Question about Frigidaire Genuine Oven, Stove, Range Gas Igniter 5303912586 "
FrigidAire gas oven doesn't work
Oven not coming on
cresguy
  • 75 Answers
SOURCE: frigidaire gas oven not working
when the power returned there would have been a high voltage which would have blown out the fuse cange the fuse and on it
Posted on Jul 29, 2008
  • 30 Answers
SOURCE: Display not working nor oven frigidaire gallery
needs a new control. Easy to replace.
Posted on Oct 23, 2009
heatman101
  • 43501 Answers
SOURCE: I have a frigidaire GAS stove. Oven doesn't work.
Even though the ignitor glows it does not mean that it is working...sounds crazy but it is true... the ignitor needs to pull a certain amperage to let the gas valve open and as they get older they stop pulling enough current...
Check out this tip I wrote about this problem...
http://www.fixya.com/support/r3663023-oven_not_working_or_oven_not_heating
Heatman101
Posted on Mar 05, 2010
SOURCE: Frigidaire gas oven, 5 years old, oven pre-heat
I don't have a solution, but I was wondering if it constantly beeps until you press the start button? I am having the same problem with my oven preheating. Until we can figure out how to stop this we unplug it and shut the gas off when not in use.
Posted on Aug 28, 2010
  • 1531 Answers
SOURCE: I have a Frigidaire model
the first thing to check is the ignitor.turn the oven on and look to see if the ignitor is getting hot if it not you will need to check the power to the ignitor.if there is power to it then you may neeed to replace the ignitor.
If the ignitir is not drawing enough current then it will not open the gas safety valve
Posted on Dec 11, 2010
Oven won't heat.
Good Afternoon Gwen - Try reprogramming the range by unplugging it or flipping the household circuit breaker off. Wait approximately ten minutes and turn the unit back on. If issue persists, then the unit could possibly be experiencing an issue with a wiring failure, EOC (electronic oven control), sensor probe and/or faulty bake or broil element. I would strongly recommend consulting a professional to narrow down the precise issue before investing in parts that may or may not be the root cause.
May 15, 2013 | Frigidaire Gallery 30" Self-Cleaning...
Gas Oven Doesn't Maintain Heat level after initial warm up
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
heatman101
Sep 10, 2011 | Frigidaire Ovens
Gas burners work fine with electric start but oven power is off. I have a Frigidaire Professional Series model.
If the over glows when trying to turn it on then you have a bad gas valve in the oven, If it doesn't glow when you try to turn it on the you have a bad ignitor, the glow may need to be checked by removing the bottom pan on the inside of the oven.
Jun 28, 2011 | Frigidaire Kitchen Ranges
MY GAS OVEN WON"T TURN ON, IT MAKES ONE CLICK AND YOU CAN SEE SOMETHING GLOWING IN THERE BUT DOESN"T COME ON
Just because it glows that does not mean it is not bad...
heatman101
Sep 18, 2010 | Frigidaire FEF336BC Electric Kitchen Range
Heatman101
Mar 04, 2010 | Frigidaire FGF316 Gas Kitchen Range
My gas frigidaire oven is working, but the top
It sounds like you have a faulty solenoid on your FSD (Flame Safeguard Device) This should,when working correctly, allow a small amount of gas through to the burner, if faulty no gas will come through despite being turned on at the control.
It's quite a fiddly job and i would highly recommend a 'Gas Safe' engineer take a look at it for you.
I hope this helps.
Jul 08, 2009 | Frigidaire FGB24S5A Gas Single Oven
Frigidaire Range - Oven does not work
If your ignitor looks real dull orange then that is what is wrong. It needs to be bright as the sun or it is weak.
Dec 18, 2008 | Frigidaire GLGF386DC Stainless Steel Gas...
Frigidaire oven
Your oven valve won't open all the way
Aug 15, 2007 | Frigidaire FGB24S5A Gas Single Oven
Frigidaire Genuine Oven, Stove, Range Gas Igniter 5303912586 " Logo
14 people viewed this question
Top Frigidaire Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
