Question about Sony KDL55BX520 55 BRAVIA LCD TV
Picture freezes bad lcd - Sony KDL55BX520 55 BRAVIA LCD TV
Soniq PT42SH plasma TV power on. No back light and no pictures
SONIQ LCD TV REPAIR Blank flickering screen Energy ...
? 1:32
https://www.youtube.com/watch?v=FUqdi7lwmcE
May 29, 2013 - Uploaded by WastedOne2
Fix ya Soniq Tv once loaded up hit menu button then channel + then ... SONIQ LCD TV REPAIR Blank flickering screen Energy Saving Mode Issue ... Easiest TV repair - How to Fix Power [TV turns off, freezes, or won't turn on] ... Common easy LCD TV fix: bad picture screen rainbow colors - Duration: 4:04.
No Image & Blank Black Screen Flashlight Test - YouTube
? 5:56
https://www.youtube.com/watch?v=xUzCLgoSPGM
Sep 15, 2014 - Uploaded by ShopJimmy.com
LCD & LED TV Repair - No Image & Blank Black ScreenFlashlight Test - How to Fix LCD & LED TVs ... Most LED TVs will have a t-con board, a power supply board, a main board and an LED ..... SONIQ Australia 1,718 views.
Soniq PT42SH plasma TV power on. No back light and no ...
Jan 08, 2016 | Televison & Video
Picture freezes. Shut it off and turn it back on and the picture is fine for about 15 seconds and then it freezes up again.
Try to boot into safe mode and then see whether you're getting the same problem or not. Try before it freezes.
Sep 30, 2015 | Sharp 60IN LC-60E88UN AQUOS LCD HDTV 240HZ...
Samsung ln26a330j1d lcd tv picture freezes or just goes to white screen
BAD CAPACITORS!!!!!!!!!!!!!!!!!!!! FIND'EM
SWOLLEN ON THE TOP!!!!
Nov 14, 2013 | Televison & Video
Picture freezes
Contact your LG dealer for a service engineer, the software version currently in the TV may need updating, there is an update available for picture freeze problems.
Jan 08, 2010 | LG 42LG30 42 in. LCD HDTV
Sony lcd tv picture freezes
I saw the solution posted to your problem talking about the picture freeze feature on Sony TVs. I presume you're not touching a button on the remote when your picture is doing this.
Normally when a picture freezes it isn't the TV but the signal the TV is receiving from whatever source it's hooked up to. If you have digital cable and the company is having any type of technical difficulties with their signal, it can cause the picture to freeze. If you've ever watched TV with someone who has Dish or DirecTV while a storm was over-head, you may have seen it happen to their picture. However, if you're able to rule out the cable equipment and the cable company as being the problem, then there is something wrong with your TV. If your TV has this picture freeze feature the other guy was talking about, it's possible the feature is now malfunctioning . Whatever the case, if it's the TV the only troubleshooting you can try is to unplug the unit for 30 minutes. If that doesn't fix the issue, the TV likely needs to be serviced. Follow the link below and it will take you to Sony's esupport page. There you will find a phone number you can call, or you can chat with someone online regarding your particular issue. Good Luck!
I hope I've provided you useful assistance and that this informationallows you to make an informed decision as to how to proceed fromhere. Please be sure to vote on my response. I hope I've earned agood rating from you today.
Please post a comment if you needadditional assistance so that I can help you further.
Aug 04, 2009 | Televison & Video
Screen scrambles into various colors and freezes
TV requires main board replacement because problem seems in video processing section.
Main board is available at Shop Jimmy on reasonable price. (click shop jimmy link to see an image of main board)
Jun 02, 2009 | Westinghouse TX-47F430S 47 in. LCD TV
Polaroid 42 in LCD picture freezes
scope the power supply feeding the microprocessor, sounds like it has ripple caused by a leaky electrolytic capacitor.
Mar 08, 2009 | Polaroid FLM-4201 42 in. LCD Television
Lcd tv
can you u check in the DTB mode, the signal strength & the number ot errors ??
may be you will have to check your antenna connection. Normally it is due to bad signal.
Feb 07, 2008 | Samsung LE32R41BD 32 in. HD-Ready LCD...
Picture Freezes and Black Screens
Reset by unplugging the TV for 2 minutes and the going from there. Maybe a bad digital board since thats the only way images can et frozen on a TV.
Mar 10, 2007 | iLO 3200 32 in. LCD Television
Sony KDL55BX520 55 BRAVIA LCD TV Logo
21 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
