Question about Inland pro Bluetooth Wireless Headset 87091
Battery replacement I cannot seem to charge my headset. The manual says the LED light will be red when charging and go out when finished, instead, all I get is a blue light and it never charges. I've tried a computer, Apple wall charger, and my PS3, none of them will charge it. I asked customer service and they said the battery probably needs to be changed, even though I just got them as a gift. I cannot seem to figure out where the battery port is or how to open them to see if I can do it myself. Any suggestions?
    Problem Solver:
  • 11 Answers
I am not exactly sure, but with other products i have had, the charger was not making a connection to battery somehow. i fastened a rubber band around it and it charged. Good luck
Posted on Jan 01, 2014
Hbs700 wont charge
When you say it works when plugged in, do you mean the red light comes on? It should automaticaly turn off while charging. If you mean the red light works while charging but the earpiece seems like it consistantly has a dead battery, the battery may need replacing. It's not hard to replace. Check youtube to see how.
Jun 13, 2014 | LG HBS-700 Bluetooth Headset
Zhipingshop headphone manual
My blue LED indicator light will not turn off. It will no allow me to turn the head phones off. I've triend charging it but it just flashes red and blue instead. How can I take the battery out or is there a reset button?????
Mar 08, 2014 | XO Vision Audio Headsets IR620 -...
Red blinking light
Hi, Ephraim. The flashing red light indicates that the device is showing "low battery". It could be that the LG phone charger fits the charging port on your bluetooth headset but it is not compatible with your device. In order for you to know that it is charging, the device should show a steady red light(means charging).
Please take a look at the table reference below.
•With the Charger Plugged In
______________________________________________________________________
•Headset Indicator Headset Status
Red-----------------------------------------------Charging (battery level less than 50% charge)
Yellow-------------------------------------------Charging (battery level more than 50% charge)
Green--------------------------------------------Charging complete
With No Charger Plugged In
Off ---------------------------------------------Power off
Three blue flashes------------------------Powering on/off
Steady blue --------------------------------Pairing/connect mode
Rapid blue/purple flashes -------------Connection successful
Quick blue flash --------------------------Incoming/outgoing call
Slow blue pulse --------------------------Connected (on a call)
Slow blue flash ---------------------------Standby (not on a call)
Slow red flash ----------------------------Idle (not connected to phone)
Slow purple pulse -----------------------Connected call muted
Steady red ---------------------------------Attempting to connect
Quick red flash ----------------------------Low battery
Note: After 20 minutes on a call or of inactivity, the light stops flashing to conserve power, but the headset remains on
Hope that'll help you in some way.
**Please rate my post and/or leave a comment** ...Thanks...
Sep 25, 2013 | Motorola Mobility H560 Bluetooth Headset
My headset does not charge it gives red light flashes instead of solid red light when put on charging?
This sounds like the battery is no longer viable. Unfortunately, the headset does not have a replaceable battery. First you need to check if the headset is under warranty, and if so, get it replaced. But if it is not under warranty, you may want to take a look at the link below to see a newer headset that is compatible in looks to yours.
Plantronics M1100 Bluetooth Headset
Good luck from Headsets Direct!
May 20, 2011 | Plantronics Explorer 330 Headset
When I plug my Motorola H710 bluetooth in to charge the light only blinks red and when I use it it never seems to turn on?!
Here's the instructions for charging.
Plug the Motorola charger into the end of
the headset.
The indicator light turns red when the battery is charging. It may take up to 1 minute for the indicator light to turn on. When the headset's battery is fully charged (about 2hours), the indicator light turns green.
From your information, it may very well be that the battery should be replaced if the red light doesn't go off as it should.
Here's a link to the full instructions. I hope this helps.
(Click here)
http://www.motorola.com/Hellomoto/Master%20Lists/Product%20Manuals/Static%20Files/US-EN/H710%20QSG%20EN%20Generic.pdf
Feb 06, 2010 | Motorola Mobility H710 Bluetooth Headset
My Insignia NS-BTHDP headphones don't have a red charge light anymore. The first charge out of the pack had the red light on. But now the red light doesn't come on anymore. I wonder if it is really...
The LED may have just gone bad. Keep using it untill the battery dies, then try charging it and use it again. If it works as it should it means the LED died and there is nothing to worry about, if not you may need to replace the battery.
Jun 16, 2009 | Insignia Bluetooth Wireless Headphones...
Digimax i5 problem charging battery
■ Charging LED
Charging LED
Red LED is on = Being charged
Red LED is blinking = Charging error
 Green LED is on = Charging is complete
● If the charge indicator blinks as red, it indicates a battery charging error.
- The battery is not properly inserted
- The terminals of battery are dirty or damaged
If the battery is inserted properly and the charge indicator continues to blink, contact the
nearest Samsung Camera Service Center.
If the charging LED doesn't turn to green could mean a signal that the battery is bad or can't charge 100% anymore = too old, needs a new battery. Hope this helps.
Jul 06, 2008 | Samsung Digimax i5 Digital Camera
Charging H550
battery is fully charged (about 2 hours), the
indicator light turns off.
Jan 09, 2008 | Motorola Mobility H550 - Bluetooth Headset...
BT500V won't charge
This happens because the battery gets too low to take a charge.
To jump start the headset, connect the power lead and the LED will be flashing red. now press and hold the power and BT pairing buttons. The LED should change to solid red.
I found that holding both buttons for about 3-5 minutes allowed the battery to get enough charge to start charging and you can release the buttons and the headset will continue to charge.
If the led starts flashing again, just repeat the process again.
Hope this helps...
Baz
Dec 16, 2007 | Jabra BT500V Wireless Headset
Inland pro Bluetooth Wireless Headset 87091 Logo
127 people viewed this question
Top Inland Radio Communications Experts
eradiostore
eradiostore
Mike Charette
Are you an Inland Radio Communication Expert? Answer questions, earn points and help others
