Question about Hasbro Star Wars The Clone Wars Force Action Lightsaber - Obi-Wan Kenobi
Disassemble obi-wan kenobi force action light saber
I have a 1977 Suzuki GS400X, I get power to all
you may have a bad flasher needing replacement. just because you hear it click when you turn on the signals does not mean the bi-metallic strip inside is working.
Sep 21, 2014 | Cars & Trucks
Disassemble bolt on bolt action shotgun
Pretty much all bolt action bolts work the same. You need to relieve the spring force. That means pulling back on the cocking knob. The head will come off easily then. You need to have the bolt in the exact condition it's in when cocked, cocking knob back, to disassemble it. Reverse that to reassemble.
Apr 21, 2014 | Mossberg Optics
I need a sim network unlock pin for my pantech crossover?
ur defalt phones codes is 12345 or 00000 u can use it
Default 4 Digit user code: 1234 or 0000
Default 6 Digit Security code: 123456 or 000000
Type *#06# at the mobile screen to know IMEI no of your mobile.
send the IMEI no to me and i will reply you with unlocking code.
IF Problem not Solved So
Please New Software install in the Phone Problem will Solved
If For puk & pin cod problem So Please
Very Best Solution:You Go To Service & Sim Office and Get The Puk code And Pin code From Office oprator
Enter The Puk code and Yes
Enter The pin code and Yes
So Puk code Open and Problem will Quickly Solved
Aug 12, 2012 | Samsung Lands Phones
How to cheat in starwars?
Enter the codes below in the cheats menu to unlock the desired character or outfit:
  • LEGION - 501st Legion
  • AAYLA - Aayla Secura
  • ITSATWAP - Admiral Ackbar
  • CHOSENONE - Anakin Skywalker
  • ACOLYTE - Asajj Ventress
  • DANTOOINE - Ceremonial Jedi Robes
  • NOTIMO - Chop'aa Notimo
  • TK421 - Classic Stormtrooper
  • SERENNO - Count Dooku
  • PAUAN - Darth Desolous
  • ZABRAK - Darth Maul
  • HIDDENFEAR - Darth Phobos
  • SITHLORD - Darth Vader
  • DREXLROOSH - Drexl Roosh
  • PALPATINE - Emperor Palpatine
  • MANDALORE - General Rahm Kota
  • NERFHERDER - Han Solo
  • SHOCKTROOP - Heavy Trooper
  • ECLIPSE - Juno Eclipse
  • WOOKIEE - Kento's Robe
  • KLEEF - Kleef
  • SCOUNDREL - Lando Calrissian
  • T16WOMPRAT - Luke Skywalker
  • JEDIMASTER - Mace Windu
  • MARAJADE - Mara Jade
  • MARISBROOD - Maris Brood
  • STORMTROOP - Navy Commando
  • BENKENOBI - Obi Wan Kenobi
  • HOLOGRAM - PROXY
  • MAVERICK - Qui Gon Jinn
  • TOGRUTA - Shaak Ti
  • INTHEDARK - Shadow Trooper
  • HOLOCRON - Sith Robes
  • KORRIBAN - Sith Stalker Armor
  • SECURA - Twi'lek
  • GRANDMOFF - Unlocks all costumes
  • YELLOWJCKT - Yavin Luke
Enter the codes below in the cheats menu for the desired effect:
  • SPEEDER - 1,000,000 Force points
  • LIGHTSABER - Amplified lightsaber damage
  • CORTOSIS - Godmode
  • COUNTDOOKU - Increase combos to maximum level
  • KATARN - Increase force powers to maximum level
  • VERGENCE - Unlimited force
  • TYRANUS - Unlock all force powers
Dec 12, 2010 | Sony PlayStation Portable (PSP) Slim...
Theres a light shape like a radiaton coming on
sounds like coolant level low indicator, check coolant level and check for leaks if you cant find any the switch could be faulty
Jun 14, 2009 | 2005 Mazda RX-8
New mobo - strange post error - no video
Kinda looks like you solved your own problem!
Good luck Obi-Wan...may the force be with you!
Hank
May 17, 2009 | Computers & Internet
Hit a pole doin apprx. 15 mph and stalled out and wont start?
Hi kosterscott, I believe honda incorporated the use of frontal impact sensors which might be a good place to start hope this helps,good luck
Nov 10, 2008 | 1996 Honda Civic
I'm stuck on lego star wars 2
With Obi-Wan and Luke, 3PO and R2, make your way and fight off the first onslaught of Stormtroopers. During the fighting, press forward and you’ll see a grey colored ramp to your right. With Obi Wan, use the Force to select the ramp and move it to the opposite side, which will allow 3PO to walk up the ramp and open up the doorway on the ground.
Regroup your party and go through the open doorway and figh off more Stormtroopers. At the end of this “block,” there will be a series of Lego parts lying on the ground. Put them together, dig them out of the sand with the Force, use R2 to open up a doorway which contains more Lego parts, and use 3PO to open up another doorway with even more Lego parts. Start assembling everything until you finish building an AT-ST.
241814565_b89054ed85.jpg?v=0 Once the AT-ST is up and ready a Stormtrooper, hoping for a takeover, will run into the cockpit. Select Obi-Wan and use the Force on the giant Mech, causing the Stormtrooper fall out of it. Now kill the Trooper with one swing of the lightsaber, and then hop into the AT-ST.
