Question about Mint Automatic Floor Cleaner
Beeps while charging - Mint Automatic Floor Cleaner
Does not charge
Check to see if the two charge contacts on the bottom of Roomba are making contact with the two contacts on the charger. Also has something covered over the contacts or have they corroded?
May 20, 2014 | iRobot Scooba 350 Robotic Vacuum
Roomba 4220 light says charged but wont turn on
Try resetting
to reset the charging system. You can do this by removing the battery from the robot and unplugging the charger from the wall and robot. Please hold the power button down for 30 seconds. You then should charge the robot....."
Dec 29, 2012 | Vacuums
Scooba beeps 4 times
  • Lift Roomba off the floor and place it in the center of the room and restart the clean cycle.
  • If Roomba did not resume cleaning, lift Roomba and turn it over.* Inspect the Side Wheels for dirt or obstructions.
  • Test the Side Wheels by pushing them in and out and making sure they rotate freely. Place Roomba in the center of the room and restart the clean cycle..
  • Dec 22, 2012 | iRobot 5800 Scooba Vacuum
    What are these 2 blinking lights on my irobot roomba?
    "The Charge Indicator Light is located immediately to the right of the power button on Roomba Red and Roomba (sage). On Roomba Discovery and Discovery SE, the Charge Indicator Light is incorporated into the power button. Please refer to the table below to determine what the Charge Indicator Light is telling you.
    * Pulsing Amber - Charging
    * Green - Fully Charged
    * Amber - Partially Discharged
    * Red - Almost Fully Discharged
    * Flashing Red - Fully Discharged"
    At the end of a cleaning mission, Roomba will tell you if it has successfully completed it's mission or not:
    GREEN = MISSION COMPLETE
    YELLOW = MISSION ABANDONED (Check robot's brushes, etc.)
    YELLOW RED POWER BUTTON = BATTERY DEPLETED (Scheduler Models)
    RED YELLOW POWER BUTTON = BATTERY DEPLETED (Discovery Models)
    number of beeps after ?uh-oh? :
    No beeps: A wheel is stuck or is not touching the ground. Pick up the robot, place it down securely on the floor and touch the clean button to restart the cycle.
    1 beep: The main brushes cannot turn. Turn over Roomba and remove the brush guard by pushing the two yellow tabs. Remove the brushes, clear any obstructions, and replace them again.
    2 beeps: The side brush cannot turn. Turn over Roomba. Look to see if something is wrapped around the side brush. Remove the side brush with a screw driver and check for string or hair that may be wrapped around it.
    3 beeps: The vacuum cannot run Remove and empty Roomba?s bin.
    4 beeps: A wheel motor cannot run Your Roomba may be stuck or something may be wrapped around a wheel. Look for something wrapped around the wheels. Push them in and out and make sure they turn easily.
    5 beeps: The cliff sensors have failed or are blocked. Turn over Roomba and clear any debris that might be caught underneath the front bumper in the cliff sensors. You can also use compressed air to clean them out.
    6 beeps: Wheel obstruction or robot attempting to drive over an obstacle. Turn over Roomba and remove any obstructions that prevent the wheels from seating all the way up into Roomba?s body. Also, remove any obstacles that Roomba could drive over.
    7 or 8 beeps: Not applicable Roomba?s beep codes do not include 7 or 8 beeps. If you are getting an error with 7 or 8 beeps, try counting again or contact iRobot Customer Care.
    9 beeps: Sensor error Please contact iRobot Customer Care.
    10 beeps: Roomba is stuck Pick up Roomba and start it again somewhere else. Use a virtual wall or other barrier to keep Roomba away from the
    place it got stuck.
    Your Roomba may be experiencing an issue where the battery is deeply discharged and may need to charge longer than the standard 3 hours. (or 7 hours if you have a standard charger)
    Even with the charging light showing green (this indicates a fully charged battery) the robot is still charging. If your Roomba exhibits behavior where it charges for a short time then runs for a short time you will need to do the following.
    1. Plug the charger into Roomba (if you have a home base be sure to plug directly into Roomba instead of using the home base, this will ensure the robot's charging cycle is not interrupted.)
    2. After the Roomba's charging indicator goes to solid green please keep the Roomba on the charger for an additional 72 hours. (3 days)
    3. After the 72 hours (3 days) has passed, turn your Roomba on and begin a normal cleaning cycle. If this works successfully it may take several uses for the battery to get back up to the performance it once had.
    If this does not correct the problem, please call customer support at 877-855-8593
    Nov 22, 2012 | Vacuums
    Scooba 5800 starts to charge then beeps loudly
    1) test the batteries very well in another device.
    2) test the charges if working properly.
    3) test the power inside from scuba, some electronic components like diode, or capacitor is draining the batteries. repair or rreplace.
    God bless you
    Sep 19, 2012 | iRobot 5800 Scooba Vacuum
    My roomba stays in one spot and cirles like it's spot cleaning and it's not. It won't move around like it use to,i haven't used it in some time altho it is charged.
    You need to clean the sensors.....you have pets...the dander gets on the sensors...it's a common issue. (See...you didnt even tell me you had pets!)
    Mar 22, 2010 | iRobot 530 Roomba Vacuuming Robot, White...
    560 backs out of charging base then only turns in right circles
    Yes, this is known issue and if your bumper moves freely, you might be facing a sensor fault caused by poor quality of components.
    Here is a guide to fix it
    http://www.schneordesign.com/Avi/irobot/roomba_mod2.htm
    Have fun
    Avi
    Dec 05, 2009 | iRobot Roomba 560 Robotic Vacuum
    When i charge,the service light is on and beeping
    get back to the person that you bought it from i would think they would give you some kind of waranty.i don't trust buying from ebay .i hope you didn't pay a whole lot for it.send an email to ebay themselves.please leave feedback
    May 04, 2009 | iRobot 5800 Scooba Vacuum
    Mint Automatic Floor Cleaner Logo
    123 people viewed this question
    Top Mint Vacuums Experts
    JoeVacs
    Are you a Mint Vacuum Expert? Answer questions, earn points and help others
