Question about Emerson Televison & Video
Connect vcr to dtv
Connect vcr to hdtv
  • Emerson Master
  • 5,190 Answers
That would depend on what the two have to connect in terms of sockets and since you don't list any model numbers nobody here can advise you.
Posted on Jan 04, 2014
How do I connect my Sansui 6010B VCR with an analog TV and a DTV tuner?
two ways of connecting VCR with Analog TV with DTV tuner.
DTV tuner (RF) output to VCR (RF) input,VCR (RF) output to analog TV (RF) input.
turn DTV tuner on (VCR should have a TV\VCR switch that makes signal coming from tuner BYPASS VHS right into TV) note:: change channel FROM tuner.You should be able to record by placing a blank tape and pressing RECORD.
2ND. DTV tuner, VCR, should have a RCA in\out connections...Audio & video.You need a RF\RCA bypass switch. It has a INput with RCA connections to a RF signal out that goes to the RF Input of analog TV
Jun 21, 2011 | Sansui VHF6010 VHS VCR
I want to connect a vcr to the tv but there are no connections except one coaxial connection. The tv is also conneted to a DTV box. Any suggestions?
Without you giving any more detail about the TV or the set-top box, the box probably has the connections you need to connect your VCR. You could connect the VCR to the secondary coax on the DTV box, or if it has them you could use standard A/V connectors (yellow=video red and white=stereo audio).
The easiest would be to use the other coax connection and look in the DTV boxes manual to see if there is anything you have to change on the box via the menu system.
Thanks for using Fix Ya and happy viewing.
Mikeywaf
Mar 14, 2011 | Televison & Video
I want to connect our VCR to the new Sharp HDTV,but I do not find audio,video out on the tv.How do I link the two?
Some HDTVs can output analog video and audio but if you say your HDTV does not, then you would have to use some other tuner/box/decoder/converter such as a cable box if you have cable TV service or a DTV converter box for over-the-air TV or a satellite box. The VCR would connect to the tuner/converter box and record analog video and audio using the RCA yellow video and white audio jacks. Standard VCRs cannot record high-def video except as down-converted analog video.
The VCR would then connect to the HDTVs inputs (yellow, white) for playback.
Mar 03, 2011 | RCA VR651HF VHS VCR
No video output from Magnavox VCR (MDV560VR)
You need to tune a chanel on your tv to the vcr signal, using an RF cable (aerial cable between vcr and tv). That is if your tv has an analogue tuner.
May 09, 2009 | Philips Magnavox DVD/VCR Dual Player
I HAVE AN OLDER VCR,AND I CAN NOT RECORD CHANNEL 12,WHICH HAS SWITCHED FROM ANALOG! I MAY NOT BE ABLE TO RECORD EPRIOD!
Unfortunately, no. The VCR only has the older analog tuner and can't get digital channels. You'd need a converter box connected to the VCR for those.
Apr 12, 2009 | Televison & Video
Since I installed a DTV box I cannot watch a video on my VCR. I'm pretty sure all cables are properly connected. I also have a separate DVD player, which WILL WORK. The only problem is not being able to...
Did you hook the DTV box between the TV and VCR, or is the VCR in between? If you put the DTV box after the VCR, the digital tuner will block the analog output of the VCR. Let me know if this helps, and if not I will dig a little deeper.
Apr 04, 2009 | Televison & Video
Trouble w/ sanyo VCR after connecting DTV converter to TV
My garage door a craftsman 1/2hp 1999 Model. Opens without us opening it.we Donot have the Manual is there anywy we cn get it.
thanks
Patrick
Jan 18, 2009 | Philips Magnavox DVD/VCR Dual Player
I want to hook a system
you will only be able to get digital surround( dolby digital ) from your dvd player( by the coax or optical digital connections ) , the rest will only be in virtual surround
from the dtv box plug the yellow video jack(RCA) into the vcr video input , then plug the audio jack or jacks into the audio input on the vcr. from the vcr hook the audio out to the audio in on the reciever( tv/vcr/sat... input ) , then also connect RF out from the VCR to RF in on the TV .
for the dvd player hook the "s-video out" to the "s-video in" on the tv , then the audio L and R on same s-video input , then send the audio out connection on tv to L and R input on reciever dvd L and R input , then you will need to connect the optical from the dvd player to the reciever or coax connections for the dolby digital on the reciever to work
Jan 17, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
DTV Converter hookup
Is it possible to record TV programming on a VCR when using a DTV converter? h1 = document.getElementById("title").getElementsByTagName("h1")[0];h1.innerHTML = widont(h1.innerHTML); Hi,
I had the same problem and found this answer that worked for me. Hope this does the trick for you.
Simple stated, your VCR must be set to channel 3 also. Check it out.
woody
  1. You must have the VCR tuned to record on channel 3.
  2. You must have the VCR connected to output signal of the DTV converter box. In other words, the converter box must be connected between the antenna and the VCR. So, the likely configuration you would use with a coaxial cable is antenna to DTV converter to VCR to TV.
  3. You must tune the DTV converter to the channel you want to record prior to recording. The VCR won't be able to change channels on the DTV converter.
  4. You will be able to use the timed record function on the VCR but you must adhere to steps 1-3.
If this sounds freakishly familiar to recording on a digital cable or satellite set-top box, you are right. It is exactly like recording a signal from a digital cable box or satellite receiver. While it may be inconvenient to perform the steps above, at least the option still exists to record on a VCR while using a DTV converter box.
Disadvantage of DTV Converter: You will lose the ability to watch one program and record another with the DTV converter. Sorry for the bad news.
The reason is the tuner. The VCR tuner is useless with digital except for recognizing channel 3. The digital converter is a single tuner item so it only receives one station at a time.
Oct 17, 2008 | Emerson EWV603 VHS VCR
Televison & Video Logo
70 people viewed this question
Top Emerson Televison & Video Experts
matt martin
matt martin
 Grubhead
Grubhead
Are you an Emerson Televison and Video Expert? Answer questions, earn points and help others