Note: At this time you can go back with the AT-ST and break apart the other blocked entryway near the beginning of the second part of the level, to go into the double-score zone.
You can also take your Landspeeder into the double-score zone, and wash it at the car wash, or sell it to the Jawa, under the Landspeeder salesman sign, to get more Lego Studs.
Charge forward with your new toy, shooting up everything in sight, and barge into the open area, shooting at the Stormtroopers before they can hop into their own AT-ST. If they do it will come down to trying to get your shots off sooner than the other AT-ST in order for the pilot to fall out. If you take the five shots to knock you out, have Obi-Wan as your pilot because he can use the Force to knock out the pilot from the other Mech, giving you a small upper hand for which character counter-acts your opponent.
241814570_230cd6b853.jpg?v=0 Proceed into the Mos Eisley Cantina entrance, which should have opened up for you after you have killed the last Stormtrooper. With Luke, shoot out the magnetic generators that hamper 3PO and R2’s entrance into the cantina, and then gather everyone on the four red buttons on the floor, triggering the inner-door to the Cantina to open.
241814569_5007caa40d.jpg?v=0 Now, Han Solo and Chewbacca are the only playable characters for the remainder of the level. Get out of the Cantina, the exit will be to your right. Grapple up to the second story of the house, to your right, and proceed through the archway. In the second section, make your way over to the red grapple circle on the edge of the roof. This will allow you to swing across to the adjacent rooftop where there is a lever to pull. Pull the lever and a crate will pop out. Push it towards the two large doors at the far end of this section. Shoot it to destroy the doors, allowing you to get into the next section.
241814572_b4fac276b1.jpg?v=0 This next area is full of Stormtroopers, so use the run and gun strategy by running around and shooting at everything. Then, make your way onto one of the backs of the Dewbacks, and walk them over to the far north western corner of the level, and then jump off them. When you jump off a Dewback, they will send you flying up and over the wall. Run down the walkway towards the door to Docking Bay 94.
241814563_7f0a77ebf0.jpg?v=0 Now, this is just an all out battle. Reunited with everyone, it’s time to collectively fight off waves of Stormtroopers that Garindan keeps calling on his walkie-talkie. The goal here is to shoot Garindan four times, which will then cease the waves of Stormtroopers and open up the entrance to the Millennium Falcon.
Minikit locations:
1. Enter the Storm Trooper bath house to the left of where you starting the level.
2. Above the broken bridge. Find the three plants which are located throughout the level. Destroy every barrel you come across. After that, use Bounty Hunters grenades to break apart the shiny metallic object in the middle of the level, which will yield Lego parts. Put these together to form a propeller, allowing you to jump high enough to get the Minikit.
3. Under the sparkling grid with four red nozzles, use a Dark Force powered character to reveal this Minikit.
4. In stage two of this level, when you get the AT-ST, there is a Womprat shooting gallery next to the double-score zone. Kill 10 Womprats to get the Minikit.
5. In plain sight, there is a Minikit near the parts of the AT-ST. Stack the crates and use a Force sensitive character to jump up and reach it.
6. Find the crashed spaceship. Use a Bounty Hunter's grenade to blow up the moisture evaporator, and use the Lego parts to build a crank. Grapple up to the crashed ship and grab the Minikit.
7. Inside the Cantina, there is a Minikit behind the force field. Use a Jawa to enter the small entryway to slide in there and grab it.
8. High along edge near the door you blow up, a Minikit will be revealed after you find all 3 plants in this section of the level. Once again, as in step 2, it’s best to just blow up every barrel you find to uncover the plants and collect a ton of Lego Studs in the process.
9. In the section behind the big black and red doors, use a Dark Force powered character to get in there. The kit is hiding behind the two small gates, where you see the Womprats running around. Use the Force on the gates to open them and grab the Minikit.
10. In the movie theatre, behind the movie screen. Guess how you get it? That’s right, you blow it up.
Super Lightsaber Power Brick Location:
Across from the section, where you moved the bridge with the Force, there is a small opening that looks as if a doorway should exist. There are numerous barrels next to this phantom doorway, each of which contains pieces to assemble the doorway. After you get all the pieces, assemble the doorway and use R2 to enter and grab the Orange Power Brick.
I hope this helps!
Oct 05, 2008 | NBG Lego Star Wars 2 Original Trilogy GBA...
Help me expert-wan-kenobi's your my only hope!
if you want new codes forever use the following link ---http://www.digital-kaos.co.uk/forums/dlcat-starview-23
Aug 07, 2008 | StarTech.com StarView SV211K 2-port KVM...
Bugaboo Gecko Stroller
CONTACT BUGABOO
PHONE: 1-800-460-2922
E MAIL: service@us.bugaboo.com
WEB SITE: WWW.BUGABOO.COM
Nov 19, 2007 | Bugaboo Gecko - Green Standard Stroller
Hasbro Star Wars The Clone Wars Force Action Lightsaber - Obi-Wan Kenobi Logo
53 people viewed this question
Top Hasbro Toys Experts
thegtw
Spidey28
Are you a Hasbro Toy Expert? Answer questions, earn points and help others
