Question about Philips PET710 Portable DVD Player
No charger or battery pack for device
Trying to use spliced ac adapter
I need a replacement Power pack 12V-3A 36W. Can you please tell me where I could get one from?
Cherryl, You could try local stores that sell computers and electronics, Walmart, the source, staples etc. Check the attached links,for power pack/charger, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Premium 4 8 1 7mm Replacement Power Supply Cord Laptop Battery Charger...
Genuine Asus LCD Monitor 12V 3A 36W Ac Adapter Charger ADP 36EH
Laptop AC Adapter 12V 3A 36W 1 7 4 8mm
Amazon ca power supply 12v 3a
Apr 28, 2016 | Computers & Internet
Where do I find the AC Charger adapter for a Godox PB820S Propac. I have look online and can not find the charger for this battery pack.
If you still have the 12V car adapter it ships with, you can buy a 12V supply with a cigarette lighter connector and use that .
You could try contacting their main distributor who lists the complete device :http://www.lightinthebox.com/godox-pb820-backup-external-battery-pack-for-speedlite-vsp-136265_p995394.html , but does not list the charger alone.
Failing the distributor, try contacting the factory. They offer direct contact for support (godox@godox.com),including skype chat (GODOX@hotmail.com for MSN/skype).
Adorama sells the "Flashpoint" series of devices which seem to be relabeled versions of Godox products, but only sell the 960 larger power pack not the 820.
I read that the 820 DIN cable connector is compatible with Quantum cables. That *might* mean that one of the Quantum chargers *might* work for you, as those use a DIN connector for some of the rechargeable Quantum batteries. I once adapted a wall adapter for charging a Quantum battery pack and used a DIN connector. Unfortunately the Quantum chargers are expensive and there are a number of different models,so it may be difficult to figure out what will work for yo.
Jan 18, 2015 | Godox PB820 PROPAC Power Pack
I have sony cybershot dsc 10 digital camera but it dsn't power on batery charge is full
Please make sure that the Battery in the Camera is fully charged.
Please check if the issue is with the battery charger. Make sure that the Charge Lamp in the Battery Charger is lit when connected to the Wall outlet.
You can try recharging the battery pack for almost 6 hours as initial charging.
If you've another battery pack, try using the same to check if the issue is with the Camera or with the battery.
You can also try turning on the Camera by connecting the optional ACL-S5K AC Adapter. This Adapter can be used for turning on the Camera, it cannot be used to charge the battery pack. For charging the battery in the Camera, the supplied battery charged needs to be used.
If the Camera is not turning on using both the AC Adapter and new battery, then the Camera may require service.
Thanks for using FixYa.
Jan 10, 2011 | Sony Cyber-shot DSC-H10 Digital Camera
I have sony digital camara but it dsn't power on batery charge is full
Jan 10, 2011 | Sony Cyber-shot DSC-H10/B Digital Camera
I have sony digital camara its not power on plz help me
Jan 10, 2011 | Sony Cameras
My toshiba satellite L300 has no power
Please follow these steps VERY CAREFULLY:
1) Unplug the notebook from the ac adapter (charger power cord)
2) Take off the battery pack on the notebook
3) Once the ac adapter and battery is off the notebook, hold down the power button for 15 seconds
4) After 15 seconds, let go of the power button
5) Now plug in the AC ADAPTER (OR CHARGER POWER CORD) ONLY (DO NOT PUT BACK THE BATTERY PACK)
6) Now press the power button once.
7) If the unit boots, the unit suffered a slight surge
8) If the unit does not boot and remains dead, the unit suffered a severe surge and may be burned out and needs replacing
I hope this helps and let me know how it goes afterwards
May 03, 2010 | Toshiba Satellite Pro L300 Notebook
Battery charger
You can buy it to any electronic or computer shop nera you like Bestbuy , Radioshack or any other store just give them model of your device and they will be able to provide you that....
or
click on hyperlink:
buy replacement ac power power cord charger adapter KAWASAKI PVS-1080
Jun 13, 2009 | kawasaki PVS1080
Need battery charger
Nov 12, 2008 | kawasaki PVS1080
Low battery icon on Midland LXT350 walkie-talkies
Your LXT350 is equipped for using an optional rechargeable NiMH battery pack which can be recharged by inserting the AC adapter into the radio charge jack, or with the optional desktop charger.
I would make sure the radio is off, then insert the charger. Charge only for the prescribed time (no more/no less) and remove from the charger.
Charge time is initially 24 hours. Charge time is about 12 hours thereafter. For maximum battery life, it is recommend charging the battery pack when the low battery icon comes on. Remove the radios from the charger when the charge time expires.
Jan 01, 2008 | Radio Communications
Supersonic SC-299TDVD
Battery back needs to be connected to the DVD player when charging. connect the batter pack to player. Run the DC/out from the battery pack to the DC/in in the player. plug the charger into the wall.
if that does not work, you have a bad battery
Dec 27, 2007 | Supersonic SC-299TDVD
Philips PET710 Portable DVD Player Logo
15 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
