Question about Vehicle Parts & Accessories
What the format for a 1997 jeep wrangler cd player
Need to know the format for my stock 1997 jeep wranglers cd player
    Sergeant:
  • 384 Answers
That means u got to take it to the dealer so they can plug a computer into it and make it work
Posted on Jan 01, 2014
Hello, how do I reset the fuel shut off switch on 1997 TJ 4 cylinder. 1997 jeep
its not a FORD, why would you thing a jeep is a ford?
is stock car , USA stock car (we are USA forum, )
then this book cover all that. its called the FSm.
http://www.jeep4x4center.com/knowledge-base/index.htm?utm_source=cj#service
ever wire, every bit,
why assume it has an inertial switch. ?
here is the truth.
  1. check all fuses first, (using a meter, no guessing)
  2. check fuel pressure, ah 0psi cranking,
  3. Check engine light must glow key or PCM is dead. (fuses)
  4. I check voltage at fuel pump relay output, its 0v cranking
  5. bad relay or PCM sees no spark.
  6. got 12v there, but not at pump cranking, bad wire .connector on way to pump.
  7. if 12vdc at actual pump and dead pump that is a bad pump. (0psi pressure)
Mar 09, 2015 | 1997 Jeep Wrangler
I need a serpentine belt diagram for a 1997 jeep wrangler
taking a shot in the dark most common is 4.0liter with a/c but let me know if different .
Oct 20, 2010 | 1997 Jeep Wrangler
1997 Jeep Wrangler 4wd high disengages
you might try checking the linkage on trans case shifter. may need adjusting. might not be getting fully engaged
Feb 06, 2010 | 1997 Jeep Wrangler
Factory cd player doesn't play aftermarket burned cd's
What format are you burning them in? CDA or MP3 most Factory units will only play CDA format, just pick you up a copy of Nero and choose Aduio CD, it will convert you MP3 format to CDA and you should be able to playthem with no issue, the CDA format also works in the old portable CD players as well...
Hope this Helps,
David
If my solution was helpful please rate accordingly.
Mar 17, 2009 | 2002 Jeep Wrangler
Electrical ?
I have a 1997 jeep wrangler with the same problem and it started when I replaced the stock radio,with an after market one. The dash/parking lights are grounded to the stock radio,so if you can find a good body ground that should fix your problem. good luck.
Oct 25, 2008 | 2003 Jeep Wrangler
Cd player
remove ash tray one screw behind there, then remove top dash panel that goes from end to end across dash this just snaps off pull upward to remove you will see 2 screws on top of trim around radio remove these 2 and then dash trim will pull off pull straight back then radio can be removed should be held in by 2 10mm bolts, this should cover 80% of the radios (important TIP) if it still doesn't come out the trick is some of the wranglers have an extra security bar on stock cd players only you will see 2 more 10mm bolt on the top of the dash where you removed the 2 screws from earlier these hold a bracket that is mounted to the back of the cd player once they are unbolted you can remove the radio it takes some pulling and tweaking of the brackets but it will come out
Jun 12, 2008 | 2002 Jeep Wrangler
Eer cd problems
Some recordable compact disc media, such as CD-R and CD-RW, may not comply with the standard CD format used in automotive CD players. When these CD's are used, customers may encounter error messages, skipping, or delaminating of the labels, which can cause an eject failure. It is important to question whether these kinds of CD media are being used. When customers encounter these symptoms, check the system with a known playable CD. Explain that the media may not be compatible with some automotive CD players. Replacing or exchanging the CD player will not address these issues.
May 14, 2008 | 1993 Jeep Grand Wagoneer
Vehicle Parts & Accessories Logo
59 people viewed this question
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
