Question about Bose® CORPORATION Bose - SoundLink Mini Bluetooth Speaker
How to remove battery - Bose® CORPORATION Bose - SoundLink Mini Bluetooth Speaker
Remove battery
  1. If equipped with power seats, move the seat to the most forward and upright position.
  2. If equipped with manual seats, move the seat to the most forward position.
  3. Turn the ignition switch to the Off position. Be certain that all electrical accessories are turned off.
  4. Remove the battery cover (1).
  5. Remove the negative battery cable (1) from the battery.
  6. Disconnect the positive battery cable and position aside.
  7. Remove battery thermal blanket.
    1. Remove the battery hold down retainers (2) and remove the battery hold down (1).
    WARNING: Wear a suitable pair of rubber gloves when removing a battery by hand. Safety glasses should also be worn. If the battery is cracked or leaking, the electrolyte can burn the skin and eyes.
    1. Remove the battery from the vehicle.
Jul 12, 2013 | 2012 Jeep Grand Cherokee
Replace battery
Remove the negative cable end from the battery. Remove the positive cable end from the battery. Remove the hold down bolt from the front of the battery hold down. Loosen the rear battery hold down nut and remove the battery hold down. Remove the battery. Reverse this order to reinstall.
Sep 25, 2011 | 2001 Toyota Camry
Replacing battery on Aston Martin Vanquish
Below is the procedure for an Aston Martin Vantage, perhaps the vanquish is similar?
Removal
1. Power the driver's fully forward.
2. Remove rear compartment cover.
3. Loosen and disconnect battery terminals, earth (- ve)
terminal first.
4. Release rear carpet, studs (x2), move carpet aside.
5. Remove screws (x2), battery compartment cover to
support rail.
6. Remove nuts (x2), battery compartment cover to body.
Remove cover.
7. Remove Torx screws (x4), remove battery clamps (x2).
8. Disconnect battery vent tube.
9. With assistance, remove battery.
Installation
1. Clean battery tray and clamps.
2. With assistance, install battery into its compartment.
3. Connect battery vent tube.
4. Position battery clamps (x2), install and torque tighten
Torx screws (x4).
5. Ensure battery vent tube is not distorted by battery.
6. Install battery terminals, tighten terminal nuts to correct
torque.
7. Install battery compartment cover, install and tighten
screws (x2) and nuts (x2).
8. Position rear carpet, secure with studs.
9. Install rear compartment cover.
10. Reposition driver's seat.
Courtesy of pistonheads.com
Please vote if this helps! Thanks, Mike
Jun 12, 2011 | Aston Martin Vanquish Cars & Trucks
Remove battery from 2002 dyna
The Dyna battery can be removed by:
1. Remove the seat.
2. Remove negative connection at frame, and positive connection at battery.
3. Remove the lower rear bolt. (left side of battery box at frame upright)
4. Remove the upper rear bolt, and swing down the battery box.
5. Remove the top cover, nad side cover.
6. Lift battery out, and remove negative cable from battery.
Feb 05, 2011 | 2002 Harley Davidson FXDL Dyna Low Rider
How to get to battery to change it
1. Remove the seat.
4. Remove hte upper rear bolt, and swing down the battery box.
Jan 20, 2011 | Harley Davidson FLHTCUI Electra Glide...
How do i take off the battery cover
1. Remove the seat.
5. Remove the top cover, and side cover.
Jan 17, 2011 | 2001 Harley Davidson FXDL Dyna Low Rider
How do i remove a battery from a 2002 chrysler concorde
Battery is behind the front left wheel. You have to remove the wheel to replace the battery. (you can access the battery w/out removing the wheel, but you can't actually get the battery out unless you take the wheel off.)
Once the wheel is off, remove the inner-fender well mud-guard and you will see the battery just forward of the wheel well. From there it's pretty straight forward.
Once this is removed, you should be able to see the battery hold-down bolts.
Remove these and remove the hold-down assembly.
If you are removing the battery, remove the 1st battery cable.
Depending upon what battery you have, you may be able to slide the battery back toward the wheel and disconnect the 2nd cable.
Jack the vehicle up, put on jack stands and remove the passenger side wheel.
On the front side of the wheel well there is an access panel that needs to be removed in order to access the battery. There are 6-8 1/4" screws to remove. Then manipulate the cover until you can remove it, bending it slightly.
If you were unable to disconnect the 2nd battery cable earlier, you can now move the battery further towards the rear of the car. Remove the 2nd cable clamp from under the hood.
Slide the battery all the way out. It is heavy!
Reverse the instructions for reassembly.
Aug 17, 2010 | 2002 Chrysler Concorde
I need to replace the battery. How do I do this?
Hi!!
The battery is located in the fender, ahead of the right front tire. Te battery can be removed without reovint the tire, but removing it improves access.
Here is how to remove/replace the battery
Disconnect battery cables, negative first, then positive from remote terminals.
Remove air filter housing
Remove the two battery hold down clamp bolts and clamp.
Loosen right front tire lug nuts, rise the vehicle, support it w/jackstand and remove wheel.
Remove battery cover/splash shield from wheel well
Slide battery toward rear of vehicle and disconnect battery cables.
Remove old battery thru wheel opening and insert new one.
If helpful, click below
Apr 13, 2010 | 2003 Chrysler Concorde
Dead battery
Removal Procedure
Disconnect the negative battery cable
Remove the wheelhouse liner.
Open the positive battery cable connection cover.
Loosen the positive battery cable bolt.
Remove the positive battery cable
Remove the front fender rear bracket to side rail bolts.
Remove the front fender to front fender rear bracket upper (1) and lower (2) bolts.
Remove the front fender rear bracket.
Remove the battery hold down retainer bolt and retainer.
Important: Do not tip the battery more than 40 degrees during removal.
Remove the battery.
Installation Procedure
Important: Do not tip the battery more than 40 degrees during battery installation.
Install the battery.
Install the battery hold down retainer and bolt.
Install the front fender rear bracket.
Install the front fender rear bracket to side rail bolts.
Install the front fender to front fender rear bracket upper (1) and lower (2) bolts.
Install the positive battery cable (1).
Tighten the positive battery cable bolt.
Close the positive battery cable connection cover.
Install the wheelhouse liner.
Connect the negative battery cable
Oct 15, 2009 | 2006 Pontiac Solstice
Battery removal
The battery is located under the right front fender behind the tire. Remove the wheel, remove access panel from fender well. From engine compartment, remove 2 battery hold down bolts,10mm, slide battery rearward to remove battery cables.
Oct 18, 2008 | 2003 Chrysler Concorde
Bose® CORPORATION Bose - SoundLink Mini Bluetooth Speaker Logo
Top Bose® CORPORATION Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Bose® CORPORATION Audio Player and Recorder Expert? Answer questions, earn points and help others
