Question about Casablanca Fan 38DH32T Bel Air® Halo Weathered Copper Ceiling
Halogen bulb on this 38DH32T Bel Air Halo is pulsating
Lower light only is flashing or pulsating?
What is the wattage for the halogen lights for the hood. There are two lights but they do not list the wattage
As a general rule, the size and shape of the bulb will determine the wattage. Match it up with ones in the store, the value can be slightly higher or lower but it will still work just fine. Halogen bulbs burn out much quicker if you handle them without gloves or tissues. The oil from your fingers will cause them to burn out faster.
Jul 11, 2014 | Bertazzoni K30 PRO X 30" Kitchen Hood
How to change headlight bulb
On the back of the headlight where the wires enter, you should be able to twist and remove the lamp holder. Be careful with the new bulb if it is halogen, do not touch the bulb!!
Apr 13, 2013 | 2000 Hyundai Sonata
How to change a light on a 2001 chev cavalier
remove upper air intake splash shield.remove the headlight housing retaining bolts and pull the housing assembly out to access the bulbs.rotate bulb holder counterclockwise to remove bulbs.WARNING YOU NEED TO WEAR CLEAN GLOVE TO REPLACE HEADLIGHT BULBS BECAUSE THEY ARE HALOGEN BULBS. IF YOU TOUCH HALOGEN BULBS WITH BARE HANDS. OILS FROM SKIN WILL CAUSE HALOGEN BULBS TO OVERHEAT BLOW OUT SO WEAR CLEAN DRY GLOVES.
Oct 26, 2012 | Cars & Trucks
Are halogen bulbs a good form of light source to use for lighting a reptile's habitat?
As for the positives, halogen bulbs last a long time, are very energy efficient and produce a lot of visible light. On the downside, this type of bulb does not emit UVB light. The link below will lead you to a good quality halogen bulb, where you can find more information.
http://www.drsfostersmith.com/product/prod_display.cfm?pcatid=18316
Sep 04, 2012 | Aqueon Reptile
Installing d2r sylvania lamp in 2001 acura
look in owners manual back index for bulb replacement, it will show and tell you how to replace light bulbs.make sure you wear clean glove when handling halogen head light bulbs because oils from skin will cause halogen bulbs to over heat and blow out, halogen bulbs not cheap.
Jan 03, 2012 | Cars & Trucks
I want to upgrade my headlights on my 2001 Eclipse. What is LED, HALO, Projector CCFL lights? Or are all these basically the same?
led lights last ten times longer than any other light halogen lights are very bright but don't last as long as led. projector lights are the brightest lights thay are all most blue like air craft landing lights it depends on how much driving you do depending on the light you need its up to you
Apr 26, 2011 | 2001 Mitsubishi Eclipse
I installed a High beam hid kit and read online that they needed a resistor in that year to trick the computer. after installing the kit and the resistors to the high beams pos and neg it still flashes...
I don't know why you would install resistors inline for an HID kit, they should be 'plug and play'-you plug the connector for your halogen lights into the ballast input for the HID kit, then plug in the HID bulb harness/ bulb to the ballast output, install the bulb into the housing-done. Some people have installed relays to the lights because when the HID's 'light off' the use a lot of power until the bulbs warm up, then they actually consume less than a halogen bulb (usually 35 watts HID to 55 or more halogen). I have HID's in a number of cars and don't have relays hooked up on any, just 'plug and play' and I have no issues whatsoever.
Apr 03, 2011 | Dodge Ram Pickup 1500 Cars & Trucks
I have the Jenn-Air microwave JMV8208 and I am replacing the light bulb every 2 weeks. Can you tell me what is wrong? I've had the unit for over 5 years and the bulbs in the past have lasted several...
Are these Halogen bulbs? If so, wear rubber gloves when you handle the new bulb. The oils from your skin shorten the life of Halogen bulbs. If you do accidentally touch a Halogen bulb, be sure and wipe it with alcohol and a cotton swab before installing, or just after you have installed bulb. Do not scrape or touch anything hard with the glass of the bulb. Please rate if this helps, or if it does not. Good luck!
Jan 03, 2011 | Jenn-Air Kitchen Ranges
R 64 chevy bel air 4 door turn signal
Check the connectors on the head lights . check the dimmer switch on the floor, check the turn signal bulb sockets and make sure that they are well grounded.
Oct 02, 2009 | Chevrolet Impala Cars & Trucks
Casablanca Fan 38DH32T Bel Air® Halo Weathered Copper Ceiling Logo
21 people viewed this question
Top Casablanca Fan Dryers Experts
Henry  Thomas
Henry Thomas
Jerry Greenberg
Jerry Greenberg
Are you a Casablanca Fan Dryer Expert? Answer questions, earn points and help others
