Question about Visual Land - VL-879-8GB-BLK - Connect 7 Tablet
Screen has no picture
Product has no picture. we have charged the tablet and press and hold the power button for the 3 to 5 seconds and the screen has o picture. my son was playing his games when the screen just went blank. I told him it needed charged and he plugged it in and still no picture.
Brand new tablet will not turn on
Make sure it is fully charged. Hold power button down for about 10 seconds and wait if nothing comes up press power again for half a second. Still nothing? Then put it on charge, it should show that it is charging with a light of a picture on the screen. If there is no sign of charging, wait about 3 hours leave the charger connected and press the power button again for about a second and wait for it to turn on or for the picture to show it is charging appears on the screen, (make sure the charger is on and connected) . Press the power button again for another 5 seconds and wait. sometimes it takes a little while to turn on, especially if the battery is very flat. Other things to try are check the charger on another device e.g. another table or a phone if you can and try another charger on the tablet if they are compatible, (usually the same plug is o.k, check the voltage is the same. most chargers are USB 5v). It may need a more powerful charger than most small phones,. you can try plugging the USB cable into a car charger or USB 3.0 port on a computer. 2 amps is common for most tablets. Apple may be different, hard to be exact without knowing brand etc.
If all else fails see the retailer
Dec 26, 2017 | Tablets & eReaders
My tablet will not turn on after charging it all night. Can I change the battery?
press and hold the power button 10 sec ?
Press and hold both power and volume down buttons for 10 seconds, then release vol. down button while holding down power button for another 10 seconds, before releasing.
plug to pc and wait to be recognized?
take out the battery so that samsung fully discharge so this should help reset replug the battery.
Jan 04, 2015 | Supersonic 9.7" Android Tablet SC-97JB
How do manually reset sansui lifepad to factory default settings
Try this:
1. Hold down power and volume up buttons for 10 seconds, then press volume down button.
Failing that, this:
1. Turn tablet off. Hold down power button until 'Device Option' menu appears.
2. Select 'Power Off' then 'OK'
3. When tablet has switched off, hold the 'Reset' & 'Power' buttons simultaneously for about 10 seconds.
4. Wait for screen display, then press 'reset' button.
5. The 'system recovery' screen should appear.
6. Use 'Home' & 'Menu' buttons to navigate the menu.
7. Select the 'wipe data/factory reset' option & press 'Reset' button.
8. Then select 'Yes- delete all user data' & press 'Reset' button.
9. Press the 'Reset' button to reboot/restart tablet.
Oct 15, 2014 | Computers & Internet
New tablet just purchased fully charged it then pressed power button as instructed but nothing happens, black screen ???
have you tried pressing and holding the power button for a few second?
also try and charge it before turning it on.
Mar 12, 2014 | Leader Impression 7 Tablet
My galaxy tablet will not turn on and or charge
hold the power button down for 10-15 seconds to force a power off. When turning back on, hold the power button down until you either feel it vibrate or something comes up on the screen.
Jan 13, 2014 | Samsung 7 in. Galaxy Tab 3, 8GB...
Help how do hard reset my proscan tablet plt7035 i for got my pattern to unlock it
1. Power the Tablet off.
2. Press and hold the Volume Down button of the device, then press and hold the Power button.
3. Continue to hold both buttons until a bootloader screen appears.
4. Wait for the prompt that says to "Press <VOL_UP>" then press the Volume Up button to start the process.
5. Navigate to Erase content.
All info on tablet will be deleted but not the info in the SD card
The tablet will complete the hard reset process and reboot into a factory default state.
Oct 19, 2013 | Proscan Recertified - PLT7035 4GB NAND...
My coby MID7012 isn't going to the home screen after I charged it. Its flashing coby over and over. But its not turning on. What do I do?
Sounds like you are in a "Boot Loop". Let's try to break the Boot Loop. Plug the device into the charger, then press and hold the power button for 60 seconds - make sure the device is OFF after the 60 seconds. Let change overnight. Next Day, unplug the device from the charger, then press and hold the power button for 30 seconds, wait 30 seconds, press and release the power button normally, the device should be out of the Bootloop.
Jun 12, 2013 | Dell Android 2.3 Touchscreen 7" Internet...
I have a zto tablet android 4 and when i power on its says android word appears and just stays on like that
Sounds like you are caught in a Bootloop for some reaso. Press and hold the Power Button for 40 seconds, release. Then plug the device in a charger, let charge for 4 hours while powered down. Unplug the device from the charger:
Step1 : Press and hold the Power Button for 30 seconds, then release the power button.
Step 2: Press the power button for 1 second, release and press the power button again, release.
Step 3: Is the device booting normally? If no, contact the manufacture for a replacment.
Jun 08, 2013 | X10 AirPad 7" Android 4.0 Tablet
Dragon Touch tablet. It is charged. Why won't it turn on?
PRess and hold the volume up button and then power button together for a few seconds
Dec 24, 2012 | Android Tablets & eReaders
When I try to charge my samsung galaxy tablet a yellow triangle pops up on the battery sign
I had this same thing. The Batter image had a red line on the right side and the yellow triangle had an explanation point in the middle.
I searched the net and found a few solutions.
1. Hold the power button down for 30 seconds.
2. Hold the power button down and the volume down button at the same time for 30 seconds.
3. Just let it charge and over night and it should go back to normal.
I did all 3, in the order I wrote them. While in step 3, after about 5 minutes I pressed the power button and it showed that it was charging normal.
Hope this helps.
Dec 04, 2012 | Samsung Galaxy Tab Tablet PC
Visual Land - VL-879-8GB-BLK - Connect 7 Tablet Logo
47 people viewed this question
Top Visual Land Computers & Internet Experts
David Payne
David Payne
Are you a Visual Land Computer and Internet Expert? Answer questions, earn points and help others
