you have 'Power ON' the DVD player. If the connections are good, the logo must be ther. Otherwise check the continuity of the RCA cable, of it may have damaged[shorted]. Try replace with an other cable. OK.
Aug 15, 2011 | Apex Digital LD4088 LCD TV
I am trying to hook up my Vcr to my television set
connect vcr video output to tv video input with yello cable then connect audio output to tv audio input with white or red cable then change tv video mode to AV
Aug 11, 2011 | Televison & Video
II HAVE A 13 INCH BRAND MODEL DWT 1304. I JUST WANT TO USE IT FOR A DVD PLAYER. I HAVE NO REMOTE ,HOW DO I CHANGE THE TV TO PLAY DVD OR VEDIO
Connect the composite video RCA (yellow) cable output of the DVD player to the TV's video input RCA (yellow jack). Connect the red and white RCA cable from the DVD players audio output to the TV's audio input (red and white jacks). Select the source input from the TV's control panel - if it has an input selector switch, set it to select the video source from the front panel input jacks if you connected the three cables - yellow, red and white on the front of the set. Or, change the channel to receive the video auxiliary input source instead of the broadcast station.
Dec 20, 2010 | Durabrand DWT1304 13" TV
Dont have manual how do i change to watch a dvd
It will depend on the model but, you note which input you have the DVD hooked up to on the rear of the set---Component 1? 2? Then you use the input (some Mitsubishi's label it Device) and move until you are on the same input the DVD player is connected to.
If your DVD is HD you will if not using it for HD reception connect to the DTV input which is input on back---again not knowing the model number of your set--it is this simple---watch on whatever input the DVD player is connected to---most need a component input but some will use RCA which is yellow (video) red and white which are audio.
Component inputs require Green to green, Blue to Blue, and Red to red AND SEPERATE red and white for audio. 5 connections for typical component and three for RCA or composite.
Let me know if this helps you by rating this solution as I do this here for free.
REGARDS, SD TECH
Aug 14, 2010 | Mitsubishi Televison & Video
Have a rca tv.....hook up the new sony dvd...yello red and white...but when we hit the remote for tv to dvd....... nothing happnes???????
sounds to me you need to get to the video mode okay look for a video button on the remote or try to see what input says in your menu for set up okay hope this helps great day
May 11, 2009 | RCA TruFlat 27F520T 27" TV
DVD player won't work on my 27gt615
alexa,
good day, if youre saying that you program the DVD to work on channel 2 or 4 does it mean you convert the signal of your dvd player from A/V output to RF out?
because the simpliest way to connect your DVD player to TV screen is by using RCA cable ( 3 wired cable being color marked as yellow/red/white) yellow = video red and white = audio
the connection would be: from dvd back part you'll see colored socket yello/red and white. connect the RCA to those socket following the same color .
and from the TV screen there should be A/V input socket. can be locate at the BACK/Side or FRONT of the screen marked as
"INPUT" ( AV1, AV2,AV3 if multiple inputs). Then select which input you want to place your DVD player ex.AV1 (from AV1 there will be 3 scoket in a row, yellow/red/white)
Connect the other end of your RCA cable following the same color code to TV "AV1 INPUT" yellow = yello/red =red/white=white. then from the remote commander of your TV screen locate a button marked as "TV/AV" or "A/V" press this button until the screen display switch to AV1.
cheers,
mark
Jan 31, 2009 | GE 27GT619 27" TV
Have a Sanyo DP42828(42"). My Satellite is working after the card resetting itself. But which 3 holes do I hook the (RED, YELLOW, and WHITE) for the dvd player?
dems,
Are you reffering to your DVD player to be conected to with your TV screen?
For DVD player connection the 3 colored RCA jack socket are:
YELLOW = video out
RED and WHITE = Audio out (left and right channels)
to hook up to your screen, at the back of the screen or side of it you'll see RCA socket indicating "AV1" "AV2" AV3" this are all Audio/video inputs where you can hook up all you A/V device or game consoles. These inputs also have the same 3 colored socket (yello = video red/white = audio)
connect your DVD player to any of this input following the same color code.After connecting the cable, select the input where you hook up your dvd player. Do this by pressing "A/V" buttons in remote commander of your TV. continously press this button until it reaches the exact location where you plug your player ex. AV1, AV2,AV3
note: in some cases the remote commander doesn't indicate this A/V button but a picture of a box having a arrow pointing inside the box.
cheers,
mark
Jan 05, 2009 | Sanyo DS31590 31" TV
I am hooking up a dvd player with the black and white wires
The most basic hook up you can do is use a composite AV cable(yello/red/white). This cable should have come with your player. Check your TV it has those available inputs. They are also color coded. On the back of your player, there is only one yellow colored jack so there should be no problem in identifying where to plug the composite video cable(yellow). Put the composite audio cables (red and white) to the DVD player Audio Out jacks (red and white). Then plug the other end of those cables on the back of your TV. Just make sure they are INPUTS on the TV and colored the same - yello/red/white.
Then find your TV's correct viewing channel. It is not channle 3 or 4. Depending on the TV brand, it may be called AV, INPUT, VIDEO, GAME, SOURCE, AUX, EXT., etc. To find that channel, you may need to check the instructions on your TV manual. Most of the time, there are buttons on the TV remote control or on the TV itself. Sometimes, you need to go into the TV Menu.
Mar 27, 2008 | Philips DVP5140 DVD Player
RCA E13309 13-Inch Diagonal XL-100 Color Television Television Logo
537 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
