Question about LG DLE2532W Electric Dryer
How to reset LG DLE2532W drayer ? - LG DLE2532W Electric Dryer
  • Tedowen Jul 05, 2014
    Hi norm320 , I want to help you with your problem, but I need more information from you. Can you please add details in the comment box?
DLE2532W LG dryer, dryer won't start
new controls
not plugged in
not switched on
Aug 09, 2013 | LG DLE2532W Electric Dryer
I have an LG DLE2532W dryer. It suddenly stopped putting out heat. I've heard that there's a heat regulator switch that can trip if the unit overheats located underneath the barrel. What's the easiest...
You r correct. Take top off. Take control unit off. Take front off. Search how to videos online, YouTube, repairclinic.com, appliancepartspros.com
Jun 05, 2017 | LG DLE2532W Electric Dryer
I have an LG DLE2532W dryer and it takes hours to
the vent pipe is probably full of lint. pull the dryer away from the wall, disconnect the vent pipe and look inside the rear of the dryer and thru the vent pipe. remove any lint u find as it is a fire hazard.
Apr 21, 2009 | LG DLE2532W Electric Dryer
LG DLE2532W NO HEAT
Sounds like the heater element is bad that is the main cause for them not to heat up . Their should be a cover on the back that comes off and you can get to the heater element after removing it .
Feb 23, 2009 | LG DLE2532W Electric Dryer
DLE2532W Not heating
ask for old the fuse ,,lg have resettable thermostat...keep me posted,,its a push botton thermosatat..also they replaced this thermostat with a higher rated one,,,if you need part # just ask onthejob keeps uint from having to be reset...
Jan 18, 2009 | LG DLE2532W Electric Dryer
L G DRAYER , HEATER NOT WORKING
Had the same problem on a whirpool drayer. Get our multimeter and check which heat fuse is broken. Take that one out and throw it in the floor until you have conductivity again. Clean drayer vents and heater. This worked for me, good luck. http://www.youtube.com/watch?v=UuFQOuSlzlw
Nov 03, 2008 | LG DLE2532W Electric Dryer
Replacement of fuse and thermostat
NEED FUSE AND THERMOSTATE AND DIAGRAM
FOR MY
LG DRAYER
MODEL NO.
DLG 2524W
ART
THANK YOU
Jul 05, 2008 | LG DLE2532W Electric Dryer
DLE2532W Dryer
I had the same problem. Really glad I came to this site. Had already tried to clean out the filter area. What really worked was unplugging and resetting the computer. Everything seem fine now.
Mar 16, 2008 | LG DLE2532W Electric Dryer
LG DLE2532W Electric Dryer doesn't allow adjustment of drying options
it may be possible the contol is bad can you change the settings at all
Feb 07, 2008 | LG DLE2532W Electric Dryer
Drayer working but no heat
No heat may mean that one side of the 240 volt circuit breaker is tripped or one fuse of the 240v circuit at the fuse/breaker box is tripped. Just replace/reset the fuse or breaker which ever you have.
Dryers will have controls working but not heat if it happens to be that particular side of the 240v circuit that tripped or fuse burned.
Jan 30, 2008 | Dryers
LG DLE2532W Electric Dryer Logo
64 people viewed this question
Top LG Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
John Tripp
John Tripp
Are you a LG Dryer Expert? Answer questions, earn points and help others
