Question about Dryers
Where is the factory reset on a LG DLE 2532w dryer?
4 Suggested Answers
hunter19_46m
  • 7482 Answers
SOURCE: I have a DLE 7177WM LG electric dryer is sound
Your problem sounds like drum rollers have flat spots on them or in need of lubrication.
If you have a front loading machine, Unplug the dryer, remove the front of the dryer. This will expose the drum and belt, remove the drum and belt and this will expose the drum rollers.
Check your rollers for flat spots, if they have flat spots on them replace them.
If they don't then they probably only need lubrication. Lubricate the shaft of the rollers with a good grade of machine oil such as 3 in One oil. Reassemble the dryer, plug back in. This should solve you noise problem.
Good Luck,
I hope this helps
Posted on Oct 15, 2009
  • 185 Answers
SOURCE: I am changing the 220 plug in the Lg dle 2532w how
Page 13
http://dl.owneriq.net/0/032b525a-ae3a-438c-89e7-85d6c6c28829.pdf
Hope this helps
Posted on Jan 21, 2011
ercupa190
  • 12223 Answers
SOURCE: our dryer doesn't dry clothes like it should, sometimes takes a long long time and other times quick and the clothes feel really hot, model # is DLE 2532W
see this causes and fix it. God bless you
Power from the house
Check to see whether there's power getting to the dryer. Is it plugged in? Check for blown fuses or tripped circuit breakers--your dryer uses two fuses or circuit breakers. The dryer could tumble but not heat if only one of the two fuses is blown. If you have circuit breakers, one of the two circuit breakers can trip, even if the two for the dryer are connected.
Heating Element
Often a dryer heating element burns out, but doesn't trip the circuit breaker or blow a fuse. The heating element is simply a long coil of special wire. You can check it for continuity with an ohm meter. No continuity means the element is bad and you need to replace it. The proper ohm reading can be found in the service manual or sometimes on the tech sheet located somewhere on your dryer (9- 13 ohms is a common reading). Electric heating elements aren't repairable. The heating element is easy to replace. Check our videos for other types of dryer heating elements.
Thermal fuse / Thermal Cut Out / Thermistor
On many dryers, there's a thermal fuse mounted to the exhaust duct inside the back cover panel or behind the front cover. The fuse--which is about an inch long--is usually embedded in black resin and mounted in a white plastic housing They are also round and made of metal and plastic. The thermistor is located on the blower housing usually. If any of the fuses do not have continuity replace it. Check for continuity if none replace, But before replacing check for obstructions. The fuses are very inexpensive and easy to replace.
Wiring
A common problem is for the main wiring connection from the house, at the dryer, to burn and break its connection. Because the dryer can still tumble with partial power, the connection may be only partially defective. Check all connections, make sure they are tight. Loose connections can lead to a fire. You may need to replace both the power cord to the dryer and the terminal block inside the dryer that the wire is attached to.
Posted on Sep 27, 2012
Our dryer doesn't dry clothes like it should, sometimes takes a long long time and other times quick and the clothes feel really hot, model # is DLE 2532W
Heating Element
Wiring
Sep 27, 2012 | LG DLE2532W Electric Dryer
My LG DLE 5932w CONTROL PANEL WON'T LIGHT UP AND THE DRYER ONLY BLOWS COLD AIR. COULT THIS BE A BAD FUSE?
Check the 220 volt circuit breaker or cycle it. If on the other hand you have fuses instead of breaker panel, with 220 volt you should have two fuses to contend with and one or both may be blown.
Nov 18, 2011 | LG Dryers
LG DLE 2512W Electric dryer
There was no comment of the fault that was seen on your machine and so would request your observation.
Oct 18, 2011 | LG DLE2512W Electric Dryer
Hi need to order parts were can i get them
Hi
Thanks for using FixYa. You can order the parts from any of these two links:
LG DLE 2532W Parts
LG DLE 2532W Parts-2
Please do rate thesolution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Jun 21, 2010 | LG DLE2532W Electric Dryer
LG Dryer displays CL on screen. What to do?
Makes no mention in the manual about a CL error
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Apr 01, 2010 | LG DLE2516 Electric Dryer
Good Luck,
I hope this helps
Oct 14, 2009 | LG DLE7177 Dryer
Dryers Logo
32 people viewed this question
Top Dryers Experts
