Question about LG Televison & Video
Dvd player plays erratically - LG Televison & Video
Panasonic SA-BTT282 not reading blu ray, please help!
If the play function is erratic, the drive may have failed.
Jan 26, 2015 | Panasonic Televison & Video
My memorex dvd/cd player only plays black and white dvds
see this causes: and fix it . God bless you
  1. Disc loaded upside-down.
  2. Transportation lock engaged.
  3. Dirty, scratched, or defective disc.
  4. Dirty or damaged objective lens.
  5. Loading (mechanical) not completed reliably.
  6. Damaged lens suspension or damaged lens cover preventing free movement.
  7. Dirt, gummed up lubrication, or damage in sled drive mechanism.
  8. Dirty/defective limit switch or sensor.
  9. Defective spindle motor.
  10. Spindle table height incorrectly set.
  11. Bad component in optical pickup.
  12. Cracks in ribbon cable to optical pickup.
  13. Need to adjust servo (or less likely, optical) alignment.
  14. Faulty power supply, electronics, or control logic.
  15. Bad connections including missing/erratic optical deck shield.
  16. External interference.
Sep 23, 2012 | Memorex MVD2050-BLK DVD Player
The plaver will not play says HO2
1) Dirty or poor pick-up.
2) Sled motor sticking (bad sled motor or contaminated lubricant on the sled rails).
3) Faulty spindle motor. (especially if spindle motor is spinning with top off and no disc inserted).
DVD-RV31 also tends to suffer from dry joints to the surface mount IC's and that could cause all sorts of erratic operation.
Feb 03, 2010 | Panasonic DVD-RV31 DVD Player
Erratic operation of DVD players after a few months of non-use
what you should do is to clean the OPTICAL LENS directly with a dry Q-tip , could be that it collected some dust and thats why its playing erratically, give it a try , AJ
May 29, 2009 | Toshiba SD-1800 DVD Player
Error reads bad disc. plays on other players,all discs.
This is due to faulty DVD lens/head. Try cleaning it with DVD/CD lens cleaning CD.If still the problem persists, contact near by service center for replacing the faulty Lens.
Mar 12, 2009 | Daewoo SD-8100 DVD Player/VCR
Memorex MVD2050 problem with buttons on machine
Hi..
No offense but Memorex is junk.
Get you money back and try walmart or someone else
Dec 26, 2008 | Memorex MVD2050-BLK DVD Player
Audio static and video skipping during DVD play
Hello billandanita. Have attempted a disk player cleaning? If not purchase a disk cleaning pack from a local electronics supply/repair store. Asking a local repair shop will get you the best cleaner available. Good Luck.
Sep 29, 2008 | GoVideo Go Video DVD/VCR Combo
DVD video player problem
your laser is getting weaker now, if you have thoroughly cleaned then it needs a replacement now.
Apr 29, 2008 | Samsung DVD-V4600 DVD Player/VCR
More than 75% of the time, the erratic behavior of dvd playing is caused by defective dvd disc.
  • You said you rent them from netflix.. so check the condition of the dvd disc surface first. make sure it's not scratched or dirty with finger prints or smuges.
  • always practice to hold dvd discs by the edge and do not touch the data surface(bottom).
The other 25% of time is the dvd player's inability to track the disc properly. Most DVD players on the market today uses 3-beam pickup tracking method. Sometimes the optical eye (tracking device) goes bad and start giving above discribed symtoms. There is a dvd player cleaning disc you can buy on the market (radio shack) too. It has little gentle bristles on the disc to rub off the dust on the surface of the optical eye of the dvd player.
Regards,
Feb 16, 2008 | Televison & Video
Televison & Video Logo
13 people viewed this question
Computer Repairing
Computer Repairing
