Question about Video Game Consoles & Games
Put back together
Key lock fell apart
AllenTech08
  • 54 Answers
SOURCE: Looking for HP L7680 Manual. My top roller fell apart...
You can download the manual here:
http://h10025.www1.hp.com/ewfrf/wc/manualCategory?lc=en&dlc=en&cc=us&product=2512009&lang=en&
Posted on Mar 26, 2009
  • 3 Answers
SOURCE: head of philips norelco speed xl fell apart.
Same thing happened to my father's shaver. After working on it for about 30 mins, this is how I fixed it. You need to start with the top silver piece/cover. Turn it over so you see inside of it. Drop the 3 screens into the holes upside down (so they face out). You need to rotate the screens until they sit as low as possible. Now drop in the 3 blades, again sharp side down. There should be a triangular piece with 3 circles attached to it. One side is gray, and the other side has a black triangular piece. If you look closely each leg of the black piece has a tiny picture of a lock and an arrow. Rotate the black piece in the opposite direction of the arrow. Place the gray side down lining it up with the three blades. Now rotate the black piece, it will lock into position, and hold the blades in place! Finally, the silver head has a little hinge on one side. This hinge is flexiable. Bend it to a 90 degree angle, and slip it into the notch on the top part of the main body of the shaver. Close the head part, in my father's shaver I had to press a lever in the front to snap it into place.
Hope this helps!
Posted on May 13, 2009
  • 3 Answers
SOURCE: Replacing Heads for 8140XL Norelco shaver
Hope this helps!
SOURCE: MOUSE CAME APART INCLUDING SPRINGS HOW DO I PUT IT BACK TOGETHER
The Spring goes on the right side of the mouse wheel as it would be pointing at your computer. It supports the wheel to make it spring back when preasure is applied. Place the spring on the axle with the spring forming an spread out "A" (not a "V"). You will see that it falls nicely into the 2 little tower mounts. my real problem was with the other little piece of bent wire that fell out. This is the part that makes the snaping fealing as you scroll the wheel. This connects directly on the plastic part that is mounted on the scroll wheel. If you look at that plastic part you will see a small hole. One end goes in that hole & the other rounded end goes to the splines on the wheel itself. I hope this helps, it better that just saying go buy another.
Allen
Posted on Jun 25, 2010
  • 903 Answers
SOURCE: How to put together the CST2000 and install a battery
Which part of the Grass Hog did you take apart? If you mean the spool head, that is easy to reassemble. The actual spool (the round part with the line coming out) goes into the cavity on the bottom of the trimmer, with the line poking out of the hole in the side several inches (not enough to hit the plastic guard). Then the cover (orange with the spring on it) fits on top of the spool so that the spring pushes on the spool and the two tabs on the side snap into the holes in the trimmer.
Unless you took another part off, that should be all you need to do to reassemble the Grass Hog. Turn it right-side up and turn it on to make sure everything works.
Posted on Jul 13, 2010
My trunk lock for a pontiac sunfire fell apart how do I put it back together
If it fell apart it is because it is worn out so go to the wreckers and get another one
Aug 14, 2014 | Cars & Trucks
PS3 r2 button fell off
You'll have to take it apart there a screws in it the problem is they are tri heads they look like a Y you need to get that screwdriver look online you can find them once you have one its a simple fix just take out the screws and gentle take the controller apart at the seams put the pad back in it appropriate spot and put it back together. a simple fix if you have the screwdriver to do it with keep this in a nice spot cause all game consuls are put together this way its to keep you from breaking the warranty.
Apr 13, 2014 | Sony Playstation 3 (PS3) Console
Craftsman drill model 315
If it just fell apart the do not waste your time putting it back together as it will only fall apart again when you are working. Just get a new chuck.
Jun 28, 2013 | Drills
How does the hansgrohe hand held shower head md # 17850831 snaps together
The 17850 is not designed to be taken apart and put back together. They are pressed together in the factory. If it was dropped and came apart it is most likely broken beyond repair. If you need further help fell free to contact Hansgrohe Tech 1-800-334-0455.
Dec 08, 2012 | Hansgrohe Carlton 17850831 Polished Nickel...
My 2003 vw beetle initially starts when key put in ignition- then cuts out ? why
its the immobiliser cutting in. You will need to Google fixes or take it to a mechanic with good scan tool to reset.
Jul 21, 2012 | Cars & Trucks
Can some tell me if they have a picture of the inside on the switch my fell apart need put back together?
If you click HERE you will be taken to a web page of part numbers and the exploded view diagram's of the area of the washer the parts is located in.
Dec 15, 2011 | Roper RAS8445KQ Top Load Washer
Bought a KB classics build & load track set. The small car fell apart when I thought I was putting in the battery. Instead when I unscrewed the car, the small motor just fell apart. There are...
i have the same exact problem, tried to put the gears back together myself and couldn't figure it out. i tried to see if i could just order another car car but no luck with that either. please let me know, as well
Jan 01, 2011 | Toys
Video Game Consoles & Games Logo
23 people viewed this question
Top Video Game Consoles & Games Experts
James Wishart
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
