Lg art cool manual
We get continual condensation dripping from the bottom of the unit. Can this be stopped?
    Top Expert:
  • Heating & Co... Master
  • 36,514 Answers
If you live in a warm, humid climate the air conditioner is working properly.
Posted on Jan 01, 2014
  • 659 Answers
SOURCE: my lg art cool start working but stops showing in the lcd CH / 07
Sounds like the display has gone out or loosing power to it.
Posted on Apr 18, 2009
relaga58
  • 158 Answers
SOURCE: Error Code on LG Art Cool
error code CH22 is either compressor or inverter fault.
Posted on Jun 01, 2009
  • 6 Answers
SOURCE: Art cool keeps stopping
CH5 is a communication error between the indoor and outdoor unit. The thermistors have nothing to do with this error code. Check the communication wire for continuity, make sure it is shielded and stranded wire.
Posted on Jun 05, 2009
VtToolMan
  • 704 Answers
SOURCE: always wondered why there is no drain hole at
Newer models of window AC's use either a flailing fan to spin the condensate out the sides of the AC (outside the window) or the heat of unit and outside air will evaporate the condensate.
Either way, any excess will spill over the back edge, hence the reason that manufacturer's recommend that the AC be installed with the rear of the unit slightly tilted down to prevent excessive condensate (water) from building up and/or coming inside the front of the unit.
As to the icing, it could be that the unit is undersized for the space you are trying to cool and can't keep up and is running all the time in an attempt to cool the air down in the room you have it installed in. Try letting the unit "defrost" by shutting it off for awhile (until the ice melts) and then keep the shades pulled and the door closed once you restart it. I also tell people to give the AC a chance to adjust by setting the cooling temp to around 10 cooler than the present temperature of the room.
It's really hard to completely cool down a hot room all at once, so unless you're willing to let the unit cool it down in stages, it might not be able to ever get a 90 degree room down to 65 degrees in one day, if ever. Give it a try and see what happens, otherwise, you might need a larger rated BTU unit to get the cooling you desire.
Posted on Jul 28, 2009
hvac1960
  • 2133 Answers
SOURCE: LG Art Cool Error Code CA
Compressor discharge sensor fault. Disconnect from PCB measure resistance 237 kOhm at 20°C, 168 kOhm at 30C. Replace sensor.
Posted on Jan 03, 2011
Error code 10
Check to see if condenser fan (condenser is the outdoor unit) is spinning freely
Aug 08, 2014 | LG Art Cool LA181CNW Split System Air...
No heat but fan keeps running
If the air conditioner compressor runs all the time the main control board might be defective. The main control board provides the voltage to the fan motor and compressor. These boards are often misdiagnosed. Check all other components to be certain this is the cause of the problem.
Nov 25, 2013 | LG LAN186HV / LAU186HV 18,000 BTU 15 SEER...
Fussy Frige
Yes 66003764 Overload, Relay with Run Capacitor and you may need to also change the=> 67006531 Water Inlet Valve because it is not closing all the way and allowing water to continue to drip into the ice maker when it should be off. Here is a JCD2295KES Parts List and JCD2295KES User Manual I am here should you have questions, Thanks Sea Breeze
Jul 16, 2013 | Jenn-Air Refrigerators
Sounds like dripping water when on
Water, or in this case - condensation will be created and drip from the cooling coils inside the unit outdoors, if installed correctly. This is a normal condition. Like a cold glass of water sitting on a table or counter on a hot, muggy day; condensation will form. The amount of condensation forming on the glass - and cooling coils of the A/C - is directly related to the amount of humidity in the air.
Some A/C units have fans that not only force cool air out the front of the unit - but also spray condensate on the condenser coils (the coils that get hot and are visible from the outside) to help cool them down.
If water is dripping indoors - the A/C is tilted inward or drain holes on the bottom edges of the rear (outdoors) are clogged. Adjust the A/C support(s) so that it is tilted back (the bottom rear should be about 1/2" or 10mm lower than the bottom front) and inspect & clear obstructions from the drain holes as needed.
I hope this helps & good luck!
Sep 15, 2011 | Daewoo DWC060CL Wall/Window Air...
Our portable LG LP0910WNR is dripping water out of the bottom. The drain plug and cap are in place and not leaking.
This is caused by 2 things. The most prevalent is condensation dripping from the cooling coils. Usually this occurs, because the coils are dirty and need to be cleaned.
The second cause, is that one of the drain tubes (usually the one from the top tank to to bottom tank) is either partially clogged or has come loose from it's connection.
In either case, some dismantling of the units outer cabinet will need to be removed to check and service it. Consult your Owner's Manual concerning removing the outer cabinet.
I hope this helped you and thanks for choosing FixYa.
Aug 23, 2011 | Heating & Cooling
MLG LS307HV. Condensation is dripping off the bottom of the indoor unit. We've mounted the unit level but the left side continues to pull up. The wall mount is level but he unit is slightly out of...
the inside unit should be mounted with a slight tilt to the outside - so the water can drain outside.
also - be sure your drain hole (in the unit) is not plugged - either with dirt/debris.
Aug 04, 2011 | LG LS307HV Air Conditioner
LG Art Cool, 2 splits. Error code CH7
Multi Splits and Multi V = indoor unit is set to run in a different mode from the master indoor unit. Set ALL indoor units to cooling or ALL to heating to clear.
Splits = Compressor Over Current (CT2)
Jul 09, 2010 | LG Art Cool LA121CNP wall/window Air...
I HAVE MISLAID REMOTE CONTROL INSTRUCTIONS TO CHANGE FACILITY REQUIRED IE COOL, OR HEAT
You can download the owners manual; here is the link for it.
http://www.generalmanual.com/Air-Conditioners/LG-LA121CNP-Art-Cool-Air-Conditioner.htm
when you get to the page scroll down and you will see Download Now and under that "Owners Manual" just click on it.
I hope it helps.
May 27, 2009 | LG Art Cool LA121CNP wall/window Air...
Condensation from the coils
check drain hose maybe is obstruct or have bad plunk.
Feb 12, 2009 | Sanyo 09KS51 Mini Split Air Conditioner
C6 error code on LG art cool
Try turning the power off at the fuse box, waiting 5 minutes turning the system back on and spray some water on the vents on the side of the outside condenser. If the fan isnt spining get a twig and spin it in an anti-clockwise direction after 1 or 2 spins it should start spinning on its own. continue to hose the vents with water for another 5 minutes. Its important to have the fan spinning as it extracts the heat from the condenser box.
Jan 03, 2009 | LG LSC121PMA Split System Air Conditioner
Heating & Cooling Logo
29 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
