Question about Panasonic KX TG2553B Cordless Phone (KX-TG2553B)
Phone is not charging
My Panasonic cordless phone-The speaker sound was very weak from the very beginning,recently I disconnected the battery and on reconnection the phone has dropped dead even replacing the battery hasn't solved the problem
    President:
  • 1,952 Answers
Check ur phone soundspeaker
Posted on May 20, 2009
Buttons don't make any sound but can hear dial tone, speaker phone doesn't work, phone dies fairly quickly - would this all be caused by bad battery and what is the life of battery in a Panasonic cordless...
First off, try changeing from tone dial to pulse dial and try calling out. If that does'nt work, touch bad is probly bad. As far as the speaker phone it does not work off battery's it works from the main base which is powered from the A/C. And for the battery life, when you have a cordless phone you have to build the life to the battery, what I mean is : first time you charge it for 12-14 hours, after that use the phone and do not put it back into cradle, the battery will hold a charge for 8 hrs, if you use it for 30 mins and put back on cradle untill next use, use another 30 min and continue doing this the battery will build its life to 30 min and always die after 30 min, try to get into leaveing off cradle all day and charge while you sleep and keep off cradle all day.
Nov 07, 2013 | Panasonic Lands Phones
Phone will not charge
No reset button, it sounds like the internal handset charging circuit is blown.
Mar 12, 2012 | Panasonic Lands Phones
Turn ringer on
Go to Settings > SOUND > Silent mode (No sounds except media and alarms).
If this is ticked (on), it means umts smartphone alarm will sound even if you make the phone silent.
Regarding the loud sound even after reducing ringer volume, no idea for this.
Dec 03, 2011 | Panasonic KX-TG2383 Corded Phone
Phone turn off when speaker is turn on and it disconnect when it turns off
If it is the handset speakerphone, this usually means the battery is dying. The speakerphone uses more power than the regular phone, so when you turn on the speakerphone with a weak battery the handset will shut off and disconnect the call. You likely need a new battery.
Mar 23, 2011 | Vtech DECT 6.0 Cordless Phone with Digital...
My panasonic kx-t7730 proprietory phone does not power on
Hi,when a phone does not come on, it is either the battery of the phone is dead,
might need to be charge or replaced with another battery.
you can use another battery to test if it is the battery the fault.
The other thing to check is if the phone memory is weak and may need to be restored
back the phone memory.
will need to be flashed.
Take care.
Aug 04, 2010 | Uniden TRU9480 Cordless Phone
Nothing shows up in the display. This has only been recently after a power glitch. The display lights when a call is made or received.
I unplugged the base unit from the wall for more than 10 minutes. Sometime after I plugged it back in (not immediately)the display re-appeared.
Nov 16, 2009 | Panasonic KX-TG2631 Cordless Phone
I have a cordless KX-T7885 and can't get the battery to charge. i replaced the batteries and both phones but they both will not work. They sat for two years and I have just recently tried to use them. They...
If you have a multi-tester, check the voltage on the battery packs. The voltage should be equal to or greater than the voltage listed on the battery pack. If the voltage on the packs is too low, either the battery packs are defective or the charging systems of the phones are not operating properly. If the phones are not charging properly, it is likely not cost effective to try to get it repaired.
Oct 10, 2009 | Panasonic KX-T7885 Cordless Phone
Phone sounds like going underwater, buzz noise when headset in
it sounds like u have fitted a cheap double phone line adapter try removing same and see if sound improves
Jul 21, 2009 | Panasonic KX-TG2431 Cordless Phone
Battery fully charged but phone dies within a minute
A friend that worked for GTE advised me some yrs ago to do this and I have NOT had a problem with another battery since
when you get any new Battery charge it plugged in to the ac AND phone jack for a minimum of 24 hrs without using it.
all batteries have some memory and deminish power over time but if it was NOT fully charged to begin with as a yr goes by so does the battery life. hope this works,
Apr 16, 2009 | Panasonic KX-TG5438 5.8 GHz Cordless Phone
Possible battery going bad???
The signs of a bad battery are: going to static while talking on it, going dead after a short period of time, or needing constat charging.
Apr 13, 2009 | Panasonic KX-TGA552M Cordless Expansion...
Panasonic KX TG2553B Cordless Phone (KX-TG2553B) Logo
184 people viewed this question
Top Panasonic Lands Phones Experts
guyvstewart
george  peters
george peters
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
