Question about HTC Cell Phones
My htc one vx shut down and will not start it has a flashing orange light been charging for 24 hr
I've tried to power up by holding down power button it flashes then stops and it viberat
  1. While the phone is off, press and hold the VOLUME DOWN button, and then press and hold the POWER button.
  2. Wait for the screen with the three Android images to appear, and then release the POWER and VOLUME DOWN buttons.
  3. Press VOLUME DOWN to select FACTORY RESET, and then press the POWER button.
Posted on Jan 01, 2014
  • 3422 Answers
SOURCE: my K610i won't turn on. Red light flashes n won't charge.
HI,
That indicates a problem with the battery.Try a reset first.
Connect the phone to the power adapter and then press and hold the power button for more then 1 min.If it still doesn't turn on then remove the battery and sim from the back and then insert the sim back again and hold the power key for more then a min.Make sure you don't insert the battery now.Let me know the result.
Thank you
Posted on Aug 02, 2009
otacon
  • 1944 Answers
SOURCE: sony ericsson k610i stopped working
Try leaving the battery out overnight. Then put back the battery in and try to turn on. If this didn't help, then your phone's software needs to be flashed.
Posted on May 09, 2008
  • 10 Answers
SOURCE: it wont power on & has a red flashing light
2 things, first bad battery, sometimes bad battery works for few minutes then your phone just dies on you, it says its fully charged but it aint. That red light flashing only means that your phone has LOW BATTERY. 2nd your phone software has problem. If you have another ericsson that uses the same battery you can check it the battery is ok, its the only way you can find out if the battery is good. If the battery is doing ok with another cellphone then your cellphone software has problem.
Posted on Jan 05, 2010
jerseymark
  • 358 Answers
SOURCE: My battery does not charge
Hello, why the phone is not charging is because the cell of the battery is weak and can power on the phone for to long, that's why it shots down so quick,
You will need to replace battery with a new one for longer talk hours.
Make sure you charge battery for 6hours before use.
And also if the battery still doesn't work that means the phone memory is weak and it will need to be flashed to restore back the phone memory.
What you will need to do is this,
You will have to flash the phone to restore the memory of the phone.
You can use this link to see how to flash your phone
hubpages.com/hub/How-to-Flash-your-cell-phone
and
unlocktotalk.com/UnlockCodeInstructions.htm.
Take care.
Posted on Sep 12, 2010
ashlocked
  • 1140 Answers
SOURCE: My phone wont turn on and when I try to charge it,
First thing to do is try to replace battery for a test,usually when phone is often used,it can easily discharge like using wifi or any,then simultaneously charger is plug in.this will damage the battery and can be easily drained.
Posted on Aug 07, 2011
Orange light mean
The orange light indicates its stuck in charging mode.
Hold volume down and power for 15 seconds, you should see the bottom buttons flash a few times and it will go into recovery mode.
Use volume keys to highlight restart phone and press power once.
Oct 12, 2013 | HTC Cell Phones
HTC Vivid won't turn on
1.Check the device's battery level for at least two bars of strength.
2.If the battery level is low, charge the battery.
3.If the issue is not resolved, remove the back cover.
4.Remove the battery.
5.Wait 10 seconds.
6.Press and hold the W key.
7.While pressing down the W key, re-insert the battery.
•The device restarts and after approximately 15 seconds, the 'Recovery' screen appears
•Release the power button but *continue holding the home button*, for another 30 seconds.
Step
Thanks
Aug 04, 2012 | HTC Vivid
Htc chacha wont turn on and orange light flashing
The battery is completely dead, charge for about 1 hour; if flashing light continues then you need a new battery, I've just done this to my phone..
Mar 29, 2012 | HTC Chacha Smartphone
Htc evo 4g shift won't charge or turn on and I
Have you attempted taking the battery out and while the battery is out holding down the power button for a few seconds? If this doesn't work,
First test your charger to ensure proper charging. Clean charging ports. Remove battery and clean brass contacts with alcohol and q-tip
Jan 12, 2012 | Lands Phones
My HTC mobile not going to on after pressing power button and on connection of charger it is showing red LED. Same there here. I woke up this morning and my phones just dead. Even if i connect the charger...
Remove the battery then connect the charger without the battery. Then hold down the power button for a few seconds. The red light may come up for a quick second during this process.
Don't remove the charger. After the red light goes off then insert the battery and check if the light turns amber or orange.
Leave it in orange or amber light state for about 2 minutes. After that, try to turn it on. If it turns on then it is resolved. If not then there is a hardware problem with your phone and it needs to be checked at any HTC Service Center.
Jan 28, 2011 | HTC Touch P3450 Smartphone
Dell Inspiron 1525 laptop, no power light, battery light flash orange, wifi light flash blue and orange I bought the Dell Inspiron 1525 laptop in 2008. I use the laptop as a desktop, so I never plugged...
Since it sounds like an issue with the Power first try to release flea power.Disconnect the charger,remove battery,press and hold down the power button for 30 seconds.Reconnect the battery and charger.Turn on system and check if it turns on. For further help please check Dell Inspiron 1525 Manual. Also confirm if the light on the charger stays on,when connected to the system.
Mar 06, 2017 | Dell Inspiron 1525 Notebook
Dont really know if its a real problem, but i got up in the middle of night for the toilet and noticed that on my desk my laptop was flashing orange from the charging port, i thought i must not have shut...
try to do a hard reset and check if it works..
shut down the pc, take out the charger, take out the battery, press and hold down the power button for 20-30 secs. then put back everything in their place and turn it on.. see if it works.
Apr 29, 2010 | HP Compaq 6735s Notebook
My charge light constantly flashes orange and my C600 won't turn on at all. I hold the power button and all the lights turn off. I got nothing. Just a blankscreen.
When you say charge light, was that the battery led light that you were referring to or the power button?
If it is the battery led light, try this:
Try to power on your laptop without the battery in your laptop.
take out the battery and just use the ac adapter, if it works fine then there could be a problem with your battery.
If is the power button that is flashing orange, then try to power cycle laptop.
turn off laptop.
take out the battery and the ac adapter.
then while those are out, you hold down power button for atleast 10-15 seconds.
put back the power source and check the led again.
Apr 08, 2009 | Dell Latitude D600 Notebook
Flashing lightning bolt on Compaq C300
This sounds like a battery problem. The best way to test this is to remove the battery and then power the laptop up with just the power cord plugged in but no battery. If the computer boots then the battery is bad you will need a replacement. Also try letting the battery charge for a day. Be sure that the charging light is coming on when you have it plugged in.
Dec 09, 2008 | Compaq Presario Notebook
Cell Phones Logo
158 people viewed this question
Top HTC Cell Phones Experts
Ashutosh Khandelwal
Level 1 Expert
D. E. Hev
Tech Leprechaun
Tech Leprechaun
Are you a HTC Cell Phone Expert? Answer questions, earn points and help others
