Question about Whirlpool LTE5243D Top Load Stacked Washer/Dryer
The dryer does not dry
The washer works fine, but I have to restart the dryer 8 to 10 times to dry my wash, each time the dryer stop's I open to fill the wash, it is hot but not dry. Does anyone have any ides...My e-mail is poppy37141@hotmail.com
    Problem Solver:
  • 12 Answers
Time to clean the lint filter and the exhaust pipe (the large, white flexible hose) which could be filled w/ lint
good luck
Posted on May 20, 2009
I am having 2 issues. Most importantly, my front load washer/dryer is skipping drying time. I typically wash the clothes then put dryer sheets in and use the dry only on low heat option. It starts...
Your two issues may be related. A combo washer / dryer uses a fine spray of cool water to condense moisture out of the air stream while drying. This water is then pumped down the drain. Cold water is also used to fill the softner dispenser. If the inlet screen on the cold water connection to the machine is restricted, those are two of several things which could show up. Turn cold water valve supplying water to machine off. Unscrew cold water fill hose from machine. Remove screen from inside machine, clean, re-install, re-attach cold water fill hose, turn cold water valve back on and see if performace improved.
Mar 02, 2011 | LG WM3431 Front Load Washer / Dryer
Haier washer/dryer combo not drying clothes
Check things like the Filter / clear fluff...Make sure outlet hose if any is not kinked and passing air..Hope this helps..
Oct 02, 2009 | Haier 14.3 lb. Washer/Dryer Combo
Rinse cycle
If the machine has a soak cycle, you can use that. If it does not, you can have it fill on a cold rinse, and then stop it for a soak. Restart it on a hot wash with a cold rinse. Tumble dry low.
May 14, 2009 | Ariston Technologies AWD 129 NA Washer/...
Washer will fill fill with water but doesn't start wash cycle
it will fill but won,t spin, will throw out water as if it washed, then it take water to rinse but won,t spin ,then will throw out water as if it did , but clothes are soaked
Feb 21, 2009 | Roper RAS8445KQ Top Load Washer
Whirlpool thin twin filled with water then stopped!
Not sure about the dryer but there are a couple things that could cause the no draining issue.
You could have a leak or block in your pressure hose. Basically there is a thin, clear tube inside the cabin that attaches to the tub on the lower right side. If this has a leak or is clogged then the washer has problems filling and draining.
The other possible problem is a broken lid switch. This is an easy fix. Basically, the mechanical mechanism that goes down when you close the lid does not work properly so when it comes time to drain, the washer actually thinks the lid is open.
For both of these you would need to open cabin. I posted instructions for that here:
http://www.fixya.com/support/t1885690-whirpool_twin_washer_dryer_lte5243dq3
Dec 28, 2008 | Whirlpool LTE5243D Top Load Stacked...
Maytag neptune stackable washer dryer stopping
Maybe a water fill problem ,washer will stop if no or not enough water enters the tub in a given time
Dec 04, 2008 | Maytag Neptune MLE2000A Front Load Stacked...
Dryer problem
front load washing machine all in one are designed to use water supply also in drying cycle to condensed the hot air & move it out to outside , can you check the faucet if its open, so the moist unside the drum can out to the drain and the machine dry properly,if its ok & no water fill to drum may be your inlet water valve for the drying cycle has a problem.So that the time to call a technician to check it .
May 01, 2008 | Electrolux EW1200i Front Load Washer /...
Drum filling with water
An obstruction in the water-inlet valve may mean that it's no longer able to shut off You can easily open the valve and clean it (from scale or other dirt). Be aware you should disconnect the power cable from machine before doing it !!!! Good luck !
Sep 09, 2007 | Whirlpool AWZ410 Front Load Washer/Dryer
Whirlpool LTE5243D Top Load Stacked Washer/Dryer Logo
110 people viewed this question
Sal De
Gerry Harvey
Gerry Harvey
