Question about Air Hogs Toys
Airhog flights my airhog bomber helicopter only flies for exactly 4 SECONDS, then crashes, even though there are fresh batteries, and are both (remote and helicopter) fully charged.
    Sergeant:
  • 290 Answers
Either you are klutz or it's probably defective if it is simply loosing power. A loose wire would be more erratic but check for other loose items. Clearly you have a failed connection somewhere.
Posted on Jan 01, 2014
SOURCE: Really small Batery life on the Air hogs Relex
wipe your **** and smell the paper
Posted on Apr 17, 2009
  • 3 Answers
SOURCE: Purchased Helicopter MINI AIR WOLF
My wife bought one of thsoe for me for my birthday. I charged it for an hour - turn off the helicopter power switch and plug in the charge plug on the control - the control must be on. anyway the thing doesn't have enough lift to get off the ground. It just skitters along the ground. Also the tail rotor doesn;t do anything. The parts list identifies a tail motor so it should do something. Going to return it to the mall. That's a hassle! I would try to fix the tail motor, but if the thing can'e even get off the ground what's the point? Any info send it to rsockey at yahoo dot com.
Posted on Nov 15, 2010
  • 65 Answers
SOURCE: i just bought a knight hawk helicopter flew it a
k tell someone from the store
Posted on Dec 25, 2010
SOURCE: The helicopter syma s032 not
0) Obviously, helicopter will operate best when fully charged... if charging light gets brighter when unplugged from helicopter, then it's not at full charge. Charge fully, then allow battery to cool for 10 minutes. Good batteries in remote also.
1) Power on helicopter.
2) Place on level surface and let gyroscopes sync. There is a red light inside the body (NOT the red/blue flasher in the nose) that will blink when you turn helicopter on, and will keep blinking until craft is level and stable for a few seconds, then will stop blinking.
3) Make sure left joystick is all the way down.
4) Power on remote.
5) Throttle up (left joystick) until blades move and then all the way back down.
This should get you flying. Let me know.
hope this helps,
r
Posted on Sep 13, 2011
SOURCE: S032 won't fly higher than
1) Ensure you're fully charging. Indicator light on charging unit should NOT get brighter at all when you unplug the helicopter. If it does, then plug helicopter back into charger until light stays the same when you unplug. Note: If you're charging with a usb charger and are using a laptop or the front side data port on your desktop, these may take several hours to fully charge as they are usb 2.0 and do not carry the full 5 volt dc charge. Use powered usb (3.0) on back of desktop, or get a usb/ac adapter. Normal charge time approximately 1 hour. Go by the light, though.
2) Don't run them dead. As soon as you can no longer maintain altitude, land and turn off helicopter. Fully discharging a Li/Po battery (particularly when it's new) will cripple it's ability to hold a charge, and can ruin them.
hope this helps
r
Helicopter charger and batteries in remote ok, chopper won't fly
Is the "flight light" blinking on the copter? If you connect the USB cable to the copter will it power up? Have you tried different batteries in the remote? Check the pins in the charging port on the copter, Otherwise there's not a lot that can be done with these little RCs.
Feb 24, 2015 | Syma S102 IR Control Micro Blackhawk RC...
Airhog bomber helicopter
Hi Nichole,
not 100% sure what you mean by short flights,
They are made for very short flights, I bought one of the INTERCEPTOR R/C witch is bigger than the Airhog and it
is only a 4-6 minutes of flight and even that is pushing it on top end of flight and then its requires a 30 to 60 minute charge, their kind of disapointing as far as Air time to charge time goes.
Jan 01, 2014 | Air Hogs AirHogs RC Helicopter Heli Sniper...
I turn the on switch on the remote control and ready to fly. The heli starts for about two seconds and shuts down?
I have a Hercules "unbreakable" helicopter that shows that"shut down" sympton when the battery is low. I assume it does that to prevent the battery completely dying while in flight.
Feb 23, 2013 | RC New 3 Ch Co-Comanche RAH-66 Helicopter
Rc helicopter not getting signal from remote
I think you have damaged the copters electronics when you crashed it.
Jun 27, 2017 | Toys
Syma S032 Transmitter battery lights blinks even when Brand new Alkaine Batteries are fitted
4) Power on remote.
r
Jul 30, 2011 | SYMA Toys industrial Syma S032 Ready to...
My syma s032 now won't hover consistently but moves up and down slowly of its own accord. I can compensate by continually moving the joystick. I did have a couple of crashes though they were...
Could possibly be weak remote batteries?
Also, the s032 has an incremental throttle (you should feel very light "clicks" when moving left joystick {throttle} up or down) that can sometimes make steady hovering a challenge. Syma helicopters are fairly durable, but crashes can make them kind of shaky. Be sure to quickly throttle down fully when you are about to have any kind of blade strike or crash. If you crashed outdoors, check to make sure no blades of grass or other foreign items are in near the gears, and check the shaft for anything wrapped around it that might be slowing one or both main rotors. (even a stray long hair can muck things up) Is it exhibiting any other symptoms?
Still getting similar flight time?
Hope this helps, let me know.
r
Jun 29, 2011 | SYMA Toys industrial Syma S032 Ready to...
The helicopter syma s032 not fly, noy function, not syncronize with the remote control. This charging for 90 minutes and the battery of the remote control is new. The helicopter light led is good, to...
4) Power on remote.
hope this helps,
r
Dec 28, 2010 | SYMA Toys industrial Syma S032 Ready to...
My Web RC - Heli I. IR - Web Wolf isn't starting up even after I charge it. The instructions are very vague. What am I doing wrong
Hi! My sister's son had the exact same problem and after a quick look over the instruction manual I was able to get it to work. I have tried all the different Airhogs and this webrc is truly a superior flying toy. You can actually control it and make it go wherever you want to after you learn how to use the trim knob. Here are my suggestions to fixing the charging issue:
- Make sure the helicopter is OFF, - the batteries are fully charged on the controller/charger - and that the charging cable is plugged in correctly. You will know when you plugged it in correctly because the little light on the controller will change from red to green or vice-versa (cant remember) - the light on the controller/charger will change colors again when the helicopter is fully charged. - I am also an electrical engineer so I recommend you wait 10-15 minutes after turning it off and the same after charging it for optimal battery performance and life.
Hope this helps.
Have a safe flight!
Dec 25, 2010 | RC Toys
I have 3 s107 and I it says 3 channel on the box and the transmitter says A B C but will only let me select 2 of them. What's the trick on flying 3 at the same time?
Mine's exactly the same as yours. Although the transmitter shows A B C the switch has only two positions, so there's a choice of two only. I doubt it's possible to fly 3 at the same time.
Nov 08, 2010 | SYMA Toys industrial New Syma S107 Radio...
Toys Logo
93 people viewed this question
Top Air Hogs Toys Experts
freddyfox
ray gallant
Are you an Air Hogs Toy Expert? Answer questions, earn points and help others
