Question about NetGear NeoTV NTV200
Neotv is frozen after update - NetGear NeoTV NTV200
Why doesn't my neotv netgear remote no longer communicating with box?
What do the different Remote control front LED lights mean?
  • Blink blue color twice per second: Remote control has paired NeoTV PRIME and is trying to connect NeoTV PRIME.
  • Blink blue color once per second: Remote control is trying to pair the NeoTV PRIME.
  • Orange blinking: Remote control battery is low. Please replace a new set of AAA battery.
go to page 15 of the following document:
http://www.netgear.com/landing/stream/img/gtv-specs/GTV100_IG_25Oct2012.pdf
Sep 09, 2014 | Computers & Internet
My neotv will not let me watch anything
Check to see if there are any physical obstacles that might interfere with your WiFi signal, things like metal wall studs, metal cabinets, etc. if that is the case and you can't move your neoTV setup, you might need to get a WiFi booster. That worked for us.
Jul 25, 2014 | Netgear, Inc NETGEAR NeoTV Streaming...
Frozen
www.netgear.com/home/contact-us
Jul 13, 2014 | NetGear NeoTV MAX NTV300SL
We have a netgear neotv streaming player ntv300. We had it connected to the tv and then it had a message that it needed to be updated, so I checked it to be updated and it started updating for a whil
We had this problem too. It turned out our wi-fi signal was too weak. After we installed a wi-fi signal booster, the netgear update was completed with no further problems.
Mar 10, 2014 | Netgear, Inc NETGEAR NeoTV Streaming...
Just did the software update on my neotv now it won't do anything just displays the neo emblem
It sounds like the update was for another model. If that is the case; you may have damaged the boot sector or upset the bois. You may now be required to install the entire operating system all over again. I hope you have a back up of your old data.
Feb 23, 2014 | Computers & Internet
My neotv box isn't doing anything at all. When I
Hi,I dont see that box before but may these solutions work for you:
1-if you attach a flash drive or external memory cards try to format the flash drive or memory drives with the box not pc
2-try to reset to factory
3-try to get and update the firmwares box software from manufacturer site
4-try another flash or memory(may be they are dead)
5-try boot it up without any flash or memory inserted
6-try disconnect it from network or any attach device and check it works fine or not
7-may be you have hardware failure
kind regards
Apr 16, 2013 | Computers & Internet
NetGear NeoTV NTV200 Logo
478 people viewed this question
Top NetGear Televison & Video Experts
David Payne
David Payne
ray gallant
Dave
Dave
Level 1 Expert
Are you a NetGear Televison and Video Expert? Answer questions, earn points and help others
